Question about Gigabyte Computers & Internet
Ga g31m es2c f1 beep 1 on power and start up screen appears. after that hang up nothing respond any keys on key board.what should i do?
I tried everything like replace keyboard, resseting memory, applying thermal paste after that. the trouble still persist. hang up on start up
  • 3,368 Answers
Try replacing the mother board and processor. they are not that expensive.
Posted on Nov 28, 2014
How to fix gigabyte ga g31m es2c after long period of use now . i can power on but freeze after start screen appears.no keys on keyboard are functional .what the real trouble? is there any solution?
Sometimes it can be something simple like the ps2 cable from keyboard has dislodged.check all cables.any bleep codes should be noted.i.e.three bleeps usually unseated/ failed ram chips.
best solution would be hirens. Boot disk which will install a small Xp version on ram and allow diagnostics and fixes to be carried out.you will need to create a bootable USB or burn a disc.google hirens 15.2.if no joy you may consider the fault is coming from boot sector which is root kit problem.the solution sometimes is to remove drive and fix it on another machine then reinstall it.
Nov 28, 2014 | Gigabyte Computers & Internet
I have a GA-G31M-ES2C gigabyte motherboard. when i try to turn the pc on it appears the message "warning! main bios checksum error Retrieving recovery source from HPA" and then the pc reboots...
Hello
Take out the memory sticks.Unplug pc first. Then Clear c mos. Put memory sticks back in one at a time.
Reboot on each stick.May be a bad memory stick.
Aug 22, 2011 | Gigabyte GA-G31M-ES2L Motherboard
Mainboard GA-G31-ES2C Warning: Backup BIOS checksum error BIOS Auto-Recovering...
If you have reset the CMOS memory you need to go into the BIOS setup screen and reconfigure the BIOS. To do that you need to press a key while the computer is booting. Usually F2 but can be other keys. It should tell you on the bottom of the first screen which key to press to enter BIOS setup.
If you don't know the settings the should be one for optimal defaults - use that one. You will also need to reset the time and date.
Save, Exit and re-boot and everything should then work.
During the boot process you will see on the screen to press delete to enter setup
Jul 23, 2011 | Gigabyte GA-G31M-ES2L Motherboard
Where could i download a GIGABYTE GA-G31M-ES2C Drivers?
Here you go http://ee.giga-byte.com/products/mb/driver/ga-g31m-es2c_1x.html
Dec 30, 2010 | Computers & Internet
Gigabyte GA-G31M-ES2c Motherboard
Normal 0
You can download the drivers from Gigabyte WEB support site, select your model motherboard to download :-
http://www.gigabyte.com/support-downloads/support-downloads.aspx
Oct 06, 2010 | Gigabyte GA-G31M-ES2L Motherboard
How can i give BIOS password in Gigabyte GA-G31M-ES2C Motherboard ?
Once you enter the BIOS, Select "Set Supervisor Password" option. For detailed explanation, please check Page 53 of the manual provided here.
Mar 09, 2010 | Gigabyte GA-G31M-ES2L Motherboard
I have a problem with my board Gigabyte GA-G31M-ES2L, encounter no display & no beeps even though I remove the RAM in the board please help me to solve this problem?
Do the fans still start spinning ? And did you do a CMOS clear ?
You should also try booting it without a graphics card and/or any other audio/network card, etc, so you only have the CPU and motherboard (and also try it with 1 RAM bank and without). When it beeps, it's probably alright (implicating other failing hardware).
When you hear no beeps at all (but the fans spin), it's pretty likely that the board is gone. You might want to doublecheck the powersupply and CPU nevertheless.
Aug 18, 2009 | Gigabyte GA-G31M-ES2L Motherboard
GE-G31M-ES2c
Hi nxxoi,
I believe you meant a driver for GA-G31`M-E32C. Which is a Gigabyte Motherboard, and you can find those drivers HERE. You can also download manuals, current Bios, and all kinds of good stuff.
Good Luck, and don't forget to leave a rating based on my Solution.
Thanks
Mark
Apr 07, 2009 | Intel Motherboard
Open Questions:
Computers & Internet Logo
Top Gigabyte Computers & Internet Experts
David
David
Tony
Matthew Spark
Matthew Spark
Are you a Gigabyte Computer and Internet Expert? Answer questions, earn points and help others
