Question about Saws
Need a repair manual for DSE mini grinder S1J-AJ2-10
Replaced commutator brushes, checked continuity. Switch works but speed controller may be faulty. I can't buy new parts until I know the specifications of the existing ones.
Krazytech
  • 725 Answers
SOURCE: F1 error on SS Amana Convection wall oven
F1=Electronic range control failure
It is telling you may have a fauilty control...need to replace control or EOC
Posted on Jun 04, 2008
danny_murray
  • 55 Answers
SOURCE: ryobi angle grinder broken locking nut
You should be ablt to find it at anylowes or home depot.If for some reason thet do not have one I would call the local industrial distributor like grainger or msc
Posted on Dec 04, 2008
  • 3 Answers
SOURCE: Sunbeam Deep Fryer Model df6300 4litre
Yes, You must first check if there is a blown fuse or tripped breaker. I know on must deep fat fryer there are many safety switches to prevent grease fires. If one of these switches have failed your deep fat fryer will not heat. If you don't have power and your breaker will not reset there is a good change your fryer has a shunt trip safety. If you still have the manual it will help greatly. If not you can go on line and find the manual with a troubleshooting guide. Good luck
Posted on Dec 06, 2008
SOURCE: Need help clearing and programming in new speed dials
I actually found the "Installation Manual" to accomplish this. Switch the button on the top front of the phone to "Program". Then the screen will show a "PITS-PGM NO?" display. Type in "*" then "#" and it will ask you for the "PASSWORD". Type in your 4 digit password, the default one is "1 2 3 4". When you enter it in correctly, it will display "SYS-PGM NO?". This is where you can enter in the "number" associated with the task you are trying to perform. For speed dials, it was 001. For date and time it was 000. Using certain buttons on the phone you then navigate accordingly. Hope this helps!
Posted on Jan 07, 2009
rowdy45176
  • 2176 Answers
SOURCE: Can't get grinder to turn on. Checked brushes. . .
Did you check continuity to the field/brush holders. They have a garter spring that sometimes became overheated and broke. It seems like you have done everything else. Let me know
Posted on Feb 25, 2009
Metabo grinder 01119190 MFE30 speeds up then slows down continuously
probably needs new motor brushes and the commutator cleaned up
Jun 30, 2017 | Metabo Saws
GD0800C speed control not working
I would check the armature, specifically the magnet on the end, or check the armature commutator for partial shorts
Apr 11, 2013 | Makita 1/4" Variable Speed Die Grinder...
New carbon replaced produces too much sparks making it hot
Either your new brushes don't meet up with the armature properly or the commutator is damaged. Brushes usually 'wear in' within the first couple minutes of running. If it's getting excessivly hot you most likely have bad armature contacts and need to at least resurface the commutator or replace the armature.
Nov 24, 2011 | Makita 9553NB 4" Angle Grinder
Unit has hard time starting, need to turn wheel, only runs at slow speed
you have a problem with the bearings or the motor/brushes are burnt. Does this tool arc when running. If so I would check the brushes first, unplug the tool and remove them and while they are out rotate the motor slowly and look at the commutator bars for excessive discoloration or unusual wear.
May 08, 2011 | Makita 9565CV 5" Variable Speed Angle...
New brushes arc
you could have a problem with the commutator on the armature being cupped. To remove this you would have to use a commutator stone to clean the surface. I would recommend finding a repair shop. Also just a thought do the brushes move freely in the brush holders and are the springs on top pushing them to maintain pressure. Let me know if you need more assistance
Apr 20, 2011 | Bosch 1800 4 1/2" Angle Grinder Cutoff
Makita ga9000 9 inch grinder just stoppe working no burn smell or noise could it be bushes or something more
First check to make sure the outlet you plugged into has power. (You may have tripped a
GFI elsewhere). The next possible problem is either buildup on the brushes and
commutator shaft or in the switch assembly itself. (I have this problem on one of my
grinders due to dust in the switch assembly).
Mar 03, 2011 | Makita GA9020 Angle Grinder
Grinder runs about 2 minutes then shuts off. I replaced the heat sensor- no change. What else could be the problem?
check the condition of the brushes, make sure not sticking in the brush tube and also look at the commutator for a really dirty surface.
Dec 21, 2010 | Metabo 01451 We14 150 Quick Electronic 6...
Front windows dont work
Check on power after opening the side panel. If the master control is working with all the others,then it is possible that power is present. If so the switch, the drive or the motor could be faulty.
Remove to check onthe switch continuity, the power from switch to the control circuit to triggger the switching of the motor and finally the motor- if so try to open clean brush, commutator and reset.
hope this tip helps.
Aug 24, 2010 | 2000 Ford Windstar
Just replaced the brushes on a WE14 150 Quick 6 Grinder and sparks now come from the brushes
From my own experience.
Are the strips of the commutator smooth and flat?
(Not to insult you. The part of the armature that the brushes ride on)
If they aren't, the brushes will bounce up and down.
I put one end of the armature in a drill, and have a helper run the drill. The other end of the armature rests in the front bearing of the grinder head, which is fastened down. (To a bench) Then I use a medium tooth, (B astard) file to dress the commutator bars flat.
I also put medium grade sandpaper in-between the brushes, and the commutator surface to dress an arc on the brushes. (Turn the armature by hand while keeping the sandpaper in place)
Brushes come with a flat surface. Putting a radius on them to fit the arc of the commutator, gives them a good contact surface to start from.
Be sure the springs are putting pressure on the brushes. Sometimes the brush mounts need to be cleaned, or the brush will not slide through the mount like it should. The brush will again, 'Dance' on the commutator. (Bounce up and down)
Sep 06, 2009 | Metabo WE14-150 Quick Angle Grinder
My makita angle grinder is making a crackling sound I replaced the brushes, but it is still making the same sound
OK one of a couple things the brushes night need seated with a stone for this purpose or the armature or field is bad. Remove the brushes and look at the commutator thru the tube and see if there is a bar or 2 that has discoloration or is raised. Let me know if I can help further.
Mar 06, 2009 | Makita 9565CV 5" Variable Speed Angle...
Saws Logo
75 people viewed this question
Top Saws Experts
Tom Chichester
ray gallant
Are you a Saw Expert? Answer questions, earn points and help others
