The power button flashes lamp +timer +standby temp
    President:
  • 1,702 Answers
Hi This means you have to replace the lamp assembly. New Bulb.
If you are not trained to do this. Please seek help from your local TV repair man. Good luck.
Posted on Nov 28, 2014
  • 49 Answers
SOURCE: Turning off
Three blinking lights indicates a lamp problem.  This can be from A) a bad lamp, B) bad ballast C) bad Light Engine/DMD Board.  Try replacing the bulb first.  As with any lamps, it has a limited life.  If that doesn't work, you can try the ballast next.  If that doesn't work, it's time to take it in to a certified repair center for diagnostics.  Here is a page from the service manual on the three blinking lights.
Posted on Jan 24, 2009
SOURCE: Tv continues to turn off
I had the same prob.{standby/lamp} and I did took the advice and just tightened the screws. I replaced the lamp 5 months ago. It must have worked loose.
Posted on May 12, 2009
SOURCE: Have replaced Lamp and still does same thing.
I replaced the ballast, a solution not even mentioned by the 3 Experts I was referred to.
Posted on May 15, 2009
  • 304 Answers
SOURCE: Burned out lamp?
First. Turn on the set and see if the Lamp Illuminates, If so then you have a bad Color Wheel. If the Lamp does not light up, you have a bad lamp.
Take out the lamp and look to the center of the lamp. If you see broken glass inside you have a bad lamp.
Posted on Apr 14, 2010
ladywinn
  • 5138 Answers
SOURCE: heard a loup pop when
Color Wheel - Pull out the Lamp using a flash light look right into where Lamp was you should see the color wheel turn TV on watch to see if wheel is turning,From what you have said Problem will be the Color Wheel. Encompass Parts Distribution has them 1-800-638-3328
Posted on Sep 26, 2010
The power button flashes lamp +timer +standby temp+it makes a weird sound like a chime
This may be a failing convergence circuit. If so, go to google and search for repair kit. They are usually around $80 or so depending on your model. Or, it may be a failing power supply. It is going to be expensive repair I am afraid.
Nov 28, 2014 | Televison & Video
Tip
Error code by led indicator samsung SP67L6HX1X
<img src="mas_baz.jpg" /><br />There are three LED indicators. LAMP, TIMER, STANDBY/TEMP. Each Led or combination leds indicated problem.<br /> <ul> <li>LAMP blinking : The picture will automatically appear in about 15 seconds.</li> <li>TIMER and STANDBY/TEMP blinking : A cooling fan inside the set is not operating normally.</li> <li>LAMP and STANDBY/TEMP blinking : Lamp cover on the rear of the set is not properly shut.</li> <li>STANDBY/TEMP blinking : Check if the ventilation hole on the rear of the set is blocked, because if the inner temperature is too high, the power will shut off.</li> <li>All LED blinking : Lamp may be defective.<br /></li></ul>It takes about 30 seconds for the TV to warm up, so normal brightness may not appear immediately. The TV has a fan to keep the inside lamp from overheating. You'll occasionally hear it working.<br /><br /><br />
on Mar 29, 2011 | Samsung HL-R6167W 61" HDTV
Samsung tv lights flashing standby/timer lamp
Possible lamp or color wheel---remove the lamp and look to see it is not shattered inside.
May 30, 2012 | Televison & Video
Samsung HL-T6756 DLP TV Standby/temp light flashing and tv won't come on. I have replaced the lamp and the fan is working. Any suggestions?
Remove lamp and inspect the color wheel to see if missing pieces or shattered---it will also just before failing give a high pitched or fan like sound and if running too slow or not at all instant shutdown happens.
Its also possible if you bought a GENERIC bulb--and used original cartridge the new lamp is bad.
Apr 09, 2012 | Televison & Video
Heard a loup pop when I turned the tv on; the timer/lamp/standby/temp lights on the power on button are now flashing; when I pushed the power button again the lamp light on the power button flashes and...
Sep 26, 2010 | Samsung HLR5667W 56" Rear Projection HDTV
Burned out lamp?
Apr 08, 2010 | Samsung HLR6178W 61" HDTV
Optoma EP755 new lamp when power standby button
you need to reset the lamp timer, usually done by holding some buttons while turning on
Mar 10, 2009 | Optoma EP750 Multimedia Projector
Televison & Video Logo
42 people viewed this question
Top Televison & Video Experts
Electro Med Services...
