Question about Canon irc5185i
How do I fix my Canon IR c5185 printing double image
I have removed the transfer belt and clean it but yet still no result
    Champion:
  • Canon Expert
  • 234 Answers
Yes,if the ITB is okay,than the problem is probably in fixing unit
Posted on Nov 28, 2014
  • 36 Answers
Decrase the print speed (print on thin as on thick paper, or in color mode). If the problem is resolved, your fixing unit is defective.
    Habit-Forming:
    New Friend:
  • 106 Answers
Check the fusing unit if the heat roller engaged? The unfixed image at the roller causing Double image too in Canon IRc5185.
  • 3 Answers
SOURCE: Stripes on Images only - Text OK
Perhaps the CMY color heads need alignment. If you have not already done so, run a head alignment from the driver maintenance section. It will print out a page containing several lines and text, and request you select the closest-aligned images. After this is done, do another image print to check for improvements.
Normally, the printer uses the black cartridge for text and the CMY inks for images (even for black on photo and specialty paper). So when you are printing normal text pages on plain paper, only the black ink is used. A good check for this would be to print a normal text page, but select photo paper in the driver to trick the printer into using the CMY inks to make a substitute black text page. If this looks ok, then you are having issues other than cartridge alignment.
Posted on May 26, 2008
  • 47 Answers
SOURCE: removing transfer belt
The Intermediate Transfer Belt (ITB) slides out from the right hand side. Open the manual feeder, pull out the right side transport, remove one screw and remove the cover behind the manual feed door, lift the sensor bracket above the transfer belt,lower the handle inside the front cover and pull the ITB straight out the right hand side.
Posted on May 30, 2008
  • 6 Answers
SOURCE: Cannon IR 3100 CN Itermediate Transfer Belt error code E00070-000
The E00070-000 is not a ITB problem, but a full wastetoner. Open the front cover find the white bottle in the middle, remove the black screw, remove the cover over the top of the bottle and empty the bottle. Be sure to clean the top of the bottle so the sensor can see that the bottle is empty. Restart the copier.
Posted on Jun 07, 2009
canontech
  • 1219 Answers
SOURCE: canon ir 1600 my copier print copy image is very poor
iR1600 are special machine that needs a little bit more care.
First, clean the laser unit and optics ( beneath copy glass too ). Then use some polisher and polish the developing cylinder and clean/replace developer cylinder blade.
Use GENUINE CANON DRUM UNIT and GENUINE TONER.
Posted on Jul 02, 2010
spinal
  • 287 Answers
SOURCE: When checking the meter reading on my canon ir
Hello joe,hope you are well.Canon copiers have literally hundreds of "meters " that the device is constantly monitoring.Things like the number of 11x17 scans,reports printed,incoming faxes,outgoing faxes,prints at 600 dpi....etc.Its wild.The device is capable of displaying to the customer a total of six meters.The displayed meters may be customized for the customer by a technician as per the customers request or needs.Each meter is named by a number,for example "101".That particular meter indicates the total of how many sheets of paper(regardless of size) that have successfully exited the machine.102 meter indicates the total number of sheets that have been output using 8.5 X 11' as the basis.So a sheet of 11x17 paper would increment the 101 meter once,but the 102 meter would "click" twice.For billing purposes my company keeps an eye on the 102 meter to maximize profit,as it should be.Now how Canon determined the display of the other meters you see is a mystery.Again there is a meter named 958,which is the number of documents scanned to the MAILBOX. So, to completely answer your question: 108 is the total black and white copies made regardless of size.230 is just color and monocolor regardless of size.321 is{your gonna love this one}color prints on 11x17.322 is color prints on 8.5x11.So there ya' go! TMI city!!! Hope this helps.
Posted on Jan 07, 2011
Testimonial: "Spinal, This is great and will be a big help! Thanks so much for taking the time for such a thorough explanation. It's really appreciated. ...Joe"
How to clean error code E000732-8888 for canon IR C5185
E732 Reader communication error.
Check the connections between the reader controller PCB and main
controller PCB. Check the power supply of the reader.
Mar 11, 2015 | Canon irc5185i
Quilt y of print !, it gives double printing on page one is print of original doc.& second as its image what should i do to improve its print quilt y. i will be thank full to you
Dots, Lines, shadows and smudges on the printouts are due to dirty/ deteriorating cartridge and cleaning the green drum of the cartridge may help temporarily. Take out the cartridge and gently clean the roller/ green drum with a dry, soft, lint-free cloth wiping off the toner dots marks/ lines.
Also, make sure that the visible inside of the printer is clean and ther is no spilled toner inside, which sometimes results in dots. Double printing is also due to the deteriorating cartridge. The drum is not getting clean after its each rotation and hence the remaining toner/ image is transferred to the paper resulting in double printing. So, it is recommended that clean the drum etc (this would help temporarily). Also, make sure that the toner cartridge is in good working condition. If not you may replace the cartridge.
Let me know if any further clarification/ assistance is required.
GoodLuck!
Dont forget to appreciate the solution if I could have been of any help!
CreativeTECH
Jan 14, 2011 | Canon Image Runner 1630 Copier Copier
Canon IR C-4580 with Fiery controller
No, but the fiery will just speed up your prints etc.. I have the c3380 and c5185, they are stand alone with no fiery. If you are buying this machine for office coping it will be fine. But remember! this is a Buisness Color machine. In my customer base the 80's have done well as long as you run them as an color machine and not the office black and white work hourse. The color prints are great without any help from fiery. Sales people will try to sell you all!!!!
Jan 06, 2010 | Canon ImageRUNNER 1670F Copier
Canon IR C5185 printing black copies, would replacing black drum fix the problem?
replace the black charger... if the copies are coming out strongly black with no white lines then your drum is good... the charger died...
Dec 08, 2009 | Office Equipment & Supplies
Printing double sided color copies.
CHANGE YOUR DUPLEX PAPER SELECTION MOTOR
Sep 17, 2009 | Canon imageRUNNER C3200 Copier
Canon IR C3200 Out of registration. When i print out a test print the colors are all out of sink and not lining up on top of one another. was running fine and then it started having this problem
the cause of the problem is ,the transfer belt is not rotating properly ITB rollers must cleaned throroughly (cleaned by isopropyl alcohol) to prevent slippage of transfer belt that causes mis alignment /misregistration of color,but copying BW is ok,In other words ITB unit needs servicing
Jul 16, 2009 | Canon Office Equipment & Supplies
Canon irC3200 Yellow Bar Going Through Prints
try this press asterisk* with head then on the control panel press adjustment and cleaning then go to clean main inside unit run this 2x. try to phocopy white paper only .check wether the yellow bar is still there it could be this a problem of transfer belt cleaning unit .you can clean this by removing the waste bottle and remove one screw and pull out the cleaning unit and cleaned it and return everything hope this will help
Jul 12, 2009 | Canon Office Equipment & Supplies
Color printing problem printing in double image looks there is registration problem irc3200 canon
this is allmost allways the transfer belt assy if you have over 200k on the machine the belt is slipping ever so little. you can take out the unit and remove the belt and clean all the rolles esp the largerer drive one. seen this many times
Dec 23, 2008 | Canon imageRUNNER C3200 Copier
My Canon IR c3200 started to print olors out of focus... I read 3 manuals through, transfer belt is clean, auto calibration process gives nothing, horizontal lines printed fine but colors misplaced in...
you have miss regrestion there are several ways to correct this process 1-go into service mode -function-clear-dc con -ok then take machine off unlug from wall outlet replug turn machine on 2-replace your itb assy. 3-there is another way but you have to be next to the machine and fimilar with second level service mode.
Oct 21, 2008 | Canon imageRUNNER C3200 Copier
Canon irc5185i Logo
351 people viewed this question
old marine
old marine
