Question about Singer 2263 Mechanical Sewing Machine
Bobbin tread bunches and jams machine
Making sure bobbin is in correctly
    Sergeant:
  • Singer Expert
  • 455 Answers
If the bobbin is inserted with the thread spinning the wrong direction this will cause "birdnesting" - thread build up under needle plate, you need to cut thread to get the item off machine. flip the bobbin over into the case and try again. Also make sure you remove ALL thread caught up in "Birdsnest" when they happen.
Cheers,
Kelly
Embroidery Services
San Diego, CA
Posted on Nov 28, 2014
SOURCE: bobbin case case keeps jamming
I am having somewhat the same problem with the exception that my needle did not break. I've cleaned and oil, but the bobbin case and projection positioned spring is not communicating to allow sewing to continue. The thread keeps jamming and the bobbin raises up the plate. So, what else am I to do?
Posted on Aug 07, 2008
  • 155 Answers
SOURCE: Singer 6217C Bobbin Thread bunching
please check out this link
http://sewvacdoctor.com/cate.asp?categoryID=6#1082
goodluck
 thanks.
Posted on Oct 26, 2008
kent581
  • 87 Answers
SOURCE: bottom of stitch is bunched with alot of thread and machine jams
Try these time savers:
Test your thread quality to start, thread your machine and LIFT the presser foot (this opens the tension disks). Pull your top thread straight back. If you feel no tension no mater how much thread you pull, your thread is good. If that your machine passes that test, then let me know, we can go to step 2. If not, try different spool of thread, same test until you get a smooth pull (tip: always check your thread this way when you thread your machine)
Step 2:
Pull on your threaded bobbin thread while it’s in the machine. Does it pull smooth and even? If so, go to step 3. If not, try a new bobbin (bobbins get bent or distorted if wound too tight).
Clean thoroughly in the hook and bobbin case area and oil 1-2 drop is all.
Posted on Mar 18, 2009
  • 980 Answers
SOURCE: Touch & Sew zig-zag model 758 - bobbin thread
email me for retiming instructions and remind me of your make, drivewithken@blueyonder.co.uk
Posted on Jan 09, 2010
  • 6 Answers
SOURCE: The bobbin case on my Singer Inspiration 4210
unscrew the black plate that holds in the bobbin case and move it over to the left just a little bit, but make sure there is still clearance between the lower right corner of the case and the plate. The case should be able to wiggle a little, but not so loose it can pop out..
Posted on Mar 21, 2010
Bobbin case
Try these suggestions
1. Change the needle--use a needle that's for the fabric being sewed
2. Rethread the machine--top --make sure to use every thread guide
3. try a different bobbin--make sure bobbin is inserted correctly into the bobbin case, & make sure the bobbin is turned the correct way in the bobbin case
4. make sure the thread has not come off the thread take up lever
5. Clean under the needle plate & in the bobbin area for lint or threads
6. Check to make sure the bobbin is not warped or damaged
7. Make sure the bobbin case is correctly in the machine,, if it's a top loading bobbin you may need to have the bobbin case checked to see if it's damaged or see if the hook and hook race has a problem
8. Also could be a timing problem, and the machine would need to be checked.
Sep 28, 2013 | Janome Sewing Machines
Help trouble-shoot jammed machine
6. Also could be a timing problem, and the machine would need to be checked.
Sep 08, 2013 | PfaFF Tiptronic 2030
Bobbin bunching on elna 3230
try changing the needle
rethread the machine top and bobbin
make sure the bobbin is inserted correctly into the bobbin case
and that the bobbin case is inserted correctly in the machine
it's also possible that the bobbin case needs to be replaced
also check the bobbin it could be warped
it's also possible that the timing needs to be checked on the
machine
Nov 22, 2012 | Sewing Machines
Threading the top of model 3116 correctly
here's a link for a free manual
http://www.singerco.com/uploads/download/438_3116.pdf
make sure the thread does not come off the thread take up lever
make sure the bobbin is not over full
make sure the bobbin is turned the right way in the bobbin case
cause that can make the sewing machine jam up
clean under the needle plate & in the bobbin area for lint
Oct 04, 2012 | Singer 3116 Simple
I have a Singer Touch and sew 600e, the bobbin thread is all bunched up and machine jams up with thread. How can I fix this? Is there a simple setting that I am missing.
rethread the machine top & bobbin
make sure the bobbin is inserted correctly in the bobbin case
make sure the top thread is not coming off the thread take up lever
make sure the bobbin is wound correctly
if these suggestions don't work, I suggest that you take the machine
to a sewing machine shop to have it checked
Aug 06, 2012 | Singer Sewing Machines
Bottom tread bunching up
Check the bobbin tension and that the thread is tight around the bobbin. Make sure that the bobbin is in the right way around - the bobbin thread should double back on itself coming out of the bobbin holder.
Feb 22, 2011 | Kenmore Sewing Machines
Help problems with Bobbin and tread
I found that if the bobbin is not threaded correctly or if the upper thread is not adjusted properly, it will bunch on the bottom. Also, if the stabilizer is not firm enough for the material it will bunch.
Oct 11, 2008 | Husqvarna Viking 1
Singer 2263 Mechanical Sewing Machine Logo
199 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
