Question about Technics Audio Players & Recorders
I have a TECHNICS SA GX-500. All of a sudden the volume indicator red line went out and all volume turned off. The only indicator lights that remain are PHOHO TUNER VCR1 VCR 2 etc.Did the receiver MUT
I have a TECHNICS SA GX-500. All of a sudden the volume indicator red line went out and all volume turned off. The only indicator lights that remain are PHOHO TUNER VCR1 VCR 2 etc.Did the receiver MUTE itself? If so, How do you unmute without a remote.
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Technics Master
  • 924 Answers
Unfortunately, I don't remember the ago of this unit. You might look in your owner's manual, and see if there's a procedure for, "Return to factory defaults, or just Reset". If this unit is controlled by a microprocessor(computer within your unit), this reset may resolve your issue. If this doesn't correct your issue and require additional assistance, or would like to inquire about a repair, please visit my website at audioserviceclinic.com. You may contact me there. Thank you.
Posted on Dec 01, 2014
SOURCE: How to set tuner presets in Technics SA-GX550 receiver
The user manual is available free at:
http://support.panasonic.co.nz/docstore/SAGX550%20Book.pdf
Posted on Jun 26, 2008
  • 4 Answers
SOURCE: Overload on Technics SA-AX710 Receiver
u can measure the speakers impedance, if is ok. I think this can be a problem, when is speakers with 4ohm conected.
Posted on Apr 23, 2009
  • 4234 Answers
SOURCE: My Technics stereo system ...the display screen shows nothing
The question is, do you hear any sound? Is just the display off or is the entire unit shutdown? Can you tell?
These displays are known to develope poor solder connections at the power input and ground pins. If you can solder, open up the unit (unplugged of course) and examine the pins for the display. This will be on the PC board attached to the front panel. The pins at either end of a long line of pins will be the power and ground pins. Reasolder those pins, taking care not to short the pins together and try the unit once done. If that does not resolve the problem (assuming it is just a display problem), update this with as many details as you can about the behavior of the unit and we'll look further.
Dan
Posted on Nov 18, 2009
SOURCE: I have a Technics SA-gx550 receiver and it i turn
wich is low imp in my technics sa-gx550 please tell me?
Posted on Nov 24, 2010
SOURCE: I am trying to restore my volume to a Technics (SA-GX670) receiver.
i can,t find my speakers, at the bottom of my computer
Posted on Feb 13, 2011
I have a Technics Stereo Receiver SA-GX 500. There is very little sound coming out of all the speakers (A and B) as well as the headphone jack. I have made sure that the speaker button is depressed (A, B...
All sources or just one? Make sure the Tape Monitor isn't engaged unless you're using an external tape deck or processor. A turntable will only work on the PHONO input.
Aug 08, 2010 | Technics SUV500 2-Channel Amplifier
When I turn on my technics sa-gx amplifier I can't hear the sound
Have you noticed if the speakers selector switch in the front panel is set to off ? That position for the switch is only suited to listen heaphones. Good Luck.
Flavio/BRAZIL
Jul 28, 2010 | Technics SA-DX750 Receiver
Hi: I have an sa-gx technics amplifier and when I turn it on I can hear the sound
Try to turn it on with volume knob at zero position. That might work well.
Good Luck.
Flavio/Brazil
Jul 28, 2010 | Audio Players & Recorders
F70 displays after about 5 min of use.
According to Technics reference manual, turn the unit off, unplug for a few, plug in, turn unit on. Consult your "dealer"(authorized repair person, i guess) if light remains on. But doesn't say what f70 means, or associated with.
Unplug and open up the unit, and check the internal fuses on the circuit board. Also check for proper speaker wire hook up. Re-seat the connections. Visibly check the speaker wire runs for shorts, cracked casing, cat/dog chewing. etc.
Hope this helps.
Apr 28, 2010 | Technics SA-DX750 Receiver
I have a technics amplifier SU G75
I have a technics too, and faced the same problem. The solution is very simple just ensure the +ve and -ve wires are connected correctly for each speaker to the amp. Eg. red wire to the red knob and black wire to the black on both ends. sometimes this arises because the wires are of just one color however there will be some marking on the wire to indicate which is +ve and -ve. This took care of the overload problem.
Jun 18, 2009 | Technics SA-AX530 Receiver
Overload at medium (4-6) volumes. Can you adjust or disable the overload protection on these Technics amps??
try this mate:
http://www.electronicspoint.com/googlesearch.php?cx=002919058480771089906%3A03mranmmdze&cof=FORID%3A10&ie=UTF-8&q=Technics+SA-GX550&sa=Search#862
May 23, 2009 | Technics SA-EX400 Receiver
Technics sa-dx940 tv volume control
Check the sound setting on your TV, is it Fixed level out, if so you have to turn volume up on TV to go through the receiver.
Mar 19, 2009 | Technics SA-DX940
90 people viewed this question
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
Ben Armstrong
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
