Question about HP Color Laserjet Cp2025 Printer Laserjet 600 X 600 Dpi Laser 40000
I have a 1" wide black smear on the right page edge when using my HP CP2025. Any ideas on how to fix this?
  • 3,506 Answers
Clean the drum if you can get to it easily and also the toner but you may need a new toner and/or drum
Posted on Nov 28, 2014
Soulvisitor
  • 1113 Answers
SOURCE: HP 2600n prints black streaks on a page
Could be a few things but black cartridge is most common cause, they are not "cleanable" one just replaces them, if you carts are non gen HP then that will surely be your problem, slight chance could be transfer belt assy or fuser. they are also just a case of replacing, go for cart, replace it and see.
Posted on Dec 05, 2007
POCBM
  • 121 Answers
SOURCE: 4 - black ink smudges (1/32" wide x 1/16" high) in right margin
Very nice trouble shooting. The image defect you describe point to the OPC or drum unit this is essentially the toner cart. In your case black. Measureing the distance between repetitive defects is a sure way of diagnosing problems such as yours. Again nice work.
Google repetitive defect ruler for your model to help in the future.
Hope this helps
Posted on Apr 07, 2009
  • 48 Answers
SOURCE: HP LaserJet 2200 Series PCL huge dark smudge
Replace toner cartridge. If problem persist replace fuser unit. P/N # RG5-5559
Posted on May 25, 2009
  • 223 Answers
SOURCE: For some reason my cp2025
There is no imaging drum in this printer there is only a transfer belt. It is the green film that is visible when you open the door. This sounds like there could be a problem with the dc controller take the printer to a local asp.
Al
Posted on Oct 01, 2010
CreativeTECH
  • 1719 Answers
SOURCE: HP CP2025 Heavy smears of magenta
It is due to spilled magenta toner leaking from side to the toner cartridge. Take the cartridge out of the printer and clean it. Clean visible inside of the printer. Shake the cartridge lightly in horizontal position to evenly distribute the toner inside the cartridge and put it back. The issue sould be fixed after some prints.
Good Luck!
Appreciate generously, if the solution could have been of any help!
CreativeTECH
Posted on Dec 23, 2010
My CP2025 HP Printer toner is smearing on cardstock when I run multiple copies, but I can't figure out how to change the options for heavier paper. Where do I find it?
The easiest way to set the paper types, if you are connected via network is to access the embedded web server of the printer. simply type the IP (network address) of the printer into the address bar of your browser and a page will open that controls all functions of the printer. Setup you paper types as required. I would suggest that you feed the heavy stock through the manual tray not the standard paper tray.
Feb 20, 2015 | HP Color Laserjet Cp2025 Printer Laserjet...
I am getting black streaks 1" wide on the right edge of each page. I have checked the rollers on all four cartridges, inspected the fuser (as best I could) and everything appears to look OK. No exces
Hi, You will have to run a cleaning cycle and do that as many times it take to fix the lines. If you don't use your printer enough the cartridges will dry up. This is a common problem with cartridges. If you are fed up with costs. Invest in a laser printer. They last longer and don't need cleaning as much. Hope that helps you.
Nov 28, 2014 | HP Office Equipment & Supplies
My HP CP2025 printer will not print color text and color shading in Word. It prints color photos, pdfs, and paintbrush files, but will not print color in Word or Word Perfect.
I had this problem on Windows 7 64x.
The solution that finally worked for me:
1. Go to your Devices & Printers window. (from the Start menu)
2. Right-click on your HP CP2025 printer and select Printer Properties.
3. Select the Device Settings tab.
4. Scroll to the bottom where you see Device Type. It probably says "Auto Detect."
5. Click on the words "Auto Detect" to activate a drop-down menu. Select "Color". Click the Apply button.
To test if this fixes your color printing, go to the General tab and click the Print Test Page button at the bottom. The page should print the Windows logo in color at the top of the page (the rest of the page is b&w).
Note: I did not install any additional drivers from HP for this printer. Windows automatically detected it and installed HP's Universal Print Driver PCL 6.
Kudos to Ken from the HP forums for this knowledge: http://h30499.www3.hp.com/t5/Printers-LaserJet/CP2025-Won-t-Print-in-Color/td-p/1151762
Feb 10, 2011 | Office Equipment & Supplies
HP CP2025 Heavy smears of magenta appear down the right-hand side of paper. Have tried restart and changing paper weight.
Good Luck!
CreativeTECH
Dec 23, 2010 | HP Laserjet Cp2025n Printer
For some reason my cp2025 printer will occasionally print horizontal lines about an imaging drum revolution space between them, and runs down the page. The lines are about a 1/2 inch wide. Sometimes it...
Al
Aug 25, 2010 | HP Laserjet Cp2025n Printer
Colour laserjet HP cp2025 keeps going into cleaning mode - why ?
Re: CP2025 cleaning at every possible moment Talked to HP support and fixed mine by changing Settings/Paper Handling/Tray 2 Type to "Heavy 111-130g"
All paper handling settings as follows:
Default Paper Size: Letter
Default Paper Type: Plain
Manual Feed: Off Duplex: Off Bind: Long Edge
Tray 1 Size: Any size Tray 1 Type: Any Type Tray 2 Size: Letter Tray 2 Type: Heavy 111-130g
Paper Out Handling
Specify Time and Action Paper Out Time: 0 Seconds
Paper Out Action:
Override
Apr 17, 2010 | HP Color LaserJet 2600n Printer
Brother MFC9600 dirty printing
We were having a lot of print quality problems, similar to what you describe. We replaced the drum and it worked fine.
Nov 19, 2008 | Brother MFC 9600 All-In-One Laser Printer
Smudges on right ride of paper
want the answer to this we have a hp 2600n laser printer and its leaving smug of color on the paper the big wide roller where the page gets printed is smear with all the colors. Is there a way to clean this and what to use so we can fix the problem.
connie petrik mu email address is connie.petrik@att.net please give me a answer to this problem.
Jul 11, 2008 | HP Color LaserJet 2600n Printer
Black smear of ink at end of lines
Please load the printer with at least 10 sheets of plain paper then press the start button. This will dry or clean any ink found on the rollers.
Continue to run blank pages through the printer until no more ink is found on the paper, then attempt printing. If ink stains, streaks or smudges are still present, the printer may need service.
May 23, 2008 | Epson Stylus CX4800 All-In-One InkJet...
HP Color Laserjet Cp2025 Printer Laserjet 600 X 600 Dpi Laser 40000 Logo
150 people viewed this question
Seeker5211
Seeker5211
