The power button flashes lamp +timer +standby temp+it makes a weird sound like a chime
    Problem Solver:
  • 14 Answers
This may be a failing convergence circuit. If so, go to google and search for repair kit. They are usually around $80 or so depending on your model. Or, it may be a failing power supply. It is going to be expensive repair I am afraid.
Posted on Nov 29, 2014
SOURCE: Tv continues to turn off
I had the same prob.{standby/lamp} and I did took the advice and just tightened the screws. I replaced the lamp 5 months ago. It must have worked loose.
Posted on May 12, 2009
  • 304 Answers
SOURCE: Burned out lamp?
First. Turn on the set and see if the Lamp Illuminates, If so then you have a bad Color Wheel. If the Lamp does not light up, you have a bad lamp.
Take out the lamp and look to the center of the lamp. If you see broken glass inside you have a bad lamp.
Posted on Apr 14, 2010
  • 610 Answers
SOURCE: The picture on my tv slowly started going out and
It sounds like the color wheel has failed and will need to be replaced. I would recommend calling a technician to do this job. You can call 1-800-samsung to find the nearest service center.
Posted on Jul 20, 2010
ladywinn
  • 5138 Answers
SOURCE: heard a loup pop when
Color Wheel - Pull out the Lamp using a flash light look right into where Lamp was you should see the color wheel turn TV on watch to see if wheel is turning,From what you have said Problem will be the Color Wheel. Encompass Parts Distribution has them 1-800-638-3328
Posted on Sep 26, 2010
SD Tech
  • 14553 Answers
SOURCE: samsung tv lights flashing standby/timer lamp
Possible lamp or color wheel---remove the lamp and look to see it is not shattered inside.
Posted on May 31, 2012
Samsung tv lights flashing standby/timer lamp
May 30, 2012 | Televison & Video
No picture no sound lamp light and standy / temp light flashing
Two things to look at---------the lamp to see if shattered inside AND with it removed look where it faces at the color wheel--see attached photo.
Look to see if any segments are broken, missing etc. Many of the wheels fail in this way and some will have a high pitched or even fan like sound before they fail.
Some when really bad will make a grinding noise also. The set monitors the speed of the wheel and if it slows or stops the set will almost instantly turn the lamp off(if possible watch from area where lamp is to see if at turn on to see if it for a moment lights or not.
May 05, 2012 | Samsung HLR5067WX 50" Rear Projection HDTV
Samsung HL-T6756 DLP TV Standby/temp light flashing and tv won't come on. I have replaced the lamp and the fan is working. Any suggestions?
Remove lamp and inspect the color wheel to see if missing pieces or shattered---it will also just before failing give a high pitched or fan like sound and if running too slow or not at all instant shutdown happens.
Its also possible if you bought a GENERIC bulb--and used original cartridge the new lamp is bad.
Apr 09, 2012 | Televison & Video
For the last couple of months there's a buzzing sound when the TV is powering up. A couple of times I list picture during a show but, I powered down and the picture came back. Now, I don't even get a...
You could have 2 things Color Wheel and Lamp needs to be replaced Color wheel is what Making buzzing sound,
Go to Encompass Parts Distribution 1-800-638-3328
Type in your Model # they will have list of Parts/Supplies
Oct 05, 2010 | Samsung HL-R6167W 61" HDTV
Heard a loup pop when I turned the tv on; the timer/lamp/standby/temp lights on the power on button are now flashing; when I pushed the power button again the lamp light on the power button flashes and...
Sep 26, 2010 | Samsung HLR5667W 56" Rear Projection HDTV
The picture on my tv slowly started going out and began making a weird sound. Kind of like an internal fan was turning on and off. The power on button has "Timer," "Lamp," and "Standby/Temp" flashing. What...
Jul 20, 2010 | Samsung HLR5667W 56" Rear Projection HDTV
Burned out lamp?
Apr 08, 2010 | Samsung HLR6178W 61" HDTV
No picture and no sound
Those blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
http://electro-medical.blogspot.com/
http://homenol.blogspot.com/
If blinks continue without any pause, the main board is faulty.
Mar 11, 2017 | Samsung Televison & Video
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
