How do I fix loose on/off button?
Nothing. Use remote.
    Problem Solver:
  • 5 Answers
Just open the remote controler and clean the contact surface or trace by continuity the connection for corossion that makes it open connection from the ic
Posted on Nov 28, 2014
Testimonial: "It's the on/off button on the set itself that does NOT work, NOT on remote controller. That's why I use remote controller!"
On my dish remote for tv 2 sat button stopped working and wont light up. all other buttons work. i have changed batteries but nothing changed. How do i fix this because i dont wan to waste money on an
Kevin rico,
I can definitely check this out with you. Does the SAT button light up when you press any buttons at all? If you press SAT, can you operate the receiver?
If neither of those work then the remote most likely needs to be replaced. If you would like to try that option, just send me an email at thomas.faust@dish.com and i'll assist you further!
Tommy Faust
DISH Social Media Representative
Jul 05, 2012 | DISH Network 142923 Remote Control
Bought a new RCA 37LA30RQ. Remote worked for the first 2 days we had it. Now, when I press power (or an other button), the power button on the remote quickly flashes and nothing turns on. Changed the...
Im pretty sure all you need to do at this point is reprogram the remote. If you dont have the codes go to the RCA website. They normally loose the codes when the batteries die and you have to change them out and re-program it. hope this helps!
Sep 09, 2011 | RCA Universal Remote Control
I have a RC28T1-27 Remote that suddenly no longer works. Put in new batteries and it seems like there is no connection. Will not work unless you keep pressing buttons repeatively.
The problem is that the broadcasting antenna at the top of the remote is very a very thin wire wrapped around a heavy cylindrical magnet and its solder points are extremely weak. You most likely dropped it and it came loose. I re-soldered mine and it worked perfectly.... until it broke again. The leads are very small and hard to fix.
Chalk it up to poor design.
It is hard to take apart.... I got mine apart by wedging a screwdriver in and twisting until it popped apart. (nothing broke) I started at a bottom corner and worked my way up the side until it came loose. It is a fairly easy fix if you know how to solder.
Jun 29, 2010 | Televison & Video
My remote does nothing that it was made to. It just stop working. I changes batteries and still the tv does not respond. When I press a button on the remote the red light comes on just like when it was...
try to check your remote sensor if working.Using your cellphone camera,point your sensor on your cellphone camera you should see a illumination of light on your remote control once you press the a button on your remote..if not try to fit your battery tou your remote there might be a loose contact on battery terminals..or open the casing of your remote control.visually inspect the battery terminals from a loose contact and corrosion.if this dont solve your problem,replace the crystal oscillator of the remote..it is the color orange square in shape with two terminals soldered near the ic..it is labeled with frequency....
May 17, 2010 | Toshiba 32A30 32" TV
Light comes on but nothing happens
You need to replace the remote more than likely. Thanks for using Fix Ya.
Jan 29, 2010 | DISH Network 135899 Remote Control
Remote will not work
sounds like you could be right-
possible fix----try removing battries and re-placing with brand new ones also pressing the on/off button while holding down the 5 button can reset the remote - I have never tried this myself but I was told by the manufactors that this is the way to do this - if you can belive that- worth a go - nothing to loose everything to gain.B/O/L------P.
Aug 06, 2009 | Toshiba 32A30 32" TV
Logitech Harmony universal remote stuck in safe mode
Just a message to all that have problems with there Logitec remotes. My remote went into something called a "safe mode" when my partner changed the batteries while holding the power button.... I pressed every single button to try and get out of it but nothing seemed to work, (I was getting pretty frusterated, there is nothing in the manual to tell you how to fix this problem), however, I have now learnt that as you replace the batteries you need to have the number 2 button held in as you replace the last battery. This works 100% so if you have any trouble with the "safe mode" then this is what fixes it.
Carly.
Jul 14, 2009 | Logitech Harmony 520 LCD Remote Control
TV not responding to remotes
I ASSUME IT'S JUST THE REMOTE YOU'RE SPEAKING OF- FIRST, IF YOU HAVE A DIGITAL CAMERA, OR CAMERA PHONE, AIM IT AT THE INFRA-RED LED'S ON THE FRONT OF THE REMOTE, AND PRESS BUTTONS [LIKE POWER OR CHANNEL] - THE CCD'S USED IN DIGITAL CAMERAS ARE VERY SENSITIVE TO IR, AND YOU SHOULD SEE A WHITE LIGHT [IMAGE] OF THE LED'S, EITHER STEADY, MOMENTARALLY, OR PULSING. IF THE REMOTE HAS BEEN DROPPED, THERE IS A CCHANCE THE CRYSTAL CONTROLLING THE FREQUENCY HAS BEEN DAMAGED. TRY A UNIVERSAL REMOTE, ALTHOUGH OFTEN YOU MAY LOOSE SOME FUNCTIONS, OR THE BUTTONS REACT DIFFERENTLY THAN LABELED. SELDOMLY, BUT IT DOES HAPPEN, THE IR RECEIVER SECTION OF THE SET ITSELF CAN FAIL. THE IR RECEIVER [LOOKS LIKE A DARK LED] CAN FAIL, AND THEY'RE COMMERCIALLY AVAILABLE AT RADIO SHACK
Feb 28, 2009 | Sony FD Trinitron WEGA KV-32FS100 32" TV
Samsung TV remote control
I HAVE THE SOLUTION TO THIS PROBLEM.
Confirmed with Samsung tech support. Problem is with remote. to fix, simple take the batteries out of the remote. Press and hold the UP Volume button for 2 Mintues (no cheating, it has to be at least 2 minutes), this Reset's the Remote Control. Put the batteries back in. Bob's your uncle. all fixed.
Sep 28, 2007 | Samsung TV Remote Control
TV issue
first you should open the set and make sure that the cables are seated properly, could be a loose or pinched cable
Apr 24, 2007 | iLO 3200 32 in. LCD Television
Televison & Video Logo
26 people viewed this question
Top Televison & Video Experts
Electro Med Services...
