Question about Car Audio & Video
Audiobahn aw1205q sub. 1 voice coil works the
Audiobahn aw1205q sub. 1 voice coil works the other does not. 1Voice coil looks like its burnt. Can this be repaired?
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 36 Answers
Replace but maybe replace wire connection. Try Radio Shack for part.
Posted on Nov 28, 2014
4 Suggested Answers
simplemitch
  • 752 Answers
SOURCE: 2 dual voice coil 12" 1200 watts subs
Are they dual 2 ohm or dual 4 ohm?
Posted on Sep 22, 2007
  • 18 Answers
SOURCE: I have 15" audiobahn subs, but I need the right wiring
Contact company the can send you diagrams or go to a stero stop they should be able to help because some shop have wire diagrams for best way to get the most thump in you r trunk.Make sure you know the ohms your subs is 1-2-4 ohms.Should say on the back of your sub and how many contacts are on in two or four.
Posted on Mar 03, 2009
SOURCE: sub does not operate
There could be many issues, from fuses in your amp, to power getting to your amps, to "low" impedance on your amp, and the circuit shutting down. Or it could even be your head unit, perhaps there is a setting on the HU that turns ON/OFF the subwoofer. BTW, you are running to low of an impedance on that amp. If my memory serves me correct, the lowest impedance that they JL Audio recommends is 1.5 Ohms.
Posted on Aug 10, 2009
How to wire subwoofers aw1205q
That is highly dependent on the amplifier being used. The subs can handle 1000 Wrms. They have dual 2 ohm voice coils, so they can run in either a 1 ohm or 4 ohm configuration.
Aug 02, 2014 | AudioBahn Car Audio & Video
I got 8 terminals on a my 15 audiobahn sub how do i hook at 2ohm load
Yes audiobahn do make a QUAD coil, and some people get confused with the - - + + on the terminal, This is called a dual lug, Check out Audiobahn.com and go to tech suport. Thier you can look up the wiring diagram for this sub... TRUST ME hope this was helpful positive feed back be nice lol
Apr 08, 2010 | AudioBahn AW1206T Car Subwoofer
Needs to be serviced.. bad terminal.. bad voice coil. who fixes these ?
From what I've gathered lately, audiobahn has gone out of business. You will likely have to go to a speaker shop that specializes in repair. Unless your sub is worth more then 200 dollars or so- your probably better off replacing it.
Oct 26, 2009 | AudioBahn 400w E Car Speaker
How to wire post to post for 1subwoofer audiobahn aw1200n
depends on how you're hooking them up to the amp, and what type of amp it is you are using. but to wire them parallel, and drop the ohm rating, assuming it's a dual voice coil sub, you wire - to + on the sub, then - to the - on the amp, and + to + on the amp. Here's a diagram:ae0c628.jpg
Oct 07, 2009 | AudioBahn AW1200 Car Subwoofer
I BLEW MY AUDIOBAHN AW1208T SUBWOOFER AND WANT TO KNOW IF IT CAN GET FIXED I THE THINK ITS JUST DUAL VOICE NOT SURE THOUGH
is the rubber surround blown out.. look at voice coil itself .. it could be repaired but maybe not worth it. can u actuate the speaker down and up.. if you can then the voice coil is fused.. and if u can and u hear or feel resistance then there is work to be done to the voice coil and spider. Could be costly.. if its just the rubber.. use silicone to re-seal it.. ol skool trick..
Sep 14, 2009 | AudioBahn AW1208X Car Subwoofer
Wiring subs
audiobahn.com can help you with the free diagrams under tect support
May 03, 2008 | AudioBahn A4075HCQ Car Audio Amplifier
Amp. Audiobahn a2300hcx
If the subs are dual 4 ohm voice coils and if your amp is good down to 1 ohm, your best bet is:
  1. Connect the voice coils in parallel ("+"s together, "-"s together). This will make the impedance of each sub 2 ohms.
  2. Connect the subs in parallel.
  3. Bridge the amp to one channel.
This should max the amp out at 2400W, which means about 1200W per sub.
If your subs are single 4 ohm voice coils, do the same steps, but you'll only be able to load the amp to 2 ohms, which means about 600W per sub.
Also keep in mind that box size, type, and quality make a big difference in how subs sound.
Mar 20, 2008 | AudioBahn A2300HCT Car Audio Amplifier
Is it enough
Audiobahn subs are not too powerful and they can not handle too much continuous RMS, be careful they will heat up and tear off the voice coils off ur subs. run about 100 - 150 RMS at 75 HZ to each sub and keep the gains at about 3/4 this way you will avoid blowing out your subs. It also depends on the amp? What kind of amp is it?
Let me know if you wish. Otherwise
Oct 21, 2007 | MA Audio HK4000D Car Audio Amplifier
Car Audio & Video Logo
56 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
