<!-- from fixya rte -->The power button flashes lamp - Televison & Video
  • 54 Answers
Lamp bulb is failing. You should get a message to that effect, but sometimes if it has been replaced before it will not show it needs to be replaced. All you can do is replace the bulb, note that some of the newer replacement housing's are not exact fits, so you will need to modify it with the old housing. Good luck
Posted on Nov 28, 2014
I got the 'lamp needs replacing' message. Ignored it. Now my tv screen is black when you try to turn it on and the blue button on the power button flashes?
You haven't replaced the lamp at time. Replace a new lamp along with its ballast and make a lamp time reset. If you wish to get more details about the lamp replacing procedure to Panasonic PTVs, check this link.
Feb 05, 2013 | Panasonic PT-44LCX65 Television
How to reset lamp after replacing the lamp on epson emp x5
1. Make sure, your projector is on standby.
2. While holding down the projector's Comp Sync + and Comp Tracking + buttons, press and hold down the power button.
3. After status light 1, 2, and 3 flash ON and OFF at least three times, release the Comp Sync + and the power button. The flashing lamps status indicate that the lamptimer is reset.
Aug 02, 2011 | Epson EMP-X5 LCD Projector
No power to tv. When i press the power button i only get a blinking green light then it stops and the blinking red light for lamp flashes and keeps flashing
You need to replace your lamp. Also check power supply and ballast board. Most of the time if you replace the lamp it will come back up. After replacing the lamp you will need original remote to reset lamp hours.
Jan 24, 2011 | Sony KDS55A2000 55" HDTV
After changing the bulb image will not come on and solid orange light appears
Other then POWER BUTTON light there are three lights more
1. lamp indicator
2. temperature indicator
3. computer input
witch one light is flashing RED or illuminated RED with POWER BUTTON orange light.
If LAMP INDICATOR light is illuminated RED than lamp runtime has reached 1800 hours. but projector still working.
If LAMP INDICATOR light flashing RED than lamp circuit failure, or abnormal function or lamp unit is damaged. In this case projector doing the same behave just like your projector.
if TEMPERATURE indicator illuminating RED the projector still projecting and if flashing RED than turned of itself
Jan 11, 2011 | Panasonic PT-LB50U Multimedia Projector
When i try to turn my camera on it flashes a small red light and then it won't turn on, how do i fix this?
The Red indicator flashing in the Camera may be the Access Lamp or the Power Lamp. The Access Lamp is located below the Control buttons and the Power Lamp near to the power button. If the Access Lamp is flashing, it indicates that the Camera is accessing the Memory. Do not remove the Memory Stick or Batter while the Access Lamp is lit.
If the Power Lamp is flashing, it indicates that the Camera is turned on. If the Lamp is lit in Red it shows that the Battery is not having enough charge. Insert new batteries or charged Nickel-Metal Hydride batteries to resolve the issue.
You may also try power resetting the Camera. To power reset the Camera, remove the batteries from the Camera and then press and hold the POWER BUTTON of the Camera for 15 seconds and then reinsert the batteries after 1 minute and check if the Camera works normally. If the issue persists, service may be required.
Thanks
Oct 21, 2010 | Sony Cyber-shot DSC-S730 Digital Camera
Heard a loup pop when I turned the tv on; the timer/lamp/standby/temp lights on the power on button are now flashing; when I pushed the power button again the lamp light on the power button flashes and...
Color Wheel - Pull out the Lamp using a flash light look right into where Lamp was you should see the color wheel turn TV on watch to see if wheel is turning,From what you have said Problem will be the Color Wheel. Encompass Parts Distribution has them 1-800-638-3328
Sep 26, 2010 | Samsung HLR5667W 56" Rear Projection HDTV
Just replaced lamp. when plugged in, power light
hello make sure the lamp is fitted securely and the lamp cover aswell
regards
shaun
Jan 16, 2010 | Panasonic PT-50LC13 50" Rear Projection...
No picture, no sound, power button blinks 47 times, then lamp flashes 134 times, then shuts off
It is symptom of weak Lamp in your TV, replace Lamp with following part number..
A1606034B LAMP BLOCK XL-2100U
It is available in Sony Accessories for $200
Always buy Sony Original Lamp for your Sony TV and avoid aftermarket/ cheap lamps.
Apr 22, 2009 | Televison & Video
Replace lamp soon flashing during warm-up
Press the left and right buttons, as well as the power button once the lamp has turned on. This will reset the lamp life counter.
Jan 16, 2009 | Mitsubishi XL5U ColorView Multimedia...
Televison & Video Logo
29 people viewed this question
Top Televison & Video Experts
Electro Med Services...
