Question about Car Audio & Video
My soundstream tx1.1300D amp is in protect mode.
My soundstream tx1.1300D amp is in protect mode. Hot wire that ges through my firewal got bare and was arching or grunfinv out. I forgot to put rubber gasket. Irewired everthing properly but the amp still protect mode. I slowly op we nex amp and it all looks good i think and theres no burnt smell to it. But i have no idea what to look for. Can any assist me on where to take amp to getfixed in sacramento area. Thanks.
techman
  • 3130 Answers
SOURCE: working on a MA Audio HC4002 amp......
On an amp? All the devices should be replaced at once as they can measure or look good, but still have a high resistive leakage, and if this happens to save a couple of bucks, you can blow out all the devices you just replaced. The thing with solid state devices? Most of the time you cannot look at them and see they are bad unless they had a total blowout and blew apart and put a big hole into itself and then yes that ones bad and beleive me most of the others are too. Good Luck
Posted on Oct 09, 2006
SOURCE: amp staying in protection mode
No, this amp is not a heavy power consumer- matter of fact it takes very little power to run.Maybe you should check the fuses on the amp to see if they are what is recommended.Also check your fuse kit to your amp- your fuse might not be big enough.If neither works take it back where u got it.
Posted on Jan 02, 2008
  • 631 Answers
SOURCE: 500/1 sub amp stopped working, burnt rubber smell
It sounds like the power supply failed. Generally when the supply fails in that amp, you have to replace all 8 of the power supply FETs and all 8 of the 47 ohm surface mount resistors. Many times, the supply fails because one or two of the output transistors have failed.
If you want to have JL repair it, you MUST go through an authorized JL dealer.
If you have a good local repair shop, they should be able to repair it.
Let me know if you have any other questions.
Posted on Aug 06, 2008
  • 631 Answers
SOURCE: car audio amp in protection mode
If you power up the amp with the RCAs plugged in, does it go into protection mode.
If you power up the amp with the RCAs plugged in, does the woofer pop?
Posted on Oct 26, 2008
  • 631 Answers
SOURCE: my amp stays in protection mode
Does it go into protect in the vehicle if you disconnect the speaker wires from the speaker terminals of the amp?
Posted on Nov 30, 2008
Amp 1000sx
it sounds like protection mode is on check to make sure no wires are touching metal or the frame
Aug 19, 2013 | Soundstream Car Audio & Video
I have a 1998 Dodge Caravan it keeps blowing the engine fuse when the engine gets hot
try a highr amp fuse and also check the wires for bare spots that could lead to any arching off the wire
Apr 28, 2012 | Dodge Caravan Cars & Trucks
MY soundstream LiL Wonder 4.620 is only going in protection mode
Disconnect all speakers Meter power, remote, ground at amp, if all is good move on, if not check main fuses
Turn amp on; If in protect mode then your amp is toast Turn amp on, if not in protect mode then start reconnecting speakers one by one until your amp goes into protect mode, then you'll know which speaker is bad.
Sep 19, 2011 | Car Audio & Video
The diagnostic LED indicator comes on and i dont know why
first check the ground as it is the most important par to the wiring and operation of an amp. itshould be t the frame of the careand touching clean bare metal no paint! if that doesnt work it may be going into termal protection meaning ts getting too hot. you should always be able to continously keep yourhand on the amp, if its too hot try backing the gains down a little. next make sure the spakers are ired to a safe impedance for the amp. if its wired too low it might could put the amp into protect mode or blow it! most amps are only 2 ohm stable nd 4 ohm stable when you bridge them...hope this helps!
Sep 15, 2010 | Performance Teknique ICBM-775 Car Audio...
Goes into protect mode..
you probly have speaker wires arching. unplug them and replug thm in making sure no bare wire is showing
May 17, 2009 | Sony STR-DG520 Receiver
Whenever i go over bumps goes into protect mode
it will probably more than likely be a problem with either a speaker being loose or a bare wire someplace in the wiring
Apr 22, 2009 | Kenwood DNX7120 Car GPS Receiver
My amp stays in protection mode
Nov 29, 2008 | Sony XM-2002GTR Car Audio Amplifier
Sounstream tra 560.2 always in 'protect'
It probably has shorted output transistors. To eliminate other possible causes, read through the following page.
Amplifier in Protect Mode - Troubleshooting
Nov 01, 2008 | Soundstream Tarantula Car Audio Amplifier
Goes into protection mode for no reason
if the amp is powering on the sub and playing and then turns in to protect mode it could be the amp is getting hot and its kicking into protect so you wont fry the amp
May 06, 2008 | Kicker 06ZX750.1 Car Audio Amplifier
Amp staying in protection mode
Jan 01, 2007 | Soundstream XTA880.2 Car Audio Amplifier
Car Audio & Video Logo
119 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
