Question about Vtech VM321 Video Baby Monitor 1 Camera Communications Safe &
Vm321 infrared leds stoped working
Everything works great but the infrared leds no longer illuminate in night vision mode. The black and white enhanced night vision works with a light source like a night light. But without a source the screen is just black (audio works fine regardless).
    Problem Solver:
  • 5 Answers
It might be cause of open infrared diode or shorted
Posted on Nov 28, 2014
I have a swann security camera with night vision & it doesn't show a picture at night. What could be the problem
Those cameras use infrared led lights to see at night. If you have no image at night then those led lights are not working.
Aug 24, 2015 | SWANN Home Security
I have the swann 8 channel platinum cctv camera system and whilst it works with amazing quality during the day, the night vision is almost non-existant, it won't trigger cameras and is very dark on sc
Nearly all cameras work well in the day. Night vision depends on the type of camera and the technology it is using. For example a CMOS based camera will provide a very poor quality picture in the dark. A CCD Super HAD CCD II will provide a good picture with 0.01 illumination and a EXVie HAD CCD II will provide an even better picture with lux of 0.001. You really need to look at the specifications of the camera before you buy and not go with the "Platinum" or hype keywords used by the manufacturer. I have seen a lot of SWAN Cameras which are basically useless at night.
Aug 21, 2014 | Swann Communications Home Security
I bought 2 outdoor CCTV.camera RV537B with night vision. one of the unit has not functioning properly on night. i tested it by covering the photo cell that switch the LED lamp which is ok but it seems to...
I think I answer you question--when?? Take the good CCTV camera and hook it up to monitor. Then hook up the CCTV camera and turn it on. Point the working CCTV camera at the bad camera that is turn on. Now, look at the monitor which is working with your operational camera. Look at the bad camera while it on, and see how many IR LED's you can see on the bad CCTV, while it turn on. You should be able to the IR LED glowing red. If not, then there is a problem with bad CCTV IR LED's. Short wire, no power to the IR LED's. stewbison
Jun 24, 2011 | Optics
The night time video doesnt work and the screen is black. It works fine during the day. Not sure what has happened to the night time mode. Even when plugged into the ac adapter the screen is still black...
It sounds like the Infrared LED are not on (there are 8 of them on the fornt of the unit), it should automatically turns on when it senses dark scene. You can find out at night using the digital camera pointing at the LEDs, you should see white glow on your digital camera.
The problem can be caused by the power supply that supplies the power the LED assemblies or the detector circuits that suppose to turn on the LED when the surrounding area is dark has failed.
Jun 24, 2011 | Summer Infant Additonal Camera for Video...
Illuminator doesn't work despite replaced battery
It needs a new IR illuminator bulb or LED...stewbison
Dec 31, 2010 | ATN Viper Night Vision Goggles - FREE UPS
Will the Bell Howell DNV900 HD Infrared Night Vision camera work in total darkness? Where can I get the spes on this camers
It will only see anything if there is an infrared light source. It's got an infrared led for this, but that wil probably only illuminate the first meter from the camera, you need an IR light, such as the onse used witrh security camera's to see further
Dec 18, 2010 | Bell & Howell Bell Howell DV1200HD...
Is there a night vision part to enhance vision for this camera?
Generaly most night vision cameras are of the infrared kind where you need infrared lights of typically infrared LEDs.If you can get more infrared leds towards your objects will be better.Or you can buy infrared lamps with independent power and similar to the ones you place on your front yard.I've tried it and it works.
Oct 27, 2010 | Logitech Security Surveillance Camera...
My remote no longer works power on/off or volume on my LG 50 PC 30 plana flat screen. New batts, no obstructions. Help!?
Assuming the batteries are good and installed properly, you can view the Infrared output of the remote with any video camera that has night-vision mode.
Goto a camera shop with video cameras on display, set the unit to nightshot/night vision, and look at the front of the remote while pushing the buttons. You should see flashing from the unit, as the infrared LEDs are very bright.
If you see no flashing, then you likely will need to purchase a replacement remote.
Oct 21, 2009 | LG 42LC2D 42 in. LCD HDTV
CAMERA GOES TO BLACK & WHITE A HOUR AFTER RESETTING POWER ON IT A
The SSC-CD73V and SSC-CD73VT cameras
offer a “Day/Night” function to provide
optimized sensitivity in both day and night
shooting scenarios. As the scene illumination
reduces and the acquired image darkens, the
infrared cut filter is automatically removed and
the camera switches to B/W mode, requiring
only a minimum illumination of 0.2 lx.
Incorporating an optimized lens for the
“Day/Night” function, the camera can produce a
clear and crisp image under normal illumination
or when used with near IR illuminators. In
addition, “Day/Night” modes can be
automatically switched, or manually initiated on
demand through an external control signal.
Apr 21, 2009 | Sony SSC-CD73V Color Mini Fixed Dome...
Vtech VM321 Video Baby Monitor 1 Camera Communications Safe & Logo
518 people viewed this question
Top Vtech Baby Gear Experts
Dorel UK
Dorel UK
Are you a Vtech Baby Gear Expert? Answer questions, earn points and help others
