Question about Lands Phones
When my telephone rings, it doesn't show the call ID, however it did it the past. Caller ID shows up on all my other phones. also I also have a new battery.
I have unplugged the phone from the wall for several minutes and plugged it back in. I don't have my manual, but there should be a simple solution for this problem.
  • 693 Answers
Some networks don't always display on caller Id but it is an idea to check with your supplier to see if it is switched on from their end.
Posted on Nov 28, 2014
  • 65 Answers
SOURCE: caller id
Some phones are not equiped to pick up call waiting caller id. check the box or look up your model number on the uniden site. The call waiting caller id only shows up on the phone that is in use at the time of the call.
Posted on Feb 02, 2008
  • 65 Answers
SOURCE: Caller Id does not always show up
call panasonic 1-800-211-7262
Posted on Feb 05, 2008
SOURCE: Caller ID Stopped Working - Think the phone needs to be reset?
Not sure why this worked, but I went to the Menu and the Set Area Code selection. The area code setting was blank, so I entered my area code and saved it. Caller ID started to work again. As a test, I went back to the Set Area Code selection and deleted the area code and saved it. It is currently still working. Seems really odd, but it worked for me.
Posted on Feb 24, 2008
SOURCE: Philips CD240 cordless phone
need manual for philips cordless phone CD 240
thank you
degs
Posted on Aug 29, 2008
SOURCE: Uniden CXA15198 not showing caller id
Had a similar issue with a brand new DECT2035 uniden phone, displaying incoming call not caller ID.
Checked my old uniden phone, and it was receiving CID. So I connected my DECT2035 to that line and then lo and behold I got my CID.
After further investigation I found that CID on my dect phone wont work if its using a shared filter (ie. adsl/phone splitter). Had to find an unfiltered splitter and then just put a phone filter (that I got with my adsl modem) onto the line that is directly connecting the phone. and then WOOHOO I have caller ID.
Hope this helps you... I got my wife a little cranky over this one cos it took me over an hour and a half to try and sus this one out =)
Posted on Apr 30, 2009
My Uniden 8055 is shoingno caller id when I ring my mobile phone, how do I make it show caller id on all outgoing calls?
Try this .go to menu,then settings , then call settings ,then press' Show caller Id.'I hope this works for you .
Feb 09, 2015 | Uniden DECT 6.0 Cordless Phone ID
My new Hp Officejet j3680 caller ID is not working... All the phones in the house display the incoming phone numbers except the j3680. I wonder why?!! it shows instead ringing!!!
The caller ID phone having the tip & ring detection circuit to detect the incoming phone number, but in this model doesn't have tip & ring detection circuit to display other phone number but after connecting the other fax it will read the information which was stored like company name & phone number of other one..
Jan 04, 2012 | HP J3680 Officejet All In One Printer
On my Uniden Cordless Tru9380 Series phone, how do I use caller ID ? please give deailed instructions as I've had it for 4 days & still cannot figure out how to do it. Help will be greatly...
Caller ID with Call Waiting is available by subscription from your Telephone provider. With this service, you will be able to view incoming caller information while on a call with another user.
This will allow you the ability to select to talk to this user and put your existing party on hold or make the decision to ring them back.
But, you must contact your Telephone provider and subscribe to the service.
Here is the link for the User Guide: http://www.uniden.com/pdf/TRU9380-4om.pdf
Remember, If you subscribe to Caller ID from your phone company, your phone will show you the caller's phone number and name (if available) whenever a call comes in. If you subscribe to both Call Waiting and Caller ID, the phone also shows you the name and the number of any call that comes in while you're on the line.
Jan 15, 2011 | Uniden Cell Phones
No caller ID. TP company says I have service.
  • Did you fully charge your phone? - Make sure you fully charge for 16-24 hours .
  • Is the battery old? - Replace the battery.
  • Is the electrical outlet switch turned on? - If you are using AC (electrical) power, make sure that the unit is connected to a non-switched electrical outlet.
  • Are the connecting wires tight - Unplug the AC power converter from the unit and plug it back in.
  • Do you have Caller ID service with your telephone company - In order to receive Caller ID records, you must subscribe to the standard name and number Caller ID service available through your local telephone company. If the Caller ID works for normal calls but not on Call waiting calls, then you must contact your phone company to get the combined CID/CW service.
  • Caller ID shows up after second ring - Be sure to wait until the second ring before answering. Caller ID signals comes through after the first ring, if caller pick ups phone too soon Caller ID signal will not be transmitted to the handset.
  • Confirm that caller ID is still working on that particular line by checking another phone on the same line - If Caller ID is not coming through contact your phone company provider.
If this does not fix your problem, contact your authorized Service Center.*
Oct 16, 2010 | Uniden DECT 6.0 Cordless Phone ID
Id caller don't show who ring
If this is a landline (not a mobile phone), you need to subscribe to your provider's Caller ID service to get the details to show on your phone. You can't just buy a phone with caller display and have it working out of the box, sorry.
This is how it works in the UK anyway, I don't know about other countries.
Apr 25, 2010 | Panasonic 5.8GHz Cordless Telephone
Lucent Partner 18D - Caller ID not working
The caller id information is sent from your local telco provider after the first ring and might not be able to be extended to the individual sets, try backing off the ring to answer on your voice mail from 2 to 3 rings to see if the information is then passed on. The Voice Messaging System message is being sent from the system showing who transfered the call to you. You should also notice that the ring pattern when that message is displayed is a standard ring followed by a beep meaning a transfer is taking place.
Nov 20, 2009 | Lucent PARTNER18 Corded Phone
Caller id not working, called tele ph comp they said to change batt, have base unit with one in other room, base one and two not showing caller id, the batt are showing full.
Caller ID information is passed between the first and second rings.
Try connecting a regular corded telephone or a standalone Caller ID box. Does Caller ID information show up?
If you have multiple telephones (I don't mean a single cordless telephone base with multiple handsets) and none of them are showing Caller ID after 3 rings it would appear that the telephone company does not have Caller ID turned on for your telephone line.
Oct 29, 2008 | Lands Phones
Caller id
Feb 01, 2008 | Uniden TRU9480 Cordless Telephone
Caller ID
Even at its factory defaults your Siemens handset should be showing the caller id after the second ring. Look at your time and date on the phone, if they are not accurate then the caller id signal is not coming through since when activated caller id will not only give you the caller information, but it syncs with the telephone companys clock too. If I were there, I would take a phone that is known to have its caller id working and plug it in your line and see if caller id shows up on it. If it does show caller id, then there is something wrong with your Siemens base. If it does not, then your phone company dropped the ball and caller id is not activated. Then I would take the Siemens phone to another line (neighbor or friend) that has working caller id and plug my Siemens into it and see if it shows up. Doing all that will isolate your problem, I guarantee it.
Jan 23, 2008 | Siemens Gigaset 4200 Cordless Expansion...
Lands Phones Logo
Top Lands Phones Experts
Computer Repairing
Computer Repairing
Are you a Lands Phone Expert? Answer questions, earn points and help others
