Question about Ovens
F13 ERR kant turn oven on
I kant turn on oven
    New Friend:
Http://www.shopyourway.com/questions/1063631
Posted on Nov 28, 2014
Have Frigidaire Gas oven FFGF3053LSF. We had a power surge & F13 code came on display. Power restored, clock works, F13 code is gone- but now a DR code comes on when I push bake or broil button
answered on another appliance site..
https://www.justanswer.com/appliance/9dp3z-tyler-i-frigidaire-stove-with-dr-error-code-oven.html
the F13 indicates that you have an EEPROM (Electrically Erasable Programmable Read-Only Memory) error in the clock control board of the range. You can unplug/turn off breaker to the range for 1 minute and then plug/switch it back on. This too may possibly fix the DR.. maybe?!
Feb 12, 2018 | Frigidaire Ovens
What is error code f13?
The F13 fault code on this type of range indicates that the EEPROM (Electrically Erasable Programmable Read-Only Memory) on the control board is bad. This can be caused by a power surge or glitch through the electrical lines. You can try to reset the control board by completely unplugging the range (or shutting off the breaker) for 5 minutes. If the error code returns after plugging the range back in, then the control board for the range will need to be replaced.
Feb 05, 2015 | Thermador C301U Electric Single Oven
How do I turn off f13 beeping
For most codes, Touch OFF or turn power off at the circuit breaker, wait 3 minutes and turn it back on.
Nov 27, 2014 | Thermador C301U Electric Single Oven
Code (numbers/letters) are shown when trying to use oven (F13)
Try shutting the power down for a couple minutes and this may reset the control If it continues then you will need an error code guide to see what is causing the problem. Sometimes there is a little mini manual on the back or inside the control panel. If not you may need to call for service.
Sep 01, 2014 | Kenmore Ovens
F13 code
Hello friend, thank you for your post!
Based off the information you have provided your question is under an "F13" error code but you also stated that it is showing you an "F1" error. I have researched both error codes for you. "F13" usually indicates error identification, which could be an issue within your control board. "F1" typically can indicate that the range has detected an issue with the runaway temperature (overheating). Both codes could be corrected with a reset, which you can do by flipping the household circuit breaker for roughly ten minutes. If that does not correct the issue I would recommend contacting a professional. I hope this is helpful. -Matt
Aug 07, 2014 | Frigidaire Ovens
F13 beeping sound
Turn power off then back on. If F13 comes back, it's an internal problem with the control board. Replace the control board.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jeffrey_634abadf963e31e5
Mar 23, 2014 | Frigidare Ovens
When I try to turn on the oven it say f13 err
Most of the F13 fault codes say it is either the Main board or a temperature sensor.
May 10, 2011 | Ovens
Getting an F13 error message on my stand alone professional series oven smooth top, how can this be corrected?
F13 does indicate you need to replace the electronic oven control. It means EEPROM/ Checksum error. If you have unplugged and it returns, this is a bad control board.
I hope this helps.
Apr 21, 2011 | Ovens
Error Code F13 and door locked
press clear for five seconds if that doesn't work then power down for 30 seconds then on if that doesn't work replace the eoc
Mar 19, 2008 | Frigidaire FEB30S6D Electric Single Oven
Ovens Logo
77 people viewed this question
Top Ovens Experts
ashburton
Craig Butler
Craig Butler
Are you an Oven Expert? Answer questions, earn points and help others
