I cannot remove the agitator from the shaft. I have removed the fabric softener cup and the bolt, and I've practically lifted up the entire washer pulling up on it, but still cannot remove it.
  • 118 Answers
The fact of the matter is the spline on the drive shaft has most likely slightly corroded into the plastic agitator spline. Although the shaft is called stainless steel the grade is not 18/8 so it does contain some iron. This GROWING together might require s =special puller which I have made for myself in these situations. Otherwise if it is imperative that the agitator must be removed, then you will have to break it with difficulty because it is quite tough plastic.
Posted on Nov 28, 2014
jsrock516
  • 5911 Answers
SOURCE: Fabric softener doesn't dispense
Fabric softener dispensers are notorious for getting all gummed up and clogged. Remove the dispenser cup and soak in some hot water to dissolve all residue. While you have the dispenser removed check under the dispenser cap in the agitator for gummy residue as well. Clean with hot water. There should also be an agitator seal cap under the dispenser. Make sure the cap and rubber o-ring are seated properly. Last of all, if the dispenser has a cone shaped cup inside, make sure it is inserted cone-side UP. The cup is designed to allow fabric softener to roll down the sides of it, NOT hold it. I hope this helps.
Posted on Apr 29, 2007
jsrock516
  • 5911 Answers
SOURCE: Agitator Removal
Most agitators also have an air gap cap underneath the fabric softener cap as well. This is to prevent water from rising inside the agitator and getting to the drum bearings. Look closely under the fabric softener cap to see if there is another cap that you might have to remove. You can usually use a small flat tip screwdriver to lift the cap off. You will need a socket (with extender) and ratchet to reach the mounting bolt. As you loosen the bolt, you will need to hold on to the base of the agitator at the same time to keep it from turning. Now, not knowing what your agitator looks like, it may or may not have this set up (just a thought for you try). If there is no mounting bolt of any kind as you say, the type of agitator you may have is held on by plastic grips that snap on to a mounting hub under the base. Unfortunately there is no easy way I know of besides lifting straight out. You may have to rock it side to side a little while pulling up to get the clips to release. Normally, the problem encountered with this type of agitator is the clips wear out and no longer grip and it keeps falling off. Why do you need to remove the agitator? Just wondering because you didn't mention any problems. Good luck to you. I hope this helps.
Posted on Jul 01, 2007
dididsaythat
  • 291 Answers
SOURCE: Maytag SAV365ZAWW Agitator Comes Apart
The should be a bolt that goes thu the center that holds that down with the bottom part of the agiatator.. it might have pulled loose or rounded out the whole for the top part here is a link and a pic http://www3.sears.com/imaging/ImagePageJava.shtml?productTypeID=0153200&brandID=3048&modelDesc=WASHER&modelNumber=SAV365ZAWW&documentID=M0512408&documentTypeID=PLDM&documentClassCode=PV&titleType=TUB%2C%20INNER%20%26%20OUTER%20%28SERIES%2012%29&titleID=00010&
Posted on Sep 20, 2007
the dr
  • 447 Answers
SOURCE: Maytag washer fabric softener dispenser is yucky
There is a 1/4" machine screw in a recessed hole close to the bottom of the agitator. Remove screw. Lift agitator off agitate shaft.
Posted on Nov 28, 2007
SOURCE: GE washer WWSR3090T6WW
I DONT KNOW HOW TO REMOVE MY AGITATOR PARTS TO PUT IN THE NYLON COUPLING I GOT THE TOP PART OFF BUT THATS THE ONLY PART COMES OFF
Posted on Oct 14, 2008
I have a Maytag Washer Model LAT9206BAE, I have cleaned the washer but my clothes are still getting a lint like substance on them. Is there a screen or something on the discharge that may be blocked.
There is no filter. You may have something that is hung up under the agitator. To remove the agitator, remove the fabric softener cup, then the bolt that holds the agitator on and lift the agitator out.
Nov 22, 2012 | Maytag Washing Machines
I have a sheet stuck under the agitator of my GE gtwn3000mws. I've tried to use leverage to brute force the agitator out and it was a no go. Then I took off the top cup looking for the bolt to r
Remove the fabric softener cup, remove the plastic insert, then there is a 7/16th bolt you need to remove and the agitator will lift out.
Here is a diagram of the tub assembly.
Regards,
Richard Roth
http://appliancecafe.com
Nov 13, 2012 | GE GTWN3000MWS Washer
How do i replace the agitator in my old heavy duty whirlpool washing machone?
Hello.
The Whirlpool Ultimate Care II washing machine is atop-loading clothes washer. The washer has several cycles to choose from,including cycles for washing normal clothes, permanent press items, delicateand items marked "Hand Wash." To do its job, thewashing machine relies on an agitator, located in the center of the wash tub.The agitator rotates during the wash cycle, moving the clothes around the washtub so that they are cleaned equally. If the agitator is broken, it will notsufficiently agitate the clothes and must be replaced. ·1 Unplug the washing machine from the wall outlet or turn off the power supplyin your service panel. · 2 Open thewashing machine lid and remove any clothes remaining inside. · 3 Remove thefabric softener cup by squeezing the bottom lip of the cup and lifting itstraight off. · 4 Pry theagitator cap off of the top of the agitator with a flat-head screwdriver. · 5 Remove thebolt at the bottom of the agitator, using the socket wrench with extension, andthen remove the agitator from the washing machine. Tip the agitator to removethe bolt and washer. · 6 Install thenew agitator onto the drive shaft. · 7 Secure thenew agitator with the bolt that you originally removed. · 8 Press theagitator cap and fabric softener cup back into position on top of the newagitator. · 9 Restore powerto the washing machine to complete the repair.
Thanks.
Sep 07, 2011 | Whirlpool Washing Machines
HOW DO i REMOVE THE AGITATOR FROM maYTAG WASHER MODEL # MAV6457AWW
Gently remove the fabric softener cup off of the top of the agitator
Using a ratchet, an extension and socket; then remove the retaining bolt under the fabric softener cup.
The agitator will lift off after the bolt is removed.
Installation is:
Drop the agitator in place. Install bolt.... tighten bolt with ratchet, extension and socket. Install the fabric softener cup.
Fabric softener cup is item 14 this link:
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5170378&diagram_id=28464917#d28464917
The bolt you need to remove is item 4 of the above link.
Thanks for choosing FixYa,
Kelly
Feb 05, 2011 | Maytag MAV6457 Top Load Washer
Maytag Washer Model SAV405DEWW How do I remove the agitator from its shaft. It lifts only about 1/4 inch and then stops.
If you remove the fabric softener cap (just twists off ) their is a bolt securing the agitator to the the transmission,sometimes even after removing this bolt it can be tight on the shaft.. try slipping a belt under the agitator and grab from each side which gives you more to grab a hold of and pull straight up... Hope this helps....
Sep 21, 2010 | Maytag Washing Machines
Cant remove agitator. Fabric softener cap is off but i do not see a screw or bolt to remove the assembly. agitator is only weakly working
There should be a 7/16 bolt in the bottom of the cup once you have taken the cup out. Its kinda deep you would need a longer extension. Also this agitator bolt usually has a gasket material attached to it and it may be covered by another cap.
Apr 17, 2009 | Kenmore 22422 Top Load Washer
Top of agitator comes off in washer
#15... There's a bolt in there. Lift the fabric softener to access it.
SG
Feb 09, 2009 | Maytag SAV4655A Top Load Washer
Gunk in middle of agitator
the fabric softener spins out of the cup after the wash cycle when spinning the water out of clothes, then the washer fills back up for the rinse w/ your softener having been dispensed. is there a nut at the bottom of your agitator where you see the gunk? If so you can take the agitator out by removing the nut but be careful of the little parts that make the agitator agitate. Do not disturb these little parts if you don't know about them. Does the gunk smell like grease or a mechanics garage? If so chances are it is a lubricant and should not be removed replace the cap and your softener cup and continue enjoying your machine.
Jan 05, 2009 | Kenmore 98702 Stacked Washer/Dryer
How do I remove Kitchenaid Washing machine agitator?
with the palm orhte heel of yuor hand smack the top of agitaor, hte fabric softener cup will release.it doenst seperate to clen any furthetr though reccommnd soaking in hot water to clean out. reach down and pull up the opaque cover from the center of agitatr and there you will fond a 7/16 bolt holding the agitator to the tranny shaft. remove bolt adn PULL up
Mar 10, 2008 | KitchenAid KAWS750L Top Load Washer
Nov 28, 2007 | Washing Machines
Washing Machines Logo
35 people viewed this question
Top Washing Machines Experts
