Question about Cfm Klimaire KSWG009H113 Split System Air Conditioner
What is error code H4
I shut the power off for a few seconds and the heat began functioning for a few seconds and then shut down again with H4 error code
  • 27 Answers
Hi don the error code is a system overload. There are a lot of things that could be causing this temperature short circuit. Inwould take the cover of the unit and see if you can visually see any maybe dust or debri on any condenser coils or fans. If you can't figure it out call an expert.
Here is a link to the manual for your system
http://www.supco.com/images/Seabreeze/New%20Material%202011/NEW%20MULTI-ZONE%20INSTALL%20MANUAL%2012-10.pdf
Posted on Nov 28, 2014
Canon IRC2620 Error Code E000001-0004
This is standard error code for Canon and the fuser unit. The error can be reset by being ready to go into service mode quickly. First press the additional function button, then the 2 & 8 keys at the same time and then the additional function key again. The display should change to the service mode screen, indicating " COPIER " and other accessories. Press " COPIER " then accross the top you should see a menu and select "FUNCTION" then select " CLEAR", then " ERR ", then " OK." This will clear the error from the copiers memory. Turn off the main power switch, wait a few seconds, then turn the copier back on. If you continue to have this error you will have to replace the fixing assembly and if it is similiar to the IRC3220 then you ahve only two screws to remove and the whole unit comes out. You will be saving a service call and I do believe the fuser is over $500. I usually don' tknow the prices of items until I have to do a quote for a customer. Good Luck.
Sep 04, 2012 | Canon imageRUNNER C3200 Copier
ERROR CODE E000004-0001 IN 8070IR COPIER
This is error given by the thermistors in the fuser. Not detecting a temp change or too much temp difference between the thermistor ( front edge and Middle ). You can reset it by going into service mode. Press additional functions, then 2 and 8 at the same time, then additional functions. Press copier, then function at the top of the display, CLEAR, then ERR, then OK. Power down the copier using main power switch. Wait a few seconds then power up again. If the error continues then you will have to have the thermistors replaced if the heater is working. The heater should give an E000 code if not heating up.
Jun 09, 2011 | Canon imageRUNNER 5000 Copier
H4 Displays
H4 indicates "low temperature", possibly caused by a failure of the heater lamp or fuser. Sometimes this error is shown without an actual damage when the power cord is pulled without shutting down the copier first.
To cancel the error code, press [CLEAR], [AUTO], [CLEAR], [AUTO] in rapid succession. The display should go blank. Next, select 14 (clear low temperature code), press [START]. Finally, switch off and on the machine.
If there was no actual damage (i.e. power cord pulled), the machine should be OK again. If the error persists, immediately or after short time of operation, you will need to contact Sharp technical service for repair.
Jan 10, 2011 | Sharp AR-5316 Advanced Digital Imager...
The copier displays H4 What is the solution?
Jan 09, 2011 | Sharp AR-5316 Advanced Digital Imager...
Error h4 sharp ar-5316 can you help me ?
Jan 08, 2011 | Sharp AR-5316 Advanced Digital Imager...
Our copier is an AR-208D & it has a error code of H4-00 displayed. Can we fix it?
In most cases the flashing H4 or H then 4 code on these machines is caused by voltage fluctuations or surges. Normally there is nothing wrong with the machine and the code is easily reset. Here is the procedure:
Press the following key's in sequence and as quickly as possible (with 4 seconds for the first 4 keys)
Press "#" then the " * " (star) key then the "Clear" key then the " * " key again.
So in other words #, star, C, Star
If done correctly the display should go blank.
Then key in 14 as if you were going to make 14 copies.
Now press the "print" button
The machine should automatically shut down and restart with the H4 code being gone.
If the H4 code comes back after reset then in this case you have a fusing unit problem and will need to have the unit serviced.
Good Luck and Thank You for using Fixya.
WheatlandServices
Dec 22, 2010 | Sharp AR208D Copier
Sharp a163 photocopier ero u2 40 and h4
U2 40 is a CRUM comunication error with the toner (wrong toner chip on toner cartridge or wrong toner cartridge) try a new toner.
H4 is a fuser trouble code. Check to make sure all conection are right, Theres a few posible problems for H4, power board, MCU board, thermistor, or broken heat lamp.
Aug 30, 2010 | Sharp AR-160 Copier
Error code H4-01
This mean you have low temp. on heat lamp 2 program interput clear interrupt 14 print may clear this code. if not you can look at the fusing unit and reset thrmo breaker that may be pop off.
Jul 26, 2008 | Sharp AR-C160 Color Copier
H4 error code
H4 is a Fuser Unit heating problem.
This reset is for another model sharp, see if it will work for you.
Press "Clear", "Auto Exposuer", "Clear", "Auto Exposure", the display will go dead... then press "14" (Like your going to make 14 copies), then press "Start".
Hope this works.
Good luck,
Mac
Feb 10, 2008 | Sharp AL-1551CS Printer
H4 error code
H4 codes are related to the fusing unit. Specifically a low heat condition. Follow the reset procedure below. If that doesn't work further diagnosis of the fusing unit an peripherial circuits may be warranted.
Error code reset:
Perform the following key procedure
"#" key, Interrupt key, "C" key, Interrupt key
"1" key, "4"key
Start key, "CA" key.
See if unit cycles and comes back up. If not turn off and then back on the main power.
If error reappears on site technical service may be required.
Jan 06, 2008 | Sharp AR-5320 Black and White Copier
Cfm Klimaire KSWG009H113 Split System Air Conditioner Logo
234 people viewed this question
Top Cfm Heating & Cooling Experts
Dan Webster
Dan Webster
David Payne
David Payne
Donni Steen
Are you a Cfm Heating and Cooling Expert? Answer questions, earn points and help others
