Question about Frigidaire Affinity ATF6000ES 3.5 Cu. Ft. I.E.C. Front Loading Washer
<!-- from fixya rte -->Washer holding water in tub - Frigidaire Affinity ATF6000ES 3.5 Cu. Ft. I.E.C. Front Loading Washer
  • 693 Answers
Check the rinse hold has not been accidentally pressed . If not then you need to drain from the bottom plug and check penny trap.if that's clear it may be the pump or hoses that have clogged or failed.reset machine to off and try selecting spin only.
Posted on Nov 28, 2014
Water leaks from the machine tub while it is in the wash cycle or turned off with water in the tub. I can empty the tub using the spin cycle without any leaking
you have bad tub seals. is there stains on the walls inside the washer and the water is leaking in the middle bottom of the tub?if the washer is old get a new washer,did one last week but the washer was in good condition it was close to 300 bucks.you have to pull the agitator,remove the top ring,with a spanning tool you need to remove the center parts and pull the inner and outer tubs and the three nuts and bolts holding the outside tub on and replace the two pieces in the middle it's a bearing and a seal kit,but you need the tools to do it,like i said if the washer is old replace it or call someone in to do the job for you
Aug 25, 2010 | Kenmore 24032\24036 Top Load Washer
We have a GE front load washer WCVH6800. Recently we loaded some throw rugs into the washer. These rugs released a large amount of material. We cleaned the pump filter 3 times and it now seems clean. ...
The water inside the tub will drain out when the pump filter is removed from the pump housing and flood the base of the washer. If not, the tub drain hose is clogged preventing the water to drain into the pump housing then out.
The door is locked because the foam switch in the pressure switch is open due to the presence of water after the unsuccessful drain cycle.
Disconnect the washer from the power outlet. Remove the three screws holding the lower front access panel to the cabinet and pull the panel down to access the pump housing.
Squeeze the clamp that hold the tub drain hose to the pump housing and slide it back. Prepare a pan to catch the water to prevent flooding. The tub drain hose maybe difficult to remove and you may need to insert something under it to break the seal and pull it off.
Remove the tub drain hose from the tub by squeezing the securing clamp and pulling it off the tub drain outlet. Clear the hose and the tub drain outlet from any debris.
Reinstall the tub drain hose and manually unlock the door before reinstalling the access panel. Reach and pull the release ring behind and up the right side of the front panel, then open the door.
Feb 14, 2010 | Dryers
Washer will not hold water
You need to check drain hose, the drain hose needs to be above the tub. If it isn't the water will just drain out when you fill
Jan 12, 2010 | Washing Machines
Water doesn't drain when spinning in rinse cycle.
Check these:
  • If your washer spins but does not pump the water out, the drain line is probably clogged. In many washers a small sock or other piece of clothing can get between the clothes tub and the outer tub that holds the water. If the clothing gets between the tubs, it may then get into the drain hose that is attached to the pump or even into the pump itself. It it's in the pump, you need to remove the hoses from the pump and pull the item out.
  • To remove the item from the outer tub port, open the washer's main access panel and remove the large diameter rubber hose that connects the pump to the bottom of the outer tub. Using a needle-nose pliers, try to grab and remove the stuck item through the port.
  • Check your washer for a frozen pulley. Remove the pump from the washer and try to rotate the pulley manually. If it doesn't turn freely, it's frozen, replace it.
  • If the water that pumps out of the machine goes back after the spin cycle, your washer is siphoning the water from a laundry tub that has a slow drain back into the washer. The usual remedy for this is to improve the draining of the laundry tub.
  • Also check for these problems:
  1. If the drain hose reaches more than 4 inches into the laundry tub, cut the excess.
  2. If your drain hose is lower than the washer's cabinet, install an air gap/siphon break assembly.
Oct 27, 2009 | Maytag Washing Machines
WASHER FILLS UP THEN DRAINS WATER OUT. WILL NOT HOLD WQTER. TUB PROBLEM?
If you do not have water on the floor under the washer, then your tub is fine. You could have a drain solenoid valve problem.
Oct 25, 2009 | Hotpoint WMA64 Front Load Washer
The washer's springs configuration
They are hooked from the bottom frame to the carriage that holds the tub. Not sure of the model you have but most Whirlpool (They make kenmore, roper, magic chef and others) There is a ring around the top of the outer tub that is filled with water from the factory. Make sure it still has water inside. It acts as a damper helping to balanced the tub also.
Oct 13, 2009 | Roper Washing Machines
Not draining water away
Check these:
Sep 07, 2009 | Zanussi Washing Machines
The water will not drain out of the washer
Check these out:
Aug 22, 2009 | Frigidaire GLTF2940E Gallery 3.5 Cu. Ft....
Neptune washer tangles all cloths
the washer has a balance ring that hold water that is ok. as of the tangleing you may have a low water fill
Nov 24, 2008 | Maytag Neptune MAH5500B Front Load Washer
Frigidaire Affinity ATF6000ES 3.5 Cu. Ft. I.E.C. Front Loading Washer Logo
32 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
