Question about Kenmore Kitchen Ranges
Kenmore electric oven is very slow to get up to temperature. What is wrong?
It takes more than an hour to get up to 350 degrees.
    Problem Solver:
  • 18 Answers
Depending on how old it is the coil element could be damaged. also check with an oven thermometor that the temp is what the pad says.
Posted on Nov 28, 2014
SOURCE: GE Spectra XL Oven does not maintain oven temperature
I have the exact problem. We had the ignitor replaced 2 already and it works for 18 months and stops. Occasionally, it the oven won't even start to heat. I am ready to throw it out.
Posted on Sep 18, 2007
fridgetech
  • 473 Answers
SOURCE: oven slow to heat
In alot of ovens preheat will cause the both the broil and bake element to come on. You are most likely getting heat from the broil element. This means either the bake element is bad or the relay on the oven control is bad. If the element shows resistance with an ohm meter then replace the oven control board.
Posted on Oct 06, 2007
fridgetech
  • 473 Answers
SOURCE: bake part of kenmore not working seems to take to long
Chances are the oven ignitor will need to be replaced.  Look and see if it glows.  If it does then it is weak and not opening the gas valve to lite.  Let me know what you find.
Comment by fridgetech, posted on Oct 20, 2007
Should be able to remove the bottom drawer and unplug the ignitor from below.  Or you can cut the wires on the old ignitor and splice the new one in using ceramic
Posted on Oct 20, 2007
MNTECH
  • 1543 Answers
SOURCE: Oven takes a long time to preheat
You don't list a full model number or how old this range is, or how long / how often you have this problem, but generally it sounds like the oven ignitor is not quite drawing enough amps to allow the gas valve to open regularly. It could be a low voltage related issue, but most likely is a failing oven ignitor. ( WB2X9154)
Posted on Sep 04, 2008
RescueTech
  • 145 Answers
An extremely common problem on these models is a weak silicon carbide ignitor. You may be able to see the ignitor glowing, but that is not an indicator of it being functional or not. When the ignitor gets "weak" over time, it will not create enough amperage in the circuit for the gas valve to open. You can test this using an amprobe around one of the ignitor leads and looking for at least 2.9 amps, but years of working on these appliances has shown that if you are getting the glow from the ignition but the oven is often slow to come on, you need a new ignitor. Do-it-yourselfers often mistakenly replace the oven valve or the oven temp sensor, figuring the ignitor must be good because they can see it glowing.
Replace the ignitor and your oven will work great again.
Posted on Dec 14, 2008
Oven temp fluctuates
It is normal for the thermal device to turn on and off. Obtaining a steady temp is not always possible. When setting a temperature on some ovens, they have what is called a tolerance point. That means a set temperature has a range of a few degrees up or down. At the Down point, the oven is triggered to energize the coils and bring the interior of the oven back to the settings desired. The other factor is opening the oven and allowing cool air to enter, or in some cases a leaking door seal allows air to enter and heat to escape.
Feb 26, 2014 | Kenmore 30" Slide-In Electric Range...
Oven does not maintain a consistent temperature
Is this oven gas or electric? If it is gas then it can be normal to see 30 to 50 degrees difference in tempature. The tempature in a gas oven works on the average tempature. For example: The oven tempature may rise all the way up to 370 degrees. Then the burner will shut off. And then the tempature can drop all the way to 330 degrees. Then take 330 and add that to 370 then divide that number by two and the average tempature will be 350. If your oven is electric then the tempature should be much more consistant but can have a 10 to 15 degree variance. Also the standard oven tempature guage that you put in the oven or even the temp guage built into the oven are not very accurate. We us a Fluke meter with a thermocouple to calibrate an oven. So to check your oven for proper tempature regulation you will first need to let the oven pre-heat for about 15 minutes. Then place the thermocouple in the center of the oven. If the oven is electric the take a temp reading every 5 minutes and average them out. If the oven is gas then you will need to take a temp reading when the tempature reaches it's highest and lowest points. Take at least 5 consectutive readings and average them out. You should get an average within 10 degrees of set temp(350 degrees). If it is off by 35 degrees or less you can usually caluibrate the thermostat back to proper temp. This procedure can be different for each range model. If it is more than 35 degrees off or you are getting irratic readings then the thermostat or thermostat components might need to be replaced.
Mar 16, 2010 | Kitchen Ranges
Digital oven temperate is wrong
Yes, that is the probe that sends info to the controller.
If it's not bad, then the controller is, but normally it's the probe.
Check that the controller has not been incorrectly calibrated before you change the probe out, although most do not allow a swing of more than 15-20 degrees. Yours may allow more though.
I am guessing you measured the actual temperature, to the set point temperature, with a know good thermometer.
Jan 30, 2009 | Frigidaire FGB24S5A Gas Single Oven
Oven heats to 200 and indicator dings
Try to set it at 500 degrees and see if it goes off at 350. If it does, then it probably needs calibrating. You can calibrate it by taking the knob off and finding a set screw in the stem where the knob sits. If this is not the problem, you may have to replace the thermostat. By the way, check to see if your temperature probe is not touching the wall of the oven. It will give it a false reading. Let me know if any of these things work and we will go from there.
Jan 29, 2009 | Whirlpool RBS245PDS Electric Single Oven
Oven won't reach proper temperature and hold
If the element glows its ok , if you have replaced the sensor with a new one it can only be the control board. in some cases you can adjust the temp. through the control , it should list directions to do so in the manual. Good luck
Dec 30, 2008 | Kenmore 91112 / 91114 / 91117 Electric...
Sears Kenmore Electric Wall OVen, Mod.#9114012192 purchased in 1993. Set oven for 425 degrees, reaches set temperature, stays on about 10 minutes and temp. display goes out and oven starts cooling down. Will not stay on desired temp.to cook. Can you tell me what my problem is? Thanks. Doug.
Dec 02, 2007 | Ovens
Slow warm up
hi petrich let me know if you had your voltage to the oven checked. is must be the problem to have two ovens slow to heat up... let me know..krazytech
Aug 25, 2007 | Elan E-948-DB / E-948-DW / E-948-DS...
Kenmore oven - Not heating up
Check the BACK of your temperature knob for an adjustment. I was ready to replace my heating elements when I accidently discovered the adjustment. Made the adjustment and no more problems. My oven now stays within 4 degrees of settings.
Aug 25, 2007 | Equipex PZ-330 Electric Single Oven
Kitchen Ranges Logo
196 people viewed this question
Top Kenmore Kitchen Ranges Experts
Dan Webster
Dan Webster
Sal De
Are you a Kenmore Kitchen Range Expert? Answer questions, earn points and help others
