Question about Yaesu Radio Communications
Can you connect a siris or Delphic this to a yaesu transceiver
I'm trying to get yaesu transceiver to work I don't have the back part so I'm wondering if I connect it to my Delphi or my sirus will that work
    Problem Solver:
  • 18 Answers
Most yaesu transceivers are not capable of tunning the wide band FM broadcast band needed to hook up sirus or delphi satellite radio
Posted on Dec 01, 2014
SOURCE: my transceiver yaesu ft-one can't received/monitor and transmit
Thanks 4 your advice.
I left the radio w/o any batteries (the only battery is back up memory battery) in that time, and when I try the radio I used new batteries. The power supply for the radio is build in (uses 30 amperes switching power supply) and I have checked that the power supply is in a good condition. I suspect that PLL unit is not working so can't oscillation to generate frequencies.
The problem with sending the unit to the factory to be serviced is not worth (cost > benefit/ radio value).
Do you have another idea to help me? Please.. Thanks
Posted on Nov 06, 2008
  • 19 Answers
SOURCE: Hi I am looking for a english version of the user
Hi Tam, I think you should try trade me, I presume you have tried Google? if not just put your requirements in, you should get a response that way.
Posted on May 02, 2009
  • 120 Answers
SOURCE: Reinstating Yaesu 707 transceiver to original 100watt output
check the resistor values around the finals and also around the stage that drives the finals and see if they differ from the schematic values.
Posted on Jun 03, 2009
  • 21 Answers
SOURCE: YAESU VHF AM Transceiver VXA-100 battery doesn't
If this charger is one that plugs into the radio then you will have to take a volt meter and check the voltage on the plug. It should be close or slightly higher in voltage than the label on the power supply.
It most likely be that the transformer or the contacts in the plug are bad.
You could try and turn on the radio with the battery on and see if the radio comes on.
Posted on Oct 11, 2009
I have a Yaesu FT 101z HF Transceiver - whilst listening to a QSO the signal strength needle went off the scale and the sound went - after a few minutes the sound came back and then went again
It sounds like your RF GAIN control either needs some DEOXIT sprayed in, or replaced. Try turning the RF gain control when this happens and see if the signal returns. If it does, then live with it or try and find a replacement control. Also, you might want to try cleaning the plug in circuit board pins with a pink or drafting eraser. They do oxidize over time and the connections can get noisy.
Jun 24, 2017 | Yaesu Radio Communications
Radio power`s on but no transmit or receive on ssb however it will transmit with full power on fm
If your receiver was operating previously but now the SSB option is not working, very likely the sideband detector has failed. I'm not directly familiar with your Yaesu unit but, in most Yaesu transceivers, the SSB chip and control circuit (including diodes) is identified in print on the main board.
May 16, 2015 | Yaesu FT-990 DC Transceiver
How to reset yaesu vx300 vhf radio transceiver
While turning on the device,at the same time push another button.One of the other buttons should re set the Yaesu.
Oct 10, 2014 | Yaesu Radio Communications
I need a pdf of the manual, where can I get it?
www.manualslib.com > Brands > YAESU Manuals > Transceiver > VX-8DR I found one at the above site.
Jul 19, 2014 | Yaesu Quad-Band VX-8DR Submersible VHF/UHF...
Yaesu service manual
The external VFOs for the FT400/401/560/570 (ie "F line" transceivers) are all fairly similar.
Fox-Tango manuals library
http://www.foxtango.org/ft-library/FT-Library/60s-70s/60s-70s.htm
Look for FV-401 listed under FTdx-400 transceiver
Antique Radios discussion of Yaesu Musen vfo
http://www.antiqueradios.com/forums/viewtopic.php?f=5&t=238656
Dec 15, 2013 | Radio Communications
Software Menu Aligment yaesu FT-857
http://www.hampedia.net/yaesu/ft-857-second-menu.php this link lists the settings to put back to factory abc together when switching on to access
Apr 10, 2013 | Yaesu FT-857D HF/VHF/UHF Mobile...
Yaesu FT-857D transceiver
Nice rig, what's the question?
Aug 09, 2012 | Yaesu FT-857D transceiver
May 29, 2009 | Yaesu POWEREX MH-C500Y Charger for FRS...
Yaesu Ft 2200 transceiver operators manual
Found a couple of ham radio sites that had manuals for sale or free downloads. Took several hours on net to find but it worked. had at lest 3 responses in 24 hr period of time.
thanks for yur help.
Mar 27, 2009 | Computers & Internet
Radio Communications Logo
Top Yaesu Radio Communications Experts
Steve
eradiostore
eradiostore
Nyte_Ryder
Are you a Yaesu Radio Communication Expert? Answer questions, earn points and help others
