How do i add a new remote to my system - Televison & Video
    Sergeant:
  • 245 Answers
All u need to take the old remote to the remote vendor !
He will match the internal cosing and give u a new piece !
Take it to your home
It will work as your previous remote !
Regards
Posted on Nov 28, 2014
Bose solo sound system
Does the Bose remote work at all? New batteries may fix the problem. Logitech Harmony universal home theater remote and app This the best remote control you can ever have for your system. It is amazing. No need to look up codes since the remote is programmed all at once for every component you have and it's done online at their website. Want to change or add a new component? No problem....just log back on to their web site and edit your settings.
Sep 07, 2016 | Bose Solo TV sound system - Black
Why is my circuit board showing KO when trying to add new remotes
It means that it has not programmed your new remote ie not compatable with your system or damaged hope this helps
Mar 03, 2016 | BFT R93524500001 - Swing Gate Kit, Single,...
How do I reprogram my key bob
Remote Programming Troubleshooting Guide - Compustar
https://support.compustar.com/.../202839770-Remote-Programming-Tro...
How do I add/remove a DroneMobile unit from my account? ... (Do not start the engine, simply move the key to the final position before start); Immediately following the key ... Holding the button down will cause the remote programming to fail.
How do I program a remote to a Compustar system ...
https://support.compustar.com/.../202232840-How-do-I-program-a-rem...
How do I add/remove a DroneMobile unit from my account? ... Insert your vehicle keyinto the ignition and cycle the key to the 'ON' position and back ... Valet mode will be activated if the system does not identify a remote during programming.
Programing a Compustar 1Way 4 Button Remote - YouTube
Jan 12, 2016 | Vehicle Remote Starter and Security Kit
Need program to add additional key fob to my Python 474P model on a 2005 Kia Sportage
To program additonal remote; open door, turn ignition on. Press and release valet button one time then, press and hold valet button. While holding valet button, press lock button on new remote. Turn ignition off. Test system.
Sep 29, 2012 | Remote Start System
I have a 1990 Wayne Dalton opener with remote control model 61wd. it uses rolling codes. Everytime i try to add a my new KLIK1U univeral remote controller, the original controller quits working. When I...
The system is limited in the number of openers it can store. Usually 3 though I don't know about your model..
You need to clear all stored openers, and then re-add what you want to use. If there are 4 or more it will not work.. The last one entered will be replaced by the new one. (What you're getting now)
Usually to clear memory, hold down the program button for ten seconds or so.
Wait a few seconds, start installing your openers.
Good luck
Dec 27, 2010 | Chamberlain Clicker Universal Remote...
Replaced a Dish VIP722 with the new VIP722k,--got new remotes, also have a Bellvu 3100 on same primary TV. Used to be able to use one remote to control either recever boxes. How to I add the 3100 to the...
d1032d_junk3
If you are using the remote to operate an IR frequency, you can program that component to the VCR or AUX button on the new remote. I have provided the instructions on how to program the remote. I hope this helps.
Address To 2nd IR Receiver Using AUX Mode
  • Remote: 3.4, 4.4, 5.3, 5.4, 6.3, 6.4, 20.0, and 21.0
    1. Go to 2nd IR receiver
    2. Go to System Info Screen
    3. Hold down the AUX button until all mode lights light up.
    4. Press 3 then enter a number between 1 and 15 using the numeric keypad on the remote.
    5. Press the pound (#) button
    6. Once the AUX button blinks three times, press record. Note: If successful the number selected in step 4 will appear in the System Info screen under Remote Address.
Ray Calo
DISH Network
Jun 13, 2010 | DISH Network IR Remote Control
Adding a second Harmony
Account migration from a Harmony 1000 to 890 is not suppoted, though it may work.
1. In the software, click on the 'Remote Settings; tab.
2. Click 'Manage Remotes'.
3. Connect the 890 and click 'Replace Remote'.
4. Update the remote.
Like I said this is not supported by Logitech, so if anything goes wrong they may not help you out with it. The saftest way to get your 890 set up is to create a new account.
Apr 14, 2010 | Logitech Harmony 890 LCD Remote Control
How can i program a new remote?
usually viper systems just need program button and ignition key. start by turning key to run then press the program button once then press again and hold. then press lock button of transmitter you want to add, parking lights should flash and then indicating that it is programmed. let go of switch and turn key off. try remote. good luck
Oct 09, 2009 | 5900 SST 2-Way Security System / Remote...
I need a complete workingsource code written in
This is a simple source code for Simple calculator in Java using RMI
//mathServer//
import java.rmi.*;
import java.rmi.Naming.*;
import java.rmi.server.*;
import java.rmi.registry.*;
import java.net.*;
import java.util.*;
interface mathInterface extends Remote
public int add(int a,int b) throws RemoteException;
public int subt(int a,int b) throws RemoteException;
public int mult(int a,int b) throws RemoteException;
public int div(int a,int b) throws RemoteException;
public class mathServer extends UnicastRemoteObject implements
mathInterface
public mathServer() throws RemoteException
System.out.println("Initializing Server");
return(a+b);
return(a-b);
return(a*b);
return(a/b);
public static void main(String args[])
try
mathServer ms=new mathServer();
java.rmi.Naming.rebind("MathServ",ms);
System.out.println("Server Ready");
catch(RemoteException RE)
System.out.println("Remote Server Error:"+ RE.getMessage());
System.exit(0);
catch(MalformedURLException ME)
System.out.println("Invalid URL!!");
//mathClient//
import java.rmi.*;
import java.awt.*;
import java.awt.event.*;
public class mathClient extends Frame implements ActionListener
Button B1=new Button("Sum");
Button B2=new Button("Subtract");
Button B3=new Button("Multiply");
Button B4=new Button("Divide");
Label l1=new Label("Number 1");
Label l2=new Label("Number 2");
Label l3=new Label("Result");
TextField t1=new TextField(20);
TextField t2=new TextField(20);
TextField t3=new TextField(20);
public mathClient()
super("Calculator");
setLayout(null);
l1.setBounds(20,50,55,25);
add(l1);
l2.setBounds(20,100,55,25);
add(l2);
l3.setBounds(20,150,55,25);
add(l3);
t1.setBounds(150,50,100,25);
add(t1);
t2.setBounds(150,100,100,25);
add(t2);
t3.setBounds(150,150,100,25);
add(t3);
B1.setBounds(20,200,80,25);
add(B1);
B2.setBounds(100,200,80,25);
add(B2);
B3.setBounds(180,200,80,25);
add(B3);
B4.setBounds(260,200,80,25);
add(B4);
B1.addActionListener(this);
B2.addActionListener(this);
B3.addActionListener(this);
B4.addActionListener(this);
addWindowListener(
new WindowAdapter()
public void windowClosing(WindowEvent e)
System.exit(0);
public void actionPerformed(ActionEvent AE)
if(AE.getSource()==B1)
sum();
else if(AE.getSource()==B2)
subt();
else if(AE.getSource()==B3)
mult();
else if(AE.getSource()==B4)
div();
public void sum()
int i=Integer.parseInt(t1.getText());
int j=Integer.parseInt(t2.getText());
int val;
try
String ServerURL="MathServ";
mathInterface MI=(mathInterface)Naming.lookup(ServerURL);
val=MI.add(i,j);
t3.setText(""+val);
catch(Exception ex)
System.out.println("Exception:"+ex);
public void subt()
int val;
try
val=MI.subt(i,j);
t3.setText(""+val);
catch(Exception ex)
public void mult()
int val;
try
val=MI.mult(i,j);
t3.setText(""+val);
catch(Exception ex)
public void div()
int val;
try
val=MI.div(i,j);
t3.setText(""+val);
catch(Exception ex)
mathClient MC=new mathClient();
MC.setVisible(true);
MC.setSize(600,500);
Jul 03, 2009 | Microsoft Computers & Internet
Televison & Video Logo
Top Televison & Video Experts
