The picture is not working correctly - gets a picture but only about a third of the screen and distorted
Nothing - don't know what to do with it.
    New Friend:
  • 14 Answers
If this is a RPTV set your convergence circuitry has failed. The cost of repair is usually $200 to $300. Or, if you are familiar with electronic repair you can fix it by yourself with a kit (search your model number for repair kit) which usually costs under $100 and takes about 2 hours of labor.
Posted on Nov 29, 2014
Hi i replaced my bulb for Sony VPLBW5 now i am not getting a clear picture anymore, its very distorted and something seems very wrong
It's very unlikely that this is a due to a faulty bulb.
It's possible that there is a fault with the projector which existed before you relamped it, (i don't know the exact circumstances) but you could try the following steps
1) If the old lamps still works, remove the new one and replace it with the old one. fire the projector up and see what happens. If nothing happens replace the new one again, making sure you don't touch any glass parts (as it can shorten lamp life) or any other internal parts.
2) Turn the projector on and check the image with different picture sources and cables to rule out a fault there. Is the image distorted while the projectors warms up and displays the startup screen? If the image looks correct the problems is likely to be outwith the projector. If the startup image is distorted then the problem is likely to be with the projector.
You should ensure that the lens is free from obstructions. It won't make much difference in most instances but you could clean it with a soft cloth, taking care not to damage it.
Hopefully these steps will help you fix the problem.
Feb 18, 2011 | Sony VPLBW5 LCD Projector
Sony cybershot Dsc-t33 view screen is distorted
This is known issue of ccd imager chip failure in Sony DSC-T33 camera and ccd imager chip will be replaced to get correct live view to take pictures.
Required ccd imager chip is available with Part Store for $52
Let me know if you have additional question.
Thanks.
Mar 10, 2010 | Sony Cyber-Shot DSC-T33 Digital Camera
Distorted picture.
Is the menu text clear on the screen, when it's focused correctly. Or is that also distorted.
If the menu text is OK then the picture signal is dodgy. could be due to a bad earth lead on the video cable.
Is it distorted on all signal inputs
Oct 30, 2009 | Panasonic PT-LB20U Multimedia Projector
Flatron w2043s 20" there is distortion on all letters and numbers etc, its as if its ran out of ink ,spoils the picture big time
The distortion mostly is caused by a wrong screen resolution. Choose another (smaller or larger) resolution and once you've found the correct resolution for your display card tne distortion will be gone.
Aug 03, 2009 | Computers & Internet
My rear projection 51mp392h has color distortion on the bottom third of the screen,it curves up in the middle. Is this a picture tube
Hello tj444,
This is not a picture tube problem. This could be what is called pincushion distortion. It is caused when the is a malfunction in the deflection coils and the inability to correct for the curvatures caused by the CRT. The pincushion distortion can also be caused by the degradation of the functionality of the convergence amplifiers in the TV set. I would suggest that you have a TV technician examine the deflection circuitry and the pincushion circuit, this would also include the convergence amplifiers.
I hope this helps,
Thank you,
Shuttle83
http://www.electron-age-technologies-llc.com
Jul 12, 2009 | Philips Magnavox 51MP392H Rear Projection...
Canon A75 - viewfinder shows- purple distorted picture.
Its bad ccd imager in camera and this part will be replaced.
Canon will repair Free of Cost A75 camera as per announced scheme.
Click Canon CCD Imager Advisory for details.
Mar 15, 2009 | Canon PowerShot A75 Digital Camera
Viewing problems
Projection sets have two very common problems.
The first common problem is convergence
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
Here are some of the most common problems with these sets...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Nov 01, 2008 | Samsung HCL5515W 55" Rear Projection...
Distortion and double imaging
*Screen Looks 3-D
*Colors wont align
Sep 07, 2008 | Hitachi 53UDX10B 53" Rear Projection...
Black screen
I have the same problem. Fine one day and a black screen the next. I called Vivtar and they were no help. They wanted me to send it in and let them repair it at my expense. don't think so. everything works perfect on the camera...but the screen is black and so are the pictures. Good Luck!
Apr 26, 2007 | Vivitar ViviCam 5385 Digital Camera
Televison & Video Logo
32 people viewed this question
Top Televison & Video Experts
Electro Med Services...
