Question about Icom Ptt Over Ear Mic / Ear-phone For Ic-w32a Ic-t90a Ic-f3 011s Radios
Just moved to new location and hooked up i com. Am only getting sound in left ear. Have rechecked everything and all connections seem sound???
This is an oxmoron you cant have checked every thing
left and right ear audio on CBs come from a common mono signal
so the right ear signal is missing or the headphone on the right ear piece is busted
sherlock....
Posted on Nov 30, 2014
Stereo system connected to computer audio is not working and it was working before
Recheck your settings. Go the lower right and see if the speaker settings are correct. Vol. and speaker connections! You may have turned off the speaker off by error. If the settings are OK, try a headset with right/left ear buds and if you get sound, then the speakers are a problem.
Dec 31, 2013 | Computers & Internet
I did the Valve cover gasket, spark plug and wires on my girls 2000 mitsubishi eclipse GT and I put everything back to where they go. And right when I started it up, Knocking and rough idle occured. T
sounds like u left a vacuum line disconected or a emision line off recheck to make sure u hooked everything back up. sometimes when disconectimg wires and hoses u move them out of the way and they get hidden.
Oct 03, 2012 | Mitsubishi Cars & Trucks
All I get is static when I use my T V Ears. Everything hooked up properly, have new battery. What's wrong?
Hook up your TV cable to Bell , Rogers , or satelite box , make sure cable is connected good.
Feb 27, 2012 | TV Ears 10241 Professional Listening...
I just installed a clarion type II am/fm/cb on my 83 golding. The handle bar switches work and the gauges work. But I get no sound what so ever. Before I put it all in the faring I tagged each set of...
Recheck the wires. If you do not plug everything into the right spots it will not work. Possibly one of the plug holes is mismarked. You may have to located the original instructions to get it hooked up correctly.
Aug 18, 2010 | 1980 Honda GL 1100 Innerstate Gold Wing
The left side seems to have a faulty connection with the sound being absent or intermittent. Occasionally it sounds normal. Waggling or tapping the actual ear phone seems to activate the sound but dfficult...
You might have a bad connection on the wiring terminal inside the left speaker where the left and right join the main cable. Here is a link:http://www.metacafe.com/watch/1045725/how_to_solder_how_to_repair_headphones/
Nov 25, 2009 | Bose On-Ear Headphones
The left earbud of my Bose in-ear headphones doesn't have sound
You probably need to replace the stereo plug on the end that goes into the jack. Most of them are molded on unfortunately but it can be done with a new jack and some soldering skills. There have been lots of people with the same problem on this site so there are already some good explanations of how to do this on here.
Aug 28, 2009 | Audio Players & Recorders
How to install bobbin
In the shuttle area there is a silver round piece- called the shuttle race cover. It has a black ear on the right and a black ear on the left. Push the right ear to the right, and the left ear to the left and the silver ring should come out. Behind the silver ring is the bobbin case stuck in the hook. Remove that, jiggle it, move it, just work the bobbin case out of the hook. Now put the hook back in the machine. In the machine there is a driver that looks like a half moon. Your hook looks like a half moon- make a full circle out of both of them. Re-install the race cover, pushing the left ear to the right and the right ear to the left to secure the race cover, and your problem should be solved.
Jul 07, 2009 | Necchi Sewing Machines
Bobbin don't turn
Jul 01, 2009 | Brother SE-270D Computerized Sewing...
Water & Ice dispenser quit on Kenmore 106.9535110
recheck the electical connection at upper frz door hindge sometime a wire could be pushed out but check to see that the control lock was not set by accident
Dec 11, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Icom Ptt Over Ear Mic / Ear-phone For Ic-w32a Ic-t90a Ic-f3 011s Radios Logo
66 people viewed this question
Top Icom Radio Communications Experts
Steve
johncassells
Level 1 Expert
Are you an Icom Radio Communication Expert? Answer questions, earn points and help others
