Question about Sharp AR-M550U Copier
I am having a problem f3-22 Code Is it possible to help
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Sharp Master
  • 884 Answers
Hi
A quick look on the internet found several items that may be of interest. The first here:
http://olsonbros.com/sharp/support/pdf_trbl/trbl-arm550n_m550u_m620n_m620u_m700n_m700u.pdf
is a diagnostic tool in pdf format carrying all the error codes for your machine and the reason for them. In your case the "f3" refers to the paper tray lift mechanism and the "22" to tray 2. I recommend you download and save this file to disk for future reference. I tried a different site and this confirmed the error as "Paper does not lift in the tray".
Unfortunately neither of these sources was any help at all with the solution.
I did find a service manual for your machine however which I think should help you and again I suggest that you download it from here:
http://diagramasde.com/diagramas/otros/SM-ARM550APR_13_2004.pdf
and save it to disk for reference. However please be patient, very patient, it is a big document (over 50 Mb). At that size I haven't been through it to pinpoint your problem areas in it, but if you use Acrobat Reader's search facility for "f3" it will cut your reading time down !!!
There are masses of diagrams and tables to help you pinpoint the problem and the section of the machine and the parts involved.
Hope this is helpful, if so would you please register that with Fixya
Cheers
Posted on Nov 28, 2014
What does a flashing yellow light mean on the joystick? the light looks like the shape of a wrench.
Hi Judy,
According to Pride's troubleshooting documents the service indicator (wrench icon) will flash when a fault is detected by the dynamic controller.
The number of flashes, followed by a 2 second pause, indicates the issue. You will need to count the flashes to determine the cause and a possible solution.
I have typed the flash codes below, but you can also see them on a larger table here: http://www.fixya.com/support/p3641679-pride_jazzy_614_hd_jazzy_614hd/usermanual-6B42026-pdf
FLASH CODES
Code #1
  • Flash Code: One, pause, one
  • Cause: Possible Stall Timeout
  • Possible Solution: Turn joystick off, then on.
Code #2
  • Flash Code: Two, pause, two
  • Cause: Battery Fault
  • Possible Solution: Charge batteries, check battery connections and fuses.
Code #3
  • Flash Code:Three, pause, three
  • Cause: Left Motor Fault
  • Possible Solution: Make sure the left motor is plugged in.
Code #4
  • Flash Code: Four, pause, four
  • Cause: Right Motor Fault
  • Possible Solution: Make sure the right motor is plugged in.
Code #5
  • Flash Code: Five, pause, five
  • Cause: Left Park Brake Fault
  • Possible Solution: Make sure the left brake is not in freewheel mode.
Code #6
  • Flash Code: Six, pause, six
  • Cause: Right Park Brake Fault
  • Possible Solution: Make sure the right brake is not in freewheel mode.
Code #7
  • Flash Code: Seven, pause, seven
  • Cause: Joystick Fault
  • Possible Solution: Check the joystick connection.
Code #8
  • Flash Code: Eight, pause, eight
  • Cause: Power Module Fault
  • Possible Solution: Check connections to the power module and batteries.
Code #9
  • Flash Code: Nine, pause, nine 9
  • Cause: Controller Communication Fault
  • Possible Solution: Check bus connections from the joystick to the power module.
Code #10
  • Flash Code: Ten, pause, ten
  • Cause: Controller Fault
  • Possible Solution: Contact Technical Service for assistance.
Code #11
  • Flash Code: Eleven, pause, eleven
  • Cause: Incompatible Device Fault
Sep 05, 2013 | Pride Jazzy 614 Hd JAZZY 614HD
Code
apparently they do not have the brand as you mentioned, i have tried looking for one but none so far, it will be best if you will get hold of comcast and possibly, only possible ask for reprograming to make your Astar work.
just click this link for their contact information Comcast
hope that helps.
Aug 05, 2008 | Astar LTV-3201 32 in. LCD Television
HOW TO KNOW MY PUK CODE?? PIN CODE? :(((((((( its possible the code must be the 4 last number of my number? i can't call the service now. No more load. HELP ME! :) :(
check the manual of ur simcard.it is usually written out there.dont try puk code for more than three times bcoz ur simcard may get block
Mar 08, 2012 | Nokia N97 Cell Phone
My 2008 Harley FXDC is throwing a code P55PL6, whats this mean ?
No such code so recheck and post a comment with any real codes. P is part of a possible code. 55 could be part of a possible code PL is not a possible part of a code. 6 could be a part of a possible code. What is your problem that you need to display a code for? That might also help narrow down you problem and your possible code.
Mar 08, 2012 | 2008 Harley Davidson FXD Dyna Super Glide
I changed my my nokia x1-01 security code and forgot:(
i have forget my password in nokia x1-01 plz help me
Jan 04, 2012 | Cell Phones
Hi I m sanchit.I want some help from all of you.I have forgot my security code.I have used nokia n72.Its serial no. is 353089020693285.I have use all 4,5,6digits code but these are not work.plz told me...
Hi! The only possible free solution is to format your phone, that erases all your codes, but, even all info from your phone. Shut down the phone, press *, 3 and green(answer) key, keeping pressing power on the phone, keep pressing, after 15 seconds release all. If operation finishes with success, you will need to enter time, data, location.
Jun 06, 2011 | Nokia Lands Phones
Battery discontected. Stero now does not operate. Need stereo code. Hyundai Sante Fe 2005 VIN: KMHSC81DR5U900169 Thanks
I don't know how much luck you will have, but open the glove compartment and look all around for a little sticker, possibly white. It should have code. A lot of vehicles that needed codes were factory installed with a code stuck inside the glove compartment. If there is no code in sight, I would suggest calling your local Hyundai dealer for possible location of the code or bringing it in for a reset. Hope this helps!!
Apr 15, 2011 | Car Audio & Video
I have A security code in my mobile but when I input my correct security code it showing code error. Can you help me pls. As soon as possible. Thanks.
This is just a guess because I had a problem similar to yours. You may want to try to re-enter the security code (if it's possible) because it may not have saved. Your old security code is probably the last 4 digits of your phone #. Different phone companies do it differently. You'd know what it was previously, so try that code and try re-doing it. Hope that helps.
Jun 18, 2010 | Cell Phones
Restriction code for lg g4020 cell phone....
I need a code possibly for free to unlock my lg g4020.....please help........thanks
Dec 11, 2007 | Cell Phones
Sharp AR-M550U Copier Logo
149 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
CheckitRight
CheckitRight
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
