Question about Brodit ProClip for Kia Carens II 2003 - 2006 Right mount
How do i fix starting problem?
I have change the oil
  • Brodit Master
  • 3,368 Answers
You need to define what the starting problem is and is it hot cold, etc.
Posted on Nov 28, 2014
Engine malfunction light came on with low oil pressure when i started car. engine light stayed on. do i just need an oil change
you need to have the oil pressure checked by using a mechanical oil pressure gauge
that will determine if it is a pump problem or an oil gauge sender unit
changing the oil will not fix the problem
you should be doing oil and filter changes every 10,000 miles and then that oil change suggestion would not figure in the problem
your problem is either mechanical or electrical but you need to determine which before you damage the engine
Sep 28, 2016 | 2004 Mercury Sable
Vita 35 classic lawn mower not starting after tilting 2 change blades.
Use some staring fluid to get it going and that will burn off the oil.
Sep 04, 2016 | Garden
I have a Mazda 2008 CX 7, had oil changed. I have a oil leak, wife started to work three day after oil change no oil in car. What could be wrong.
fix the oil leak as there is more oil coming out than you realized
could it be a loose or incorrectly fitted oil filter
Oct 19, 2015 | Mazda Cars & Trucks
Engine start ticking when start up from cold after warm up it stop what the pronlem?
lack of oil to lifters, was a common ford thing back in the 80s, when did you last change the oil? sometimes old oil causes the issue, i had a bronco that would start doing it every 4000 miles unless i changed the oil.. try a thinner oil, 5w30, or 5w20..might fix the problem
Sep 12, 2012 | 2003 Saturn L-Series
Change Spark Plugs but engine starts to leak oil
??? Sounds purely coincidental... You may want to look at where the oil is coming from and fix that issue. Oil pan, Oil filter, oil cooler, oil sending unit, intake manifold, valve covers, rear seal....
Jun 11, 2012 | 2002 Land Rover Freelander
Briggs and stratton 6.5 started smoking so changed oil in hopes would help still smoking
sounds like it broke a ring to fix better to buy new moter not worth trying to fix
Jun 01, 2012 | Briggs & Stratton Lawn-Boy 10640 20-Inch...
I have a 1999 ford e-250 v-6. i had the oil changed at a firestone where i always have it changed. a week later the oil pressure started dropping to 0 at idle it go back to normal while driving. i replaced...
Mileage? replacing the oil pump never fixes a oil pressure problem. has the oil pressure been checked with a mechanical gauge? If it really is "0" then the engine has to come apart and bearing clearances checked.
Dec 21, 2010 | Ford E-Series Cars & Trucks
My oil light started blinking. temp has not increased and there is plenty of oil in engine
Possible problems are bad oil pressure switch "OPU", blocked oil pick up tube or screen, or oil pump.
Start from the easier fix.
Change the oil pressure switch
Clean the oil pick up tube and screen in the sump.
Change oil pump.
Nov 24, 2010 | 1990 Honda Accord
Oil leak
If it the oil filter housing it can be changed if its the gasket it cab be changed too, Check and make sure which it is first then we can fix, contact if you need more help and thanks for using FIX YA.
Mar 20, 2009 | 1987 Chevrolet S-10 Pickup
Brodit ProClip for Kia Carens II 2003 - 2006 Right mount Logo
70 people viewed this question
Top Brodit GPS Experts
Gilbert Ruiz
Ted Maxwell
Mike Charette
Are you a Brodit GPS Expert? Answer questions, earn points and help others
