Question about Kenmore Dryers
How to fix a kenmore dryer that don't have power why it will not come on
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 139 Answers
Most Kenmore dryers have a thermal fuse or a high temp cutoff inside the back on the heat duct. Use a meter to see if any are open, if so replace. The thermal fuse is made of white plastic and has 2 wires connected to it. MAKE SURE the dryer is unplugged from the wall before doing anything. Hope this helps. This is a common failure when the vent is restricted.
Posted on Nov 28, 2014
11076812693 drum won't turn.
Kenmore Dryer Model 110.76812693 (11076812693) Drum ...
www.repairclinic.com/.../Model-11076812693-Kenmore-Dryer-Drum-T...
Kenmore Dryer Model 110.76812693 (11076812693) Drum & Tub Parts in stock. One million parts for 125 brands. Guaranteed same-day shipping. Call 7 days ...
Kenmore Dryer Model 110.76812693 (11076812693) Motor ...
www.repairclinic.com/.../Model-11076812693-Kenmore-Dryer-Motor-...
Includes pulley for dryer drum drive belt. Other shaft has reverse threads for blower wheel. Common symptoms of a bad drive motor are: -Dryer stops turning ...
Kenmore, Whirlpool Dryer Repair - Heats properly, drum will ...
? 6:29
https://www.youtube.com/watch?v=bOShDc4kLfk
Jul 10, 2013 - Uploaded by ApplianceVideo.com
Service a Kenmore Dryer with some of the following issues: Heats but ... Kenmore, Whirlpool Dryer Repair - Heats properly,drum will not turn - 11068202794 ..... Whirlpool Kenmore Maytag Amana Dryer Won't Start - Easy Fix ...
How To Fix Dryer That Won't Tumble ' Dryer Repair
www.partselect.com/Repair/Dryer/Will-Not-Tumble/
Feb 08, 2016 | Kenmore Dryers
Kenmore Dryer 110.61066000 control panel is on, but just gives a
2 options.
1. your belt broke and the microswitch on the idler pulley is not being depressed therefor the motor will get power. This is easy to diagnose. Open the door and try turning the drum by hand. If it spins with little to no resistance then you need a new belt. If it spins but has resistance then you don't.
2. The motor relay on the control board is bad. The control will run through diagnostics and can appear fine even if this relay is bad.
Nov 15, 2012 | Kenmore Dryers
Kenmore electric dryer code f01 what does this mean
Usually in my experience the control board is the problem.
You will need to replace this and your problem will be fixed.
It's very easy to change yourself, don't hire a repairman.
I posted the exact board on my website repairbeware.com.
This site will also give you good info if you need to hire a repairman to do the job. Hope this helps :)
May 26, 2012 | Kenmore Dryers
I need to know how to light the pilot on my kenmore dryer
What is the model number of your dryer? The number may be located inside the dryer door.
Dec 18, 2011 | Kenmore Dryers
Kenmore dryer Tub will not turn freely. Feels as if it's hung up. When you you press the start button it will just make a humming noise.
A guess, sounds like you are hearing the motor running but no tub belt as it is probably broke. If you are asking then you probably don't know how to fix it so you should call a repairman. Or the tub guides are wore out either way a repairman can help.
Nov 22, 2011 | Kenmore Dryers
Kenmore 70 Series Dryer won't turn on. I don't think it is a door switch problem because when I hold down the door switch to make the dryer light turn off, the dryer still won't start. I...
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Sep 19, 2011 | Kenmore Dryers
My Kenmore 400 series dryer has stop blowing hot air to dry my clothes. It blows room temperature air therefore, my clothes don't dry in a timely manner. How do I fix this problem? Thanks,
Hi Most ahve the same problem, maybe the dryer vent is plugged up , pull unit out and unplug it , remove vent and clean , then with a tester check over heat sensors at rear of dryer , they knid of look like diodes with two wires going to them , you could also by pass them with a jumper wire , BUT JUST TO TEST THEM ONLY ! it could also be th eelement , but most times it is a sensor form over heating unit , both are very cheep to fix,
Jul 27, 2011 | Kenmore 400 6942 Dryer
I have a Kenmore 500 series dryer. The dryer just stopped working but the light stays on when the door is closed.
the door switch is broke.when you push on the paddle of the door switch the lite should go out,if you don't see the paddle it most likely broke off,you need to send the full model number next time,it will start with 110.or similar.the door switch is a safety so the machine won't run until the door is closed,if the switch is broke no power will go to start the dryer
May 10, 2011 | Kenmore 500 6953 Dryer
I have an 80 series kenmore gas dryer, will not heat, is it the starter? where can i get one, is it an easy fix? don
it could be the glowbar that ignites the gas,or it could be the thermal fuse in the dryer vent housing,the radiant sensor on the burner tube box that detects the flame and keeps the gas valve open,or the gas valve boost and secondary coils on the gas valve are open or weak and can't keep the valve open any longer,you need to remove the front cover and top cover to remove the drum to check any or all of these components
Jun 17, 2010 | Kenmore 63942 Dryer
Kenmore dryer 417.84072300
Check you circuit breaker. Even if it doesn't look tripped reset it anyhow. This is a power interrupt code.
Dec 04, 2007 | Kenmore 84072 Electric Dryer
Dryers Logo
49 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
