Question about Refrigerators
Im getting a pe0000 h20 on my gi5fsaxvy03 whirlpool 3 door fridge I changed the main board
    Problem Solver:
  • 8 Answers
It is telling you to program the main board
Posted on Nov 28, 2014
  • 958 Answers
SOURCE: personality code
osborne, you can try this procedure.
PROGRAMMING MODE: (FOR PROGRAMMING A NEW CONTROL)
NOTE:
The Program Code is located on the Serial Plate on this unit after the word Code.
1. Open the Fresh Food door and press and hold the Door Alarm Keypad.
2. Press and hold Freezer Temperature Down Keypad .
3. Release the Door Alarm Keypad and wait 3 seconds.
4. The control will display PE to indicate the programming mode.
DIAGNOSTIC TESTS
5. Entry is confirmed by pressing the Freezer Temperature Down Keypad once more.
6. The control will display the current Program Code. This value should be validated with the
Program Code printed on the unit serial plate.
NOTE: If the Program Code is correct, the Programming Mode is exited by closing the Refrigerator
door(s).
7. Press the Refrigerator Temperature Up Keypad or Refrigerator Down Keypad to change the
digit value with each key press.
8. The decimal point indicates the selected digit. Press the Freezer Temperature Up Keypad
to select the next digit.
9. Once the desired Program Code is entered, press and hold the Freezer Temperature Down
Keypad until the Program Code begins flashing indicating it has been saved.
NOTE: If you attempt to enter an invalid Program Code the control will not save the new code,
but will beep. (The unit will NOT run with a Program Code of 0000).Once the Program Code
has been saved, the Programming Mode is exited by closing the Refrigerator door(s). If the new
code is incorrect this process should be repeated after closing the Refrigerator door(s).
The Programming mode can be exited at any time by closing the Refrigerator Door(s) or
will exit if unattended for four minutes.
i hope i was able to fix your problem.
Posted on Jul 08, 2008
SOURCE: slow dripping water from top freezer into the main fridge
We just got rid of our 26 year old Kenmore for this reason. In 26 years I used a hair dryer to thaw out a tube toward the back of the refrigerator. At least in ours when the tube gets frozen shut the water had nowhere to go but in our egg tray.
Posted on Oct 23, 2008
57 varieties
  • 1653 Answers
SOURCE: Whirlpool Fridge/Freezer Door Seal Replacement. Model: ART 462/3
In short no as long as you get the correct seal type from a spares shop, or Whirlpool. Just make sure that it is straight and there are NO gaps or splits in it when you refit it. Usually these will come pre cut to size for the particular model of FF but you can also buy seal strip on a reel from many spares shops. Also when you have removed the old seal make sure that you use a degreasing cleaner to clean around where the old seal was located and make sure the area is dry before fitting the new one.
Posted on Aug 29, 2009
aasc
  • 1606 Answers
SOURCE: un hook the water line from door on whirlpool
Push in on the end ring , pulling the tubing out at the same time . If you have the blue connector with white end rings , Push in on the ring oan pull out the tubing at the same time .
Posted on Oct 02, 2009
BMT60
  • 126 Answers
SOURCE: I have a 3 door Whirlpool Gold fridge. The bottom
ACTUALL FREEZER TEMPATURE MAY BE ABOVE 17 DEGREES. THEN THE ICE MAKER WILL NOT WORK. OR MOISTURE GOT IN TO THE HEAD OF THE ICE MAKER AND FROZE THE GEAR.
Posted on Apr 24, 2010
The fridge has quit working. Light is on inside the fridge and freezer but control panel on ice and water dispenser housing is out
It's either a bad control board in the back, bad display board or lack of communication between the two. Check all of the electrical connections on the main board and at the hinge area above the door. Then next I'd check the connections at the display board. I'd unplug the refrigerator before you do the checking to prevent any possibility of electric shock to you or arc to the board.
Mar 24, 2016 | Whirlpool GI5FSAXVY Stainless Steel ...
Self diagnostics
this sound like defective boards or the boards are not being hoked up correctly causing them to short/melfunction
Oct 22, 2013 | Whirlpool Washing Machines
My h20 symbol is lit up red
Sounds like the water filter needs changing only. What is your model number located around the fresh food section door frame? I will try to locate a user manual for you, Thanks Sea Breeze
Feb 04, 2013 | Whirlpool Refrigerators
After installing a new mother board on a 5 year old Maytag 3 door Model # MFI2568AEW the display reads PE0000 and the control buttons do not work. Is there a reprogramming procedure?
It's board are already programmed so check it's wiring for open, look for deformed component it may cause it not buttons to work. Also do not overlook the possibility of a factory defect control board sometimes it do happened. Be sure that you installed it correctly the same as the old one. Look for loose connection.
Thanks for asking. Good luck.
Jul 04, 2011 | Refrigerators
My whirlpool american fridge s20BRBB20 A/G clicks and clatters and front panel flashing. Fan and motor changed but problem persists
if the clicking is from the ptc overload relay on the compressor unplug it off the compressor and replace it,if the clicking is coming from the main control board and the front readout is flashing/strobing the board is bad,but before you replace this board make sure there are no inopertive fans as this will ruin a new board immediately
May 13, 2011 | Whirlpool 25.4 Cu. Ft. Side-by-Side...
I just replace my control board and freezer fan. I plug the refrigerator in and I get the PE0000 code. I try to go into the program mode by pressing door alarm and then freezer down key for three seconds...
I just fixed mine. With the PE00 0000 flashing press and hold the door alarm key, press the freezer down (-) button and hold, then release the door alarm button. after about a second release the freezer down button and the display should change to a steady PE00 0000 after about 3 seconds. Using the refrigerator + - buttons you change the code. The freezer + - buttons now control the position of the decimal point to change each number position. My code was 0302 (found on the sticker on the inside of the frig, right hand upper side. I had to follow the programming code found behind the kick plate on the right side twice, the second time it worked.
Apr 08, 2011 | Maytag MFI2568AES Stainless Steel Bottom...
Whirlpool fbb36af20/2 fridge freezer frame of front fridge freezer getting hot, fan at bottom back stoped working replaced fan but when you plug in new fan it starts to work but when you fully push the fan...
Hot frame is mullion heaters. Keeps moisture from forming on door and causing rust. Sounds like the connector is defective, remove connectors and wire direct. If fan won't run then you need to call a qualified service tech.
Sep 09, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Whirlpool gold refridgerator light not working and is making funny noise
Had the identical symptoms with my Whirlpool Gold GS6SHEXNB00 side-by-side refrigerator. Had a technician come on site, indicated it was the "circuit board/ timer" (Whirlpool part # 1394052). Board is accessible from behind fridge (lower left side in a white plastic housing to left of compressor).
Swapped the board out (noticed a scorched circuit on the old circuit board). Lightbulbs now work, temperature readouts also good to go.
Mar 03, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Refrigerators Logo
82 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
