Want to connect a Samsung Bluetooth keyboard KBD2000 which I use on my Samsung smart TV. the PS3 finds the keyboard and asks for a pass key I have tried 0000,1234,9999, any help would be appreciated
SOURCE: No power on PS3
Did you try and plug it in somewhere else? Did you flip the switch back on in your fuse box? If Ps3 won't work, send to sony.
SOURCE: ps3 bluetooth connection
I think you are mixing up two different technologies. You said you have recently bought a Wireless Router and when you try scanning for Bluetooth devices you can't find it?
First of all, Bluetooth isn't Wi-Fi. You should go to Network Settings under Settings in the XMB and choose for a Wireless Connection and then let it scan.
Be sure you don't have a 40 GB PlayStation 3 since they don't have Wi-Fi.
I hope this helps. Please rate.
Greetings,
DarkNeogen.
SOURCE: sony ps3 an samsung tv
Well your PS3 Can't connect with your TV to the Samsung, because PS3 Was made HD Blu-Ray. If your TV/Samsung is not supported by High Def. or Blu-Ray, it will not work, you will need a different HDMI Cable, and it should work fine.
Hope this Helped.
SOURCE: wep key for ps3
you will need to obtain your wep key no matter what...you can get it from whoever your router company is (if it is a linksys then call the linksys support number and obtain the key) in most cases thought the wep key is located on the router itself near the bar code. It will be a long number, When you get it and enter it in to the network settings then it should pick up the signal
SOURCE: PS3 PAL HDMI video problem with a HDTV SAMSUNG SQ01
hmmm maybe your tv should be set to a different setting other than PAL
