Question about Honeywell Heat/Cool Thermostat
Where can I buy a wall mounting plate for a honeywell th5220d1029 thermostat?
  • 3,506 Answers
You should be able to get this from any heating supply store or repair facility in your area.
Posted on Nov 28, 2014
Replace a honeywell t822l1000 with a programmable unit
Match the thermostat wires to the letters on the new thermostat terminals R Red Y yellow ETC.
Nov 16, 2014 | Honeywell T827K1009 Mercury Free EconoStat...
How do i reset my honeywell thermostat
Remove thermostat from wall, leaving base plate on wall.
Model number appears on back of device.
Google search thermostat model in following format: Honeywell xxxx32 thermostat .pdf
Adding .pdf to search parameter will yield product manual.
Also while thermostat is off the wall, change batteries located in compartment on back of thermostat. These batteries must be changed periodically, for example each 3-4 years.
Jul 17, 2013 | Honeywell TH3110D1008 Pro3000 Thermostat
Why does fan not cycle off on heat cycle for TH5220D1029 thermostat
1) normally you must to exchange by new batteries with the same types alkalines FULL charges.
1a) see if there are some wires loose and tight it
2) reset and program it again , follow the instr. manual if you do not have download from Honeywell from section support give the number, model and do it.go to http://yourhome.honeywell.com/home/
God bless you
Oct 08, 2012 | Honeywell Th5220d1029 Non-programmable...
How do I remove a Honeywell DT92E Thermostat from the wall mount ?
turn off power to thermostat. should be a small flat head screw located on the bottom of the unit. release screw and lift face from the bottom, out and up. you will then need to identify wiring before removal of back plate unless the wiring is redundant.
Nov 07, 2011 | Honeywell Programmable Thermostat Heater
I have a Honeywell Chronotherm III Thermostat and in instead of showing the temparature in the display it shows -AC. I've replaced the batteries, and tryied adjusting Temp up and down for cooling and...
It would appear to me that you have lost the 24 volt power supply to the thermostat. In referencing the manuals for this thermostat, available @ www.honeywell.com, I've found that when the thermostat is not connected to the wall plate (plate mounted on the wall, that the thermostat either snaps or screws into), it will display the -AC. This being said, either the thermostat is loose on the wall currently, or your 24 volt transformer has died. Hope this helps.
Dec 23, 2009 | Honeywell Power Humidifier: Furnace...
How do I " snap off" the cover of my Honeywell Thermostat to see if I need to replace the battery? The digital numbers don't show anymore and I am getting cold! I don't want to force the cover off and...
There is a seam around the edge of the Thermostat , a small screwdriver or butter knife should do the trick , if not then its mounted to a plate on the wall that has 4 corners basically...Gently squeeze the bottom and pull the bottom out , they are pretty sturdy and you shouldn't have a problem,...the wall plate may flex a little while doing this
Oct 26, 2009 | Honeywell Electronic Programmable...
MY AIR CONDITION IS BLOWING ONLY HOT AIR. I HAVE NONEYWELL TH5220D1029
http://customer.honeywell.com/honeywell/ProductInfo.aspx/
TH5220D1029#LiteratureDownload
This URL will allow you to select your model number and download the instructions.
May 08, 2008 | Heating & Cooling
Honeywell Heat/Cool Thermostat Logo
51 people viewed this question
Top Honeywell Measuring Tools & Sensors Experts
Dan Webster
Dan Webster
Bill Long
richie46
Are you a Honeywell Measuring Tool and Sensor Expert? Answer questions, earn points and help others
