Question about Radio Communications
I need an FS-1503 mic wiring schematic. It is an 8-pin and I want to convert it to 4-pin. Any tip please?
Want to convert the 8pin to 4pin
Find the grounds
on 8 pins you have two grounds black wire and copper screens
connect both to a flying wire
you can use a beep test digital meter {2$ type} to find the TX line
white or yellow is usualy audio to the radio from the mic
and thats it
oh yey too find the ground on the radio look up its details
you can use the beep test also to its neg wire {not the case it floats not + or -}
mic
the case is for the screen wires coppers
the black wire is ground on the mic plug only
the white or yellow will be audio to the radio
the orange or blue will be TX enable and gets shorted to the ground black when you press the TX key
so armed with this
good luck and happy festive season....!!!
Posted on Nov 30, 2014
I need the total wiring diagram for camera [8pin rj11]
8 pin RJ45 (8P8C) male connector
at the camera output
LG LVC-CY100NM Color Security Camera with 8-pin RJ45 (and other cameras for the LSP-M1017M Dual Quad Observation Systems by LG)
Pin
Number Pin
Name Description 8 SPK Speaker (Hot) 7 VID Video Out 6 GRN Ground 5 SPK- Speaker (cold) 4 AO Audio Out/Alarm Out 3 VDC 12VDC 2 N/C RS-485- 1 N/C RS-485+ Note: Pin numbers are labled backwards in the manual (corrected above).
The camera is adaptable for use in any composite video application with the use of a balun.
on the output. I had noise-less video and clean audio across a 350 foot run of cat 5e.
Jan 29, 2013 | LG LVCCy100NM Color Security Camera with...
Fs 1503 furuno no tx but 2182 good
Where is the damage on the mic ptt on tap but can not move to TX beg explanation when the PTT switch ya really connect .Furuno FS 1503
Mar 14, 2012 | Furuno Boating
Can you connect the 4pin power supply to the 8pin on board 12v
Yes, you can connect the 4 pin power supply to the 8 pin with little trouble but, you should not try any advanced features like overclocking or crossfire. If you would like to do those things I suggest getting a 4 to 8 pin adapter (very cheap usually less than $5) at most local computer stores.
Oct 10, 2010 | Gigabyte GA880GMUD2H AM3 AMD 880G HDMI...
CPU overvolted and burn using 8pin eps12v cable on crosshair
no i dnt think so some time due to manufacturing defects this happens the new one wont burn unless and untill u over volt it.
Jan 31, 2010 | ASUS CROSSHAIR Motherboard
Running a uniden pc 122 4pin few yrs old wanting wiring colours
Hi
have a quick look at the link bellow that should sort you out
http://www.okdxgroup.co.uk/mic.htm
Regards Alan (alstech)
Apr 27, 2009 | Uniden Bearcat Pro PC68XL 40-Channels Base...
Do I need a 4pin-4pin DV cable or a 4pin - 6p -with Canon MV 850i
The camera has a 4-pin slot. If the slot on your computer has a slot the same size as your camera, it is 4-pin. If it is larger, it is a 6 pin slot.
Dec 31, 2008 | Canon ZR850 Mini DV Digital Camcorder
Wiring diagram for a road king 56 4 pin mic
4pin roadking 56 wires came off need to know where they go 1 thru 4
Dec 01, 2008 | Magnum DeltaForce CB Radio
Kenwood 8pin harness
looking at back of 8 pin harnes, with wires facing you and tab facing up, left to right,
top
plugged into head unit i----------- i
______________________| |___________________________
| 1st pin, - blank | 2nd pin - Black wire | 3rd pin blank | 4th pin blank |
| 5th pin - yellow | 6th - pin blank | 7th pin- green| 8th blank |
Sep 27, 2008 | Kenwood Excelon DDX-7015 Car DVD Player
Radio Communications Logo
47 people viewed this question
Top Radio Communications Experts
eradiostore
eradiostore
Mike Charette
Are you a Radio Communication Expert? Answer questions, earn points and help others
