Question about Dynex DX-L26-10A 26 in. HD-Ready LCD TV
How do i change the language to english on my dynex flat tv model dx-l26-10a?
    Top Expert:
  • Dynex Master
  • 74,243 Answers
Dynex flat tv model dx l26 10a Google Search Download the user manual to this set; by this link. It has all details.
Posted on Nov 28, 2014
SOURCE: Program a universal remote for the Dynex 32" 720p Flat Panel
Try using the codes listed for Orion products. Worked for me.
Posted on Feb 17, 2009
SOURCE: Programming Scientific Atlantic remote to work with New Dynex TV
dynex is bestbuy's product try emerson, mine is working with emerson codes
Posted on May 23, 2008
rulds2008
  • 3866 Answers
SOURCE: Broke a brand new TV screen dynex dx lcd32 09 Does anyone know how to buy a replacement screen
Try ebay look up the model number on there useing advanced search you just might find one.. Good luck.
Posted on Apr 22, 2009
  • 2318 Answers
SOURCE: Dynex DX-LCD32-09. tv was working fine, then out
This type of failure could be in the LCD controller board or the power supply might not be providing enough voltage to the main board and LCD controller.
Let me know if you require further assistance locating the boards or part numbers.
Posted on Sep 28, 2009
  • 5127 Answers
SOURCE: Dynex dx-l40-10a flat-screen hdtv turns on and the
It's a backlight or backlight inverter issue. (The backlight itself usually fades or makes the on-screen image change to pink/red.) For an out-of-warranty TV, open up the back of the TV and remove the shielding. Look for any scorch marks or bulging or damaged capacitors. (Sometimes other parts will fail on this part but these can be spotted easily. Capacitors look like cylinders on a tripod.)
If you borrow (or have a) high-end multimeter (able to measure high frequencies - 50 kHz) or an oscilloscope, hold the multimeter probes a fraction of an inch apart about an inch above the board and power up the TV. If you see a 1 or an actual value, you have a good inverter. If you see a reading near 0, the board is bad or the multimeter can't resolve the frequency.
In either case, you can buy a replacement inverter for $50-150 and just do a simple swap. Disconnect all of the wires (connections are similar to molex and ribbon cables in a computer) and remove board (a few screws usually). Connect the cables to the new inverter. (If you google backlight inverter replacement, you'll find videos and text descriptions.) Note the part number on the board, including the Rev number, and order the exact one (shopjimmy.com or lcdparts.net are good starting points). Universal inverters do exist but can result in reversed controls (up to lower the brightness). Replacing individual parts on the board is cheaper but more prone to not tracking down all of the bad parts.
If the inverter is good, then it's probably backlights themselves (several in most TVs). These are sandwiched on the perimeter of the TV (usually under some tape that holds the lamp, reflector and other parts together. You need to order by length and width and get ones for your TV size. Remove the tape, and separate the reflector (make a note of how things are put together) then you have to Dremel (or use another rotary tool) to remove the plastic to get the backlight out. (They are often molded into the frame.) Then put in the new backlight and reassemble everything. (http://www.lcdparts.net/howto/default.aspx) but for an overview: http://www.inventgeek.com/Projects/BacklightFix/overview.aspx
With a good spare backlight, you can test an inverter for condition (plug together and turn on the tv while the box is open). Similarly a good inverter can test the backlight. With a bad backlight, you'll usually see a very dim image if you look at the TV from an inch from the screen. Block the room light from overwhelming this image (sometimes a carefully positioned flashlight will help you see something). If the inverter or video board is bad, you will see nothing
I hope this helps.
Posted on Jul 21, 2010
Testimonial: "thanks"
Where can i find a manual for my tv modeldx24ld23oa12 ?
Dynex has the manual for the DX-24LD230A12 (note the dash and the zero instead of an o) available on their product support site, http://www.dynexproducts.com/products/televisions/DX-24LD230A12.html?supportTab=open . The direct link to the English language edition of the manual is http://www.dynexproducts.com/cms/documents/Manuals/DX-24LD230A12_11-0893_WEB_V7_EN_Final%20lr.pdf .
I hope this helps.
Apr 26, 2014 | Dynex Televison & Video
How do I print a manual for a Dynex DX-32L221A12
Dynex has the documentation for the DX-32L221A12 on the product site: http://www.dynexproducts.com/products/televisions/DX-32L221A12.html?supportTab=open . The direct link to the User Manual in English is http://www.dynexproducts.com/cms/documents/Manuals/DX-32L221A12-DX-40L260A12_11-0101_WEB_ENG_V1_Final%20lr.pdf . Since this is a PDF you will need Adobe Reader to access the file. Once in Adobe Reader you can print the document to any printer connected to your computer. If you can't print the document, you can put the file on external media (flash drive or optical media) and have it printed at your local print shop.
I hope this helps.
Nov 24, 2011 | Dynex DX-LCD32-09 LCD TV
I have a Dynex, model DX-L22-10A . The problem is that the picture is in the middle of the screen.
Try changing the size of the screen by pressing Ratio or Screen size using your remote.
AAA TV Service
http://www.aaatvservice.com
Aug 21, 2011 | Dynex DX-LDVD22-10A 22 in. HD-Ready LCD TV
Apr 22, 2009 | Dynex DX-LCD32-09 LCD TV
Dynex DX-L26-10A 26 in. HD-Ready LCD TV Logo
277 people viewed this question
Top Dynex Televison & Video Experts
Jaime Hernandez
Are you a Dynex Televison and Video Expert? Answer questions, earn points and help others
