Question about IBM Correcting Selectric II
How do I remove and replace the tab set/clear button on an IBM correcting selectric II typewriter
Is the tab set/clear key a "snap-on? key?
  • 24 Answers
Yes, all the keys are snap on. Use a spring hook on top and bottom of the key and wiggle (carefully) upwards to remove. (If you don't have spring hooks, then hefty paper clips will do. Create a 90 degree or better bend on the end of the clip)
Posted on Nov 28, 2014
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 99 Answers
The tab/set keybutton as well as the on/off buttons do "NOT" snap on. They are on a shaft that has a "C"-clip on the out side that if you remove the clip, slide the button off and then remove the button from the metal piece that is a pivot for the mechanism. I have been working on those machine for over 38 years.
Posted on Dec 31, 2014
2 Suggested Answers
  • 3594 Answers
SOURCE: IBM Selectric II typewriter stuck in correcting position
If you know how to remove the right dust cover (black inside the T/W below the carrier) next to the R. side frame is the correction set up mech. spray some WD40 on the arms especially where they pivot, they should free up.
DickyO
Posted on Jul 02, 2009
On my ibm selectric II, the ball element is stuck and the cap came off. How do I get the ball off the post?
Take a razor blade and slide it under the remainderof the cap cut the cap off there are 5 connections, after removing the cap you will find a spring retainer pull it off.
DickyO
Feb 01, 2013 | IBM Correcting Selectric II
How do I replace the foam padding in my ibm selectric ii typewriter?
The foam was used for sound dampening. Over time, the foam falls apart and can cause problems inside the machine. If it is coming off, we usually remove it with a razor blade. New foam is not available any more. Hope that answers your question.
Sep 01, 2012 | IBM Correcting Selectric Ii Typewriter
I cannot remove the typing element on am IBM Selectric II typewri
Once the lever is broken you must either find a way to spread the spring that holds it on apart (not easy) or take a razor blade and slide it under the black plastic cap and cut it off.
DickyO
Mar 30, 2010 | Lexmark Wheelwriter 15 Series II...
I have a IBM Correcting Selectric II and I'm having trouble clearing out the margins. Can you help?
space to the right side of the machine, hold down the tab clear key and hit return.
If the carriage stops partway back, one of the tab stops has rotated too far on the tab bar.
remove the platen and paper pan, go to the stuck stop, rotate it to the rear of the machine to line up with the other tabs
Jul 16, 2009 | Nakajima AE-710 Typewriter
DickyO
Jul 02, 2009 | IBM Wheelwriter 30 Typewriter
IBM Correcting Selectric II; correction ribbon frozen in front of typing ribbon.
Move the grey lever on the R. side of the carrier to the R. and remove correction tape, try the machine, if it seems to work OK install a new correction tape.
DickyO
May 28, 2009 | IBM Wheelwriter 30 Typewriter
IBM Correcting selctric II keys are jammed
It sounds like the cycle shaft is not fully in home
position. With the machine OFF, try to turn the print shaft (the steel shaft with the single groove that goes through the carriage) top towards the back of the machine. Then turn the machine on. Try the space bar first. If it works, your machine probably needs the cycle clutch spring adjusted or replaced.
Feb 18, 2009 | IBM 3500 Typewriter
IBM Selectric II
R152
Sounds like you have a broken torquo limiter tension spring you should have it professionly serviced.
DickyO
Jul 07, 2008 | Office Equipment & Supplies
IBM Selectric II
The return clutch torque limiter is off or broken. If you take the right dust cover off it is on the turning hub around the middle of the typewriter. a small spring about 1.25 inches long with a hook on the end. I have been fixing these for 35 years. good luck. Lawrence
Jun 06, 2008 | Lexmark Wheelwriter 15 Series II...
Correcting IBM Selectric II Typewritter correcton ribbon won't engage
Selectric I and II type elements are identical (88 char) where Selectric III uses a different element (96 char). The 88 character element will have white lettering and the 96 character element will have yellow. Directly underneath the lift-up tab to remove the element will be a 3-digit number. That's the last 3 digits of the element's part number, which will be preceeded by 1167 for 88 character, or 1352 or 96 character. For example, if you have a '052" stamped on the element, and it's an 88 character style, the P/N will be 1167052.
The correcting mechanism is an intricate additional function of the backspace function. To test it/adjust it/or repair it requires the machine be hand-cycled using a hand cycle wheel which is screwed into the right hand side operational shaft. It's unlikely that an un-trained party would be successful repairing this..
May 15, 2008 | IBM Wheelwriter 30 Typewriter
IBM Correcting Selectric II Logo
93 people viewed this question
Top IBM Office Equipment & Supplies Experts
James Cagle
James Cagle
Don  Farrell
Don Farrell
jasbo
jasbo
Are you an IBM Office Equipment and Supply Expert? Answer questions, earn points and help others
