Question about Kenmore Washing Machines
My kenmore 600 washer will agitate when emmpty but not when loaded... The clutch was spinning when in the spin cycle and was told that shoud not happen.. With new clutch in it still does..
  • 603 Answers
Check the agitator PAWLS. These are the small arms that make the agitator do what it does. They are located in side the agitator. You will see them when you remove the agitator.GOOD LUCK FRIEND.
Posted on Nov 28, 2014
Testimonial: "Thanks ya when I put pressure on top of the agitator it agitates like normal.. Time for a new one.. I also saw on another forum and guy had the same tansmission as mine.. He was told by the tech, that yes the clutch is suppose to move when in spin cycle.. So basically I replaced it for nothing.."
catriver
  • 878 Answers
SOURCE: Series 70 Kenmore Washer Won't Agitate or Spin
baseball, sounds like a broken coupler, check out this post and post back, Catriver http://www.fixya.com/support/t144580-kenmore_8series_washer
Posted on Apr 27, 2007
  • 107 Answers
SOURCE: Kenmore washer will not spin or drain water,agitate works fine
Sounds like a lid switch. there should be a hole under the lid on the right side about the size of a dime. Make sure the plastic "flipper" is inside and "clicks" when you push down on it with a pen.
Posted on Apr 22, 2009
SOURCE: Kenmore 70 Series washer - agitates and drains but does not spin
my kenmor washes and drains but does not spin, help
Posted on Jun 28, 2009
sotoinfo
  • 26 Answers
SOURCE: kenmore washing machine didn't spin @ end of cycle
If you tried a different cycle and it worked this means that the timer is probably bad on the main cycle that you use. If the machine does not spin on all cycles, then please check out the LID SWITCH.
Posted on Nov 12, 2009
TheMobilian
  • 8220 Answers
SOURCE: Kenmore 90 tub spins excessively clockwise during wash cycle.
Improperly installed thrust bearing kit. Too many washers cause the basket to spin during agitation.
Posted on Jan 04, 2010
Testimonial: "Where is the "thrust bearing kit" and how can it be installed properly?"
Top loader does not spin fast enough to spin dry.
possibly the clutch is slipping, i've heard you can take a #10 washer and put it in one end of your clutch spring caps and that would tighten it up
Mar 23, 2010 | Kenmore Washing Machines
there should be 2 or 3 springs that hold it, they mite have broke, take off back panel an check.
Jan 04, 2010 | Kenmore 24032\24036 Top Load Washer
I have a Kenmore 80 series washing machine and the spin cylcle isn't working. There is a loud grinding noise during the spin cycle and the tub doesn't spin.
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number and you'll see a list of major sub-components with diagrams and parts.
This also assumes that:
1. The machine will agitate and go through the rest of the cycles.
2. It will pump out the water.
3. Since it tries to spin, the Lid Switch is OK.
The problem points to the clutch and / or transmission
See the following for how to pull the clutch on Kenmore top load direct drive washers.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=137
If the clutch springs and pads seem OK, the problem points to the main spin gear inside of the transmission. If the clutch springs and/or pads are damaged, there is a rebuild kit for them.
Following is the Whirlpool / Kenmore installation and maintenance PDF on how their top load, direct drive, neutral drain washers work.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
Here is another PDF of the Whirlpool parts list for their commercial washers, consumer models are basically the same.
If you look at the operation PDF you'll see how the transmission works when going into the spin cycle. If the "Neutral Drain" cams are intact, they drive the main spin gear which drives the spin gear connected to the clutch.
If the main spin gear is broken (It's a metal plate surrounded by plastic gears) you would hear a major grinding noise and the washer wouldn't spin.
Opening the transmission is not difficult but is a messy job. It holds about 14Oz. of oil.
Pull the transmission, remove the clutch (there is a spring clip that holds the clutch on the main agitator shaft, remove the 8 screws carefully the transmission holds 14Oz of oil, remove the clip holding the main spin gear on and check the plastic cams.
If the main spin gear or neutral drain assembly cams are damaged, they aren't too difficult to replace.
The Whirlpool Parts PDF has part numbers for both.
The Neutral drain assembly costs about $15 which is a lot less than $170 for a new transmission.
The Main spin gear is quite a bit more but still less than a transmission.
Oct 12, 2009 | Kenmore 24032\24036 Top Load Washer
My Kenmore agitates while trying to spin??
sorry the repair is a new gearcase appx 230.00 plus labor in your area or buy a new washer ,,,,,
Aug 29, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore Elite washer pn 8526056 will not spin
yes it shoud rotate freely in hand. Here's a site to go and see all the parts to your washer www.repairclinic.com enter model number and scroll all the way down. Where you see all parts click the red 100 and it will show 100 parts per page. There you can find transmission parts or the whole new unit. Good Luck. And yes you have transmission problems
Apr 02, 2009 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Washer will not agitiate or spin
Motor coupler between motor and gearcase.
Mar 30, 2009 | Kenmore 24032\24036 Top Load Washer
KENMORE 80 SERIES 110.92582110 - NOT SPINNING. I REPLACED THE TRANI, CLUTCH, COUPLER BUT I FORGOT TO PUT BACK IN THE AGITATOR WASHER. IT STILL WON'T SPIN SO WHAT NEXT
Jun 12, 2008 | Kenmore 23822 Top Load Washer
Kenmore Automatic washer -110.24862300
sounds like may be in clutch see if you can help the tub start spinning when trying in spin setting...if trying to turn or turns some and stops most likey clutch slipping
Sep 02, 2007 | Kenmore 22422 Top Load Washer
Agitator not turning during cycle
Well, it sounds like you've done your homework. My first suspect would have been the agitator dogs too, but you said they were fine. Another likely suspect would have been the motor coupler, but you said the washer spins during the spin cycle. If the coupler was bad the unit would fill, but wouldn't agitate or spin. Plus, it would make an awful noise. I would have also suspected a clutch assembly, but you said the wash tub can spin. Normally, when the clutch goes bad, the drum won't spin, or spins slow. Another suspect could have been a bad lid switch, but the washer would have filled and stopped, without agitating or spinning. The only remaining suspect that I'm aware of is the gear case (transmission). Checking under the washer can give you some clues. Normally, when a gear case starts to go bad, they leak an amber colored oil. You may find puddles or drips under the washer. If you see no signs of oil the gear case could still be defective, however. But, before you go through all the trouble, double check the agitator one more time. Completely remove it from the tub and check the under side to ensure the grooves that grip the top of the gear case shaft have not been worn smooth. I hope this may have been some help to you.
Jul 09, 2007 | Kenmore 24032\24036 Top Load Washer
Washing Machines Logo
51 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
