Question about Maytag Gemini 30" Self-Cleaning Freestanding Double Oven Electric Range - Black
I have a Maytag Gemini double oven and the right rear burner ignites but wont shut off?
We got the flame out but can still smell gas. Turned gas valve off.
  • Lisa Timm
    Lisa Timm Nov 27, 2014
    It is a Maytag Gemini gas 30" self-cleaning double oven not electric..
  • Maytag Master
  • 3,382 Answers
Great move, you kept your domicile from exploding. It sounds like a bad valve but I am only guesing.
Posted on Nov 27, 2014
5 Suggested Answers
buffalonyman
  • 1865 Answers
SOURCE: I have a Maytag Gemini double oven with a gas
18" is standard
Posted on Apr 16, 2009
caroldon
  • 17130 Answers
SOURCE: I have a Maytag gas range model #CHG9800BAB. The
It is confirmed by you that therre is no gas flow .
So this is the critical missing link to the fault.
We must trace the flow of the gas from the front regulator valve . So using a good air jet, if you can get compressed air to blow into the pipes , it will be helpful. so open the gas inlet and check flow till the valve. Now check the flow from the valve to the ovenflow pipe.
if there is no air coming through use a thin wire to puch in for removing dirt / rust.Blown it out.
Check if the nozzle jet is blocked in the valve assembly through which the gas comes in. USe a thin needle to clean the jet.
Once you have established a clean flow of air , put back all the removed parts and connect the gas.
It must work for sure..
Posted on Aug 27, 2010
Daniel S
  • 4323 Answers
SOURCE: I have a maytag gemini
Hi
The issue is with the tubing or the manifold that is bad and should be replaced. Hope this helps...please post back for further assistance.
Daniel
Posted on Jul 22, 2011
  • 650 Answers
SOURCE: On my Maytag Gemini MGR6875 the flames on the burners are too high on high and go out on low.
If you haven't changed the stove regulator to natural gas this could be your problem. If you are not comfortable with making this adjustment pleaee check with your gas company or a licensed appliance service person to do the work it should take just a few minutes.
Posted on Dec 03, 2012
Broiler shuts off
Make sure you keep the oven door OPEN when using the broiler, otherwise the thermostat will shut it off.
Jan 18, 2013 | Maytag Gemini MGT8655X 30" Freestanding...
No flame
when this happens it is usually because of a faulty flame/gas safety valve.
Sep 08, 2008 | Amana AOGD2750 Gas Double Oven
My Maytag Gemini double oven gas...........the bottom oven won't heat up past 100 degrees. What can I do to troubleshoot?
Hi
This issue seems to be with the gas inlet valve or the igniter itself that is bad. Gas Valve has a bi-metal that open when a certain amount of current flows through it to heat it up. Make sure that the glow bar is not cracked. Faulty igniters can allow correct current to flow to the oven gas valve for it to open but not get quite hot enough to ignite the gas burner immediately. Hope this helps... Please post back if you need more information.
Daniel
Jan 18, 2011 | Maytag Gemini 30" Self-Cleaning...
Top oven not heating up on BAKE, broiler gas and flames come on. Stove top burners work, Bottom oven heats for BAKE and BROIL.
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
Jan 08, 2011 | Maytag MGR6772BDS Gemini Gas Kitchen Range
I smell gas faintly when I walk by my gas range
If it uses gas pilot lights, check each of them to make sure they are lit. If this is not the problem, then check the fittings on the gas supply to the stove - almost every time I've run into a slow leak it's been from a union coupling. It's also possible a valve for one of the burners is not shutting off properly (although I've never run into that before). In this case, I expect the gas odor would be strongest at one of the burners.
Dec 05, 2010 | Maytag Gemini 30" Self-Cleaning...
I have a Maytag Gemini Precision touch 750 series double oven range MGR6775ADB. The lower over is not responding. It will not preheat. The display says preheat and stays at 100. There is no flame igniting.
This sounds like your ignitor has gone out. The preheat will work because the valve doesn't have to ignite to heat to 100 degrees, but whent he unit is ready to ignite, the gas can't ignite it. If you will call or email us, we'll be sure to get the correct ignitor out to you asap so you have your oven orking right away! Thanksgiving is just around the corner, so I hope you get this repaired soon. We hope this helps and we hope to hear back from you soon.
Sep 30, 2009 | Maytag MGR6772BDS Gemini Gas Kitchen Range
Igniter working, can smell gas, but gas not getting to burner
Gas valve is not working. Replace
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
Jul 23, 2009 | Maytag Admiral LER3330AAW / LER3330AAZ /...
Bottom oven does not heat
i ceertainly think that there is problem with the burner. as per the working principle of an Oven the ignitor is doin its job so the problem is with the burner please do check it out...
Nov 25, 2008 | Maytag MGR6772 Gemini Gas Kitchen Range
Swooshing sound in oven when burner ignites
the valve your talking about with the two wires on it is the safety valve and should not let gas in without the ignightor being on sounds like its leaking i recommend shutting the gas off till the valve is replaced there is no piolet light on theese ranges
Jan 18, 2008 | GE JGBS23 Gas Kitchen Range
Maytag Gemini 30" Self-Cleaning Freestanding Double Oven Electric Range - Black Logo
132 people viewed this question
Top Maytag Kitchen Ranges Experts
vince
gbob59
Are you a Maytag Kitchen Range Expert? Answer questions, earn points and help others
