Question about Rainbow Vacuums
I need conected wires with main switch rainbow gold e2. I have 6 wires, they go from rainbow and 6 conectors on main switch.I do not witch wire conect to witch conector.Have you some schema? Thak you.
  • Rainbow Master
  • 3,368 Answers
You can look for the service manual on line with Google. You will need the model number to have a sucessful search.
Posted on Nov 27, 2014
reddevil6
  • 1673 Answers
SOURCE: Rainbow D4C power switch replacement
As far as I know, that switch with 6 terminals is still available. But if not, I would wire the 2 for the power head and the 2 motor wires together. Then you would have 4 leads to attach.
Posted on Jan 31, 2008
reddevil6
  • 1673 Answers
SOURCE: Rainbow SE Power Switch
The 2 clear side panels come off, remove the screws there, then the top will come off and you can get to the switch from there also.
Posted on Feb 05, 2008
  • 61 Answers
SOURCE: Rainbow D3C electric Hose is broke
NO NO NO NO you have to get a new hose in this situation there is no other way around it. If you screw up just the littlest bit reattaching that hose a vacuum that uses water will QUICKLY let you know. Do yourself, your family, and your life insurance company a favor and buy a new hose.
Posted on Apr 15, 2009
  • 430 Answers
SOURCE: I have the new power on/off switch to replace the
Simply pair 1 each of the power head leads and motor leads on to one terminal and wire the cord as on previous switch.
Posted on Sep 09, 2009
  • 41 Answers
SOURCE: Need wiring diagram for Rainbow D4C vacuum to
You can get a wiring diagram at http://www.rainvac.com/schematic.html
You can get all of the manuals, and the full breakdown schematics, of every model there.
If you need me to tell you which wires go where, exactly on the switch, let me know. I am a Rainbow vacuum expert and know everything about almost every model ever made.
If you have any more questions, let me know.
Thank you,
Posted on Jun 13, 2010
How does the Power Head wire up to the switch on the Rainbow SE?
Here is the wiring for a D4 switch:
Rainbow D3 D4 SE power switch
Rainbow no longer makes the switch with 6 wires, it comes now with only 4.
GoodVac.com
800-775-6586
Jun 29, 2014 | Rainbow 75th Anniversary Canister Vacuum
How do i put the wand back together on a rainbow e-series ?
The wire schematics in the handle assembly has four total wires. Two from the hose and two from the Receptacle Nozzle. Take one wire from the hose and one wire from the receptacle and connect together. Take the second wire from the hose and connect to the Switch Handle PN2E PN2. Take the second wire from the receptacle and connect to the other switch terminal. If you need more details, you can download the schematics at Rainbow Vacuum Schematics or you can call us at 800-523-0510.
RainVac
www.rainvac.com
May 30, 2014 | Rainbow E series Canister Wet/Dry Vacuum
I need a wiring diagram for a rainbow d4c
Are you talking about the power switch. The new power switches have 4 wires sautered to the power switch, where the old ones have 6 wires that slip in and lock into the power switch.
The blue ones are for your power cord, and the black ones are for your vacuum motor, and your power nozzle plug.
Secure one motor wire and one power nozzle plug wire to one of the black wires out of the new switch, and secure the other two, to the other black one from the power switch. It does not matter which ones that you match together. Secure one of each of the power cord to the two blue wires from the power switch. It does not matter which one of them goes to each wire neither. It is AC so power goes both ways.
Use twist on wire nuts to secure the wires to each other, and put some electrical tape around each of them, after you secure them securly with the wire nuts.
It is best to secure the cluster of wires to each other with a pull tie, after you are finished wiring everything.
If you have any more questions let me know. I am a Rainbow seller, and a Rainbow expert also.
Thank you,
Ralph
May 25, 2010 | Rainbow Technologies D4 Bagless Vacuum
How do you wire in new switch on rainbow vacuum cleaner. Model D3B
Hello. I am sorry but, if you don't already have the knowledge to do this, I would strongly reccomend you do not attempt it. Rainbows have a large wiring harness. Here's the main reason: Rainbow vacuums are designed to work with a water filter. If you wire the vacuum wrong, or, if one of the connections come loose, it could mean a possible injury to yourself or damage to the unit, which I know you paid good money for. This repair should only be handled by a qualified vacuum service tech. Thank you.
Nov 03, 2009 | Vacuums
When i conect the vacum part to maun system it
There is a motor in the power head that could be out or the receptacle, electric cord on power unit or loose wire in power head.
Oct 14, 2009 | Rainbow E series Canister Wet/Dry Vacuum
Possable broken/Disconected wire
hope you have checked the obvious first ..the plug are all the conections tight including the fuse? if so check the vac's switch for loose conections .lets face it the mains feeds the switch the switch feeds the motor unless you have a speed switch. sounds like a fault that could be cured with a bit of investigation good luck farr64
Apr 30, 2009 | Rainbow E series Canister Wet/Dry Vacuum
I am taking the old motor out of my Rainbow SE
Switch is not serviceable.
I think you are talking about old model switch (originally installed in your Rainbow) To remove 6 wires from the switch - push a pin where the wires go into the switch. It will release wires so you can pull them out. Make sure to draw a diagram how to connect them back.
If you need a new switch - go here
Nov 28, 2008 | Rainbow 75th Anniversary Canister Vacuum
Vacuums Logo
78 people viewed this question
Top Rainbow Vacuums Experts
Joseph Hoffmann
Jax Planet
Jax Planet
Are you a Rainbow Vacuum Expert? Answer questions, earn points and help others
