Bang&Olufsen, Beovision MX 3000, have no remote controll, is there any way to change volume on the actual TV?
    Top Expert:
  • Televison & ... Master
  • 74,118 Answers
If its front pane key-board is not locked; you can. If it is locked, there is no other way. You should have a remote control.
To select a proper universal remote control, you should know about the number of digits to its set-up codes. There are 3 digit, 4 digit, 5 digit, 2 digit and even single digit codes, to some brand devices. After confirming this, check the sites linked here. Both the sites have set-up code list and set-up procedure to many popular brand remote controls. Check which brand remote control has set-up code/s to your device brand, and buy that one according to availability? Brand name of the remote control isn't a matter, but it should have set-up codes in its code list, to the device brand you have.
Please note: Every new universal remote control will have set-up code list, and set-up procedure along with its pack. Never accept a remote control, that hasn't both of this. For more details about the set-up codes, visit the site http://electrohelponline.blogspot.com/ Check this site too. http://remotesearch.blogspot.com/ Universal remote controls are available at most of the electronic spare part selling shops.
If you wish to buy its original remote control, contact the authorized service centre, or authorized dealer to your device brand. They can either give you a genuine remote control to your device, or can direct you, from where can you purchase a suitable one.
Posted on Nov 28, 2014
What's wrong with my TV
Open internal fuse or power supply failure
Jul 07, 2016 | Televison & Video
Bang & olufsen Beovision 7- Unable to turn television on When trying to turn the television on using the remote. WAIT appears on the top right side of television.
Nice TV set. Try first unplugging the tv for ten minutes, this quick hard reset will drain power from tv, and sometimes it solves the problem when TV is freezing on startup.
If this soes not work there must be a service reset procedure.
Aug 17, 2008 | Televison & Video
Bang and olufsen beosound 3000 does not read cd and loading stops. Can you help? Thanks
I never had like that. But "normally" there may be two reasons: CD fault or control board fault. Sometime main control keeps memorized wrong data and (in my Ouverture) CD unit simply is not responding and not loading - standing still. No way to move on except plugging off the power, press CD start on remote with no power, plug in power and try again. It clears bad data. I suspect it happened few times when I stopped CD player by remote or local main switch off.
Aug 19, 2014 | Bang and Olufsen Beosound 2000 Shelf...
We have a bang and olufsen beovision 7 40 inch tv. when we try to connect our laptop through vga port the tv appears blank without any display, tried connecting the laptop through dvi port also. The...
First, try setting your monitor refresh rate at 60Hz using a known-working monitor. (The VGA input of the Beovision 7 is recommended for 60Hz refresh rate). If this fails to produce output from the Beovision 7, it is very likely, your video driver's resolution is set too high for the Beovision 7 to display signal. If you are using the Beovision 7 as your primary monitor, first connect a known-working monitor to the computer and reduce the resolution to 1024x768. Once you have changed the resolution, try connecting the Beovision 7. If you get video signal, increase the resolution incrementally until you find the maximum resolution the Beovision 7 will handle.
IF YOU ARE USING THE BEOVISION 7 AS A SECONDARY MONITOR USING EXTENDED DESKTOP, reduce the resolution on Monitor 2 output to 1024x768. If video appears on the Beovision 7 at that resolution, incrementally increase the Monitor 2 resolution until you find the maximum resolution the Beovision 7 will accept as a secondary monitor.
Jul 14, 2011 | Televison & Video
Hello i have a black line runnig across my screen horizontally. Some times disapperar for a few seconds and tv is normal and then comes back. Some tines is black and some times l flashes in red, ...
IF YOU HAVE A SOLID BLACK LINE RUNNING VERTICALLY THEN YOU HAVE A FAULTY MATRIX INVERTER. IF CENTRAL THE MAIN VERTICAL INVERTER NEEDS CHANGED. LEFT = LEFT VERTICAL INVERTER RIGHT=RIGHT.........
ANOTHER WAY TO GET THIS FAULT IS WORN OR DAMAGED RIBBON/PLASTIC GOING FROM THE SCREEN MATRIX TO THE INVERTER
HOPE THIS WILL HELPOUT IN SOLVING THE PROBLEM...
May 18, 2011 | Televison & Video
I recently purchased a Panasonic DVD Recorder Model DMR-EZ48VEB to use with my Bang & Olufsen Beovision 8902 TV. Having set up the recorder the DVD remote control would not work because the DVD...
You said you have the operating instructions, try this,instead of doing the manual entry of your code, try using the CODE SEARCH method for each one....hope this was helpful.....
May 23, 2010 | Televison & Video
Beovision MX 7000. Crackling noise emanating from speakers followed by picture jump. This happened on a couple of occasions then one final crackle, slight burning smell, no picture - power light pulsing...
Check 2 areas,capacitors c102 c103 c104 for burnt joints all in deflection cct.and burnt connector at scan coil at tube end,if its this second problem c102 and line output transistor may also be faulty.
Mar 12, 2010 | Bang and Olufsen Beotalk 1200 Digital...
Bang & Olufsen Beosound 3000 Ouveture CD Problem....Please Help!
Chances are you will need a replacement cd mech assy to fix this problem assuming you have already cleaned the laser lens(cotton bud with ethyl alcohol or isopropanol).dont know of universal remote for b&o but some specialist remote replacement companies do one for beolink1000 which will operate your product.
Feb 15, 2010 | Bang and Olufsen Beosound 4000 Shelf...
MY beocenter 2 does not recognise any disk
I have blue lines across my Beovision 3 TV screen
Nov 04, 2006 | Bang and Olufsen Beosound 4000 Shelf...
Televison & Video Logo
37 people viewed this question
Top Televison & Video Experts
Electro Med Services...
