Question about Fujifilm 8.1mp Digital Camera3x Optical Zoom5.1x Digital Zoom A860 4my12
A lens and focus fault on my fuji A860
Have tried new batteries and switching on and of the lens moves but will not retract when switched of neither will she take a snap just makes a buzzing noise
  • 76 Answers
SOURCE: zoom lens won't retract
Usually down to the lens block assy being faulty.Is the lens retracting and opening properly?.It usually turns out to be worn gears in the lens drive assy or the result of a fall.Either way will be expensive repair!My advise is check and see whether camera is covered by insurance for accidental knocks.,
Posted on May 11, 2007
SOURCE: fuji finepix s7000
I just then took the previous posts idea and pulled the lense off and cleaned light sand out of it , extended lense as told, put back together and turned on.so far focus seems good
Posted on Jun 02, 2008
  • 12 Answers
SOURCE: FinePix A500 Fuji camera "focus error"
Check out this link: www.digitalcamera-hq.com/digital-cameras/fuji-finepix-z1_question.html?qid=4289
After the basics, try dropping the camera on a carpeted area from about 2-3 feet. It worked for my Fuji Finepix A500 and 90% of the responders on the link. Everything on the web said it would cost ~$100 to fix. I was in the process of researching new cameras to buy and had nothing to lose by dropping it on the floor.
The error may be caused by debris in the zoom mechanism preventing it from working. Dropping the camera loosens the debris and voila!
Posted on Jul 07, 2008
  • 244 Answers
SOURCE: I have a fuji finepix F460 which displays 'zoom
Either the focus mechanism has jammed or the drive gear has sustained damage. Only way to be sure is to open it up and have a look. I have photos if you want to have a go yourself. my email is listed in "THE ONLY WAY I KNOW HOW..." In the tips & tricks section. Dave
Posted on Apr 21, 2009
  • 4090 Answers
SOURCE: My Fuji F50 has developed a fault whereby it's
Works on any camera like this
OK you are probably going to think I am loony giving you this advise But No I am completely sane!
Get a can of compressed air OR acces to a compressor at your local garage Get them to fit the triggered air blower tool to it.
Blow around the lens in all the extension joins the firmly slap it in the palm of you hand with the side of the camera making contact with you palm. Do the procedure two or 3 times and inbetween the slaps turn it on to activate the lens mechanism. I have now fixed about 80 of these cameras with this method. I obtained the fix from Sony who charge $90 to do exactly the same. Keep at it as it will eventually work. One tip, make sure the battery is charged before you do this.
Please rate our help to keep the FREE service online ++++Thanks for using FIXYA
Posted on Sep 10, 2009
Showing lens control error fuji finefix HS 30 exr
Does it say Lens control error, or does it say Focus error, turn off the camera and turn it on again?
The last can happen when you touch the lens barrel. When the lens does not retract when you shut down the camera, perhaps the battery is exhausted or the barrel got stuck.
Try to recharge the battery and start all over again. If nothing goes, try carefully to pull out the lens a little Less then one millimetre. or gently press it back a little. Be aware the camera is a very delicate piece of equipment, so don't use force, because that could damage the camera definitive.
In the manual, it says you should contact FujiFilm, when the error comes back after you switched off and on. So if nothing helps, that is the last option. Visit a repair shop from Fuji, or bring a visit to your dealer.
Dec 27, 2013 | FUJIFILM FinePix F300EXR Digital Camera
Turn off camera and turn back on will not go away
I guess your camera has the message turn off the camera and turn on again.
This message will occur when the camera has any malfunction. Could be caused because you obstructed the lens while focusing or zooming. Could be lots of other things.
If the switching is not enough and you observed the lens is retracting complete when switching off. Please remove the battery for a little while. Perhaps you could use the time to recharge the battery. Then when you replace the battery and the camera still gives this error, there is only one thing you can do: Please contact a FujiFilm dealer.
Nov 19, 2013 | Fujifilm Finepix S2980
Fujifilm ax280 won't turn on
You think the lens got stuck. Don't use force, but try if the lens will move a little when pulled or pushed. Take care, there are gears on the lens and if the motor does not work, you will definitely damage some gears. You need power in the camera, to let the motor retract the lens.
If nothing works, you should go to your dealer, or contact Fuji.
I sometimes read you could try slamming your hand where the camera sits in, while switched on, but if you don't know enough about how everything works in your camera, don't do this. Because you end up with a camera that can't be repaired.
Nov 05, 2013 | Fuji Cameras
Zoom lens won't retract on fujifilm f410
This indicate that there will be some problem with your camera Lens. Try to follow these steps to resolve the issue:-
1) Switch the camera OFF and then ON again. (May be your camera lens is struggling to extend)
2) Load new or fully charged batteries.
Else your device need service (repair)
Rating the solution is highly appreciated....Good Luck
Mar 03, 2010 | Fuji FinePix F410 Digital Camera
I have a fuji finepix F460 which displays 'zoom error' and the lens is not retracting fully. I have removed and refitted the battery and tried all buttons but the lens doesn't move. Is there a reset...
Apr 19, 2009 | Fuji FinePix F460 Digital Camera
The lens will not retrieve, screen message is Focus Error
the lens will not retract and camera is not functional (no picture ondisplay, and does not shoot) , and you already tried replacingbatteries with a new fresh set (ensure please) , and then restartingcamera with no memory card inside, then camera is faulty.
Try aneasy fix by pushing gently the lens (do not force them, just help them)while you turn off camera at same time. Try also switching the modeselector.
If still no luck , then the camera must be disassembled to fix the problem.
Possible reasons are :
  • Faulty lens mechanism or jammed lens (camera usually turns off by itself in this case)
  • Main board faulty.
  • Ribbon cable to main board broken or connector defective.
  • If there is no power at all it is the connector from batteries to main board, this is also a ribbon cable.
The pound 50 repair is not too bad , there is need to work at the camera a good number of hours to disassemble it and fix it. About the 30 pounds I do not know , I should inspect the camera to say.
If you want an alternative estimate for comparing with the one from from Fuji , or from a third party like Advance Camera here :Advance Camera Repair you can book the repair online.
Apr 10, 2009 | Fuji FinePix F700 Digital Camera
'FOCUS ERROR'
If bought this at best buy and are still under your MFG warranty they can send it out to repair, or if you have their service plan, nothing you can do, this needs to be sent to a repair facility...
May 28, 2008 | Fuji FinePix A500 Digital Camera
Lens won't retract
I've had this problem before, and it was solved by charging the battery fully then putting it back in the camera and switching it on.
If not, chances are the motor is knackered, and it's probably now more economical to buy a new camera.
May 27, 2008 | Fuji FinePix F20 Digital Camera
Camera keeps shutting off
Have you fully charged the new batteries
Nov 03, 2007 | Fuji FinePix A345 Digital Camera
Lens/focus err
I had the exact same problem in September 2007 (must be built in obsolence). I sent mine to Fuji's repair center to get repaired. Unfortunately, it becomes a decision of whether to get it repaired or buy a new one (repair cost ~$160). The kicker is now the flash will not work. I get a message/warning of camera shake. The manual says it's something to do with the shutter speed but no mention on how to correct it. So it becomes another decision of do I throw more money at it (send back for repair) or bite the bullet and buy a new camera.
Oct 23, 2007 | Fuji FinePix F700 Digital Camera
Fujifilm 8.1mp Digital Camera3x Optical Zoom5.1x Digital Zoom A860 4my12 Logo
47 people viewed this question
Top Fuji Cameras Experts
Greg Cann
Greg Cann
Steven Wander
Steven Wander
Are you a Fuji Camera Expert? Answer questions, earn points and help others
