Question about Dryers
How do i fix what appears to be sparks and or flashes in the back of my dryer drum
Havent tryed anything doing some homework first.is this normal?
  • pat capali
    pat capali Nov 27, 2014
    thx. for input gil,not alot of noise but sqeaking then at times it stops for abit.
  • Dryers Master
  • 3,368 Answers
That does not sound good, I would get an appliance tech in to check it. It may be a bad bearing but you would have a lot of noise with it. Do not use it until you know it is safe.
Posted on Nov 27, 2014
  • pat capali
    thx. for input gil,noise comes and goes when in use.but i unplugged more worried about the sparks or flashes being seen.maybe not worth repairing
My AEG T37400 lavatherm standanlone tumble dryer works for a turns of the drum then stops.
Alarm conditions during operation of the dryer
The LEDs begin to flash if one of the following malfunctions occurs:
  • NTC open (the LEDs flash in sequence from right to left)
  • NTC short-circuited (the LEDs flash in sequence from right to left)
  • If the START button is pressed for more than 20 seconds while a cycle is in operation all the LEDs flash.
25679338-hf2jxxovvq5cn05mugly0fcq-5-5.jpg If the microprocessor identifies one of the conditions listed above, operation of the dryer is interrupted; the LEDs continue to flash in order to warn the user of the malfunction.
If the error is eliminated, the dryer returns to normal operation when the programme selector knob is turned to RESET and the drying cycle is re-selected.
Dado
May 04, 2015 | AEG Dryers
Washer making loud noises, but still works... For now. Just completed a normal hot/cold wash and spin/rinse cycle with no problems other than it making a number of cyclic noises throughout, until the
Good morning Mike
The thought that comes to mind is, there are some coins,nails or screws rattling about in the machine. I have not emptied all pockets. It would be wise to take a look at the troubleshooting ages in the manual. Kolbrun
Feb 05, 2015 | Kenmore 700 6972 Dryer
My dryer does not heat. Clothes do not dry.
Pull the dryer out away from the wall. Unhook the vent from the dryer completely. Do not put anything over the dryer exhaust on the back of the dryer. Do a normal load with the vent unhooked. If it dries better or ok like this then the problem is in the dryer venting. Like a blocked vent pipe or a smashed or restricted vent hose. If the vent doesn't make a difference, then check the blower wheel for excessive lint build up, check that there isn't anything stuck to the air intake baffle inside the drum, (i.e. the screen on the back wall of the dryer when looking into the drum). Check the lint filter chute for blockage. Check that the heating element isn't shorted to ground. Check the exhaust temperature of the dryer. A meat or pocket thermometer can be used for this. It should cycle approx between 120 degrees and 160 degrees ( without clothes ). Check that the drum seals are not worn out.
Dec 06, 2010 | Kenmore Dryers
The machine appears by the sound of it to be only turning at half its normal speed clothes take longer to dry
You could have something inside the dryer dragging on the dryer drum. You can unplug the dryer and lift the top *(your dryer lid is held on by spring clips just push up on the front edge and it should pop open, tilting up and back) Look around for anything in the area of the drum that doesnt belong there...a sock...a pair of shorts...dryer lint...you get the idea.
If you dont see anything you may have a drum roller going bad. That will take a bit of dexterity to check out but you should be able to see if one of the roller looks like it isnt turning. Give the drum a turn by hand and see if a roller is hung up.
Good luck and be careful.
Mar 01, 2010 | Dryers
Frigidaire FDE336RES2 Dryer marking Clothes
Excessive lint on or near the heater coils will send smoldering lint onto the clothes. Use a flash light and go inside the drum to see the heating coils or lifting the top up who should be able to see the lint build-up on the coils. These need to be cleaned.
Nov 10, 2009 | Dryers
TIMMER RUNNING BUT NOTHING DRY
Q - Dryer takes too long to dry or multiple times to dry a load
A1- Pull the dryer out away from the wall. Unhook the vent from the dryer completely. Do not put anything over the dryer exhaust on the back of the dryer. Do a normal load with the vent unhooked. If it dries better or ok like this then the problem is in the dryer venting. Like a blocked vent pipe or a smashed or restricted vent hose.
A2 - If the vent  doesn't make a difference, then check the blower wheel for excessive lint build up, check that there isn't anything stuck to the air intake baffle inside the drum, (i.e. the screen on the back wall of the dryer when looking into the drum). Check the lint filter chute for blockage. Check that the heating element isn't shorted to ground. Check the exhaust temperature of the dryer. A meat orpocket  thermometer can be used for this. It should cycle approx between 120 degrees and 160 degrees ( without clothes ). Check that the drum seals are not worn out.
thanks and please do not forget to accept the solution
Apr 03, 2009 | Whirlpool LER5636P Electric Dryer
Our 2-year old Frigidair dryer, Model # GLER341A was working fine-I removed the dry clothes, put in the next load, turned it on and it sounded like a load of chains was in it.. When I opened the door...
could be rear drum bearing. possible heat element broke and is rubbing on back of drum those light you say you saw was probably your heat element arcking on the metal in other words sparking
Jan 12, 2009 | Frigidaire GLER341A Electric Dryer
Dryer is shooting sparks and making a scraping sound
hoover washer drier is making a scraping noise and a spark from the bottom of the machine everytime the drum spins, does anyone know what this cold be. thanks.
Apr 05, 2008 | Kenmore 83142 Electric Dryer
Brother HL-5240 drum light flashing
Normally clearing the drum count the machine has to be on open front cover as if to change the drum press and hold the button in for about 10 second then release and shut the door. This should reset the count if not please get back to me and I'll check the service manual to see if anything in that.
Thanks J
Jan 29, 2008 | Brother HL-5240 Laser Printer
Drum Stuck
Frigidaire GLEQ2152ES Electric Dryer. I have checked the dryer pretty thoroughly and can't find anything jamming. I believe it is a bearing. Something on page two of the manual. If I can, I will repair it myself. That area has been diffucult to access.
Thank you
Jan 25, 2008 | Frigidaire GLEQ2152ES Electric Dryer
Dryers Logo
41 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
