I have the above problem also ie Washing Machine stops after a moment or two. I tried the above 'Fix' but to no avail, the problem remains. The filter isn't blocked and the drain pum
Have made sure that the filter isn't blocked. Have powered down for a few hours and tried again. Have tried the solution supplied with regard to unplugging the blue wires from the PCB. All to no avail
  • 693 Answers
If you can check the motor by removing the belt,then put in spin only mode.with no load on motor it should reach full speed without cutting out.if it cuts out.you may need to replace the brushes.there should be telltale signs of fine black deposits in the motor area.sometimes brushes can be okay but the dust emitted can lay within motor and cause problems.the motor should be inspected and cleaned.if still not right you may need to replace the motor.very rare for the control panel to fail but worth checking for dry joints at the relays.again bushes can cause undue load on motor and cause relay to trip thus preventing further damage.
Posted on Nov 27, 2014
Krazytech
  • 725 Answers
SOURCE: I have a whirlpool front load washing machine model WFW8300SW00
Hay Crab.
what I have found is that the washer thinks it is not pumping out .. if your drain pump is clearly removing the all the water in a good time... then the problem is your pressure switch...it is telling the computer that it still has water in the machine...
replace the pressure switch and it will solve your f21 error.
It is a round unit on the right hand side on top...with a tube and wires going to it...let me know if it helps
Posted on Apr 05, 2008
  • 497 Answers
SOURCE: Hotpoint Aquarius WT540 washing machine. will not fill with water
Sounds like a timer switch malfunction.
Posted on Sep 06, 2009
  • 4 Answers
SOURCE: miele W1712 washing machine drain fault
Just had the same problem, after Much patience and persistence I found the blockage at the y piece that joins the pump to the outlet hose air trap towards the top of the machine LHS with the top and cover off.
It was clogged solid therefore no back pressure on the top little ball valve (between the air trap and the outlet) therefore no seal therefore norain therefore a drain-fault that persists regardless of a cleaned pump filter.
Posted on Dec 04, 2009
SOURCE: Whirlpool washing machine "clean pump" error light.
take top off machine. look down right side and you will see a disc about 50 mm in diameter, attached to this is a small flexible rubber pipe, take this off at the disc and blow through it,( you will need some type of pipe to connect to the rubber pipe).this worked for me with the very same problem.
Posted on Mar 13, 2010
  • 35 Answers
SOURCE: washing machine not draining the water
the weater pump is bad replace....
Posted on Apr 13, 2010
Its stops when it reaches in 39 minute the function set on cottons what is the problem
Try resetting the mainboard by removing the wall plug overnight. May also be a faulty lid switch if it is a top loader.
  • Hello, my washing machine stops completely when it reaches ... www.shopyourway.com > Manage My Life > Questions ... my washing machine stops completely when it reaches the pause cycle, ... Answered in 5 minutes ... Kenmore washing machine 417 44252500.
  • Washing machine stops mid cycle - White Goods Help www.whitegoodshelp.co.uk > ... > DIY Washing Machine Repair Help Possible causes when washing machine stops mid cycle by a repairman with 30 years experience.
  • What could cause my washing machine to stop before the ... diy.stackexchange.com/questions/21181/what-could-cause-my-washing... What could cause my washing machine to stop before the ... i.e. it never reaches the end of the cycle ... What would cause my washing machine to stop at the rinse ...
  • Washer Stops Mid Cycle - Repair Parts - RepairClinic.com www.repairclinic.com/...A-Washing-Machine/50---/Washer-stops-mid-cycle ... listed below for the symptom Washer stops mid cycle are ordered from most likely to least likely to occur. ... Electrolux Front Load Washing Machine Disassembly
  • once my washing machine reaches the rinse cycle, about 3 ... https://answers.yahoo.com/question/index?qid=20080526150940AA3izVT
    • RESOLVED
    • 6 POSTS
    • 5 TOTAL ANSWERS
    2008-05-26 · Once my washing machine reaches the rinse cycle, about 3 minutes after ... Once my washing machine reaches ... My washing machine stops after the ...
  • Common Problems to all Washing Machine Brands ' Washing www.appliancerepair.net/washing-machine-repair-2.html Washing machine designs vary widely, ... but stop agitating after a few minutes and fill some more. ... stop the spin cycle and unplug the washer.
  • My washing machine will not spin and now it does not stop ... www.shopyourway.com > Manage My Life > Questions My washing machine will not spin and now it does not stop when it reaches the water level. ... Answered in 5 minutes
  • washer stops in the middle of washing cycle - Appliance ... forum.appliancepartspros.com > ... > Washer Repair
    • 6 POSTS
    • FIRST POST: 2012-02-07
    2012-06-22 · Appliance Repair Forum > Appliance Repair Help > Washer Repair » washer stops in the ... but when the timer reaches 24 minutes left to ... Washing Machine stops ...
  • LG Washer Stuck Timer 2 - YouTube Youtube
    • BY SBUBANDIT
    • 14 MIN
    • 4.9K VIEWS
    2012-08-29 · Video embedded · In this video the washer display shows 8 minutes remaining in ... machine stops and turns ... 10kg Top Load LG Washing Machine
  • http://www.bing.com/search?q=washing+machine+stops+when+it+reaches+39+minutes&qs=n&form=QBRE&pq=washing+machine+stops+when+it+reaches+39+minute&sc=0-47&sp=-1&sk=&cvid=04BC47135B524BD8B5BAC3759F010C1B
    Jun 10, 2016 | Washing Machines
    Ge 9 min light flashing
    I broke down and had a technician come and fix it for me. It ended up being a loose wire in the panel.
    Apr 22, 2013 | GE WBSE3120B Top Load Washer
    Washing machine not draining water
    What is the model number of your unit?
    Nov 27, 2012 | Washing Machines
    Door remains locked and machine doesn't start running
    Did you check and see if the child lock is active?
    Mar 25, 2017 | Zanussi FJ1254W Front Load Washer
    Kenmore Side x Side Model 106.50522101 Product says "Filtered Water" through the door, but the water tastes bad. Cannot find where the filter is located and cannot figure out how to remove the...
    On your refrigerator the filter isn't in the grill below the grill it is in the ceiling of the refrig. section above the top shelf in the upper right corner
    The part number for the filter is 2206048 its available at your local appliance parts store,sears,
    Lowe's or HomeDepot. Just take in the old one to match it up. Its also available online from any of the places in this link; http://www.google.com/search?q=2206048&sourceid=ie7&rls=com.microsoft:en-us:IE-Address&ie=&oe=&rlz=1I7ACAW_enUS360US360#q=2206048&rls=com.microsoft:en-us:IE-Address&oe=&rlz=1I7ACAW_enUS360US360&um=1&ie=UTF-8&tbo=u&tbm=shop&source=og&sa=N&hl=en&tab=wf&bav=on.2,or.r_gc.r_pw.&fp=e812f2706985ae2e&biw=1093&bih=538
    Aug 14, 2011 | Refrigerators
    Water sensing level not working on Fisher & Paykel Eco Intuitive washing machine . The water just keeps filling up until I stop it manually . We can't use the machine to wash clothes as the Service...
    Your pressure value switch is malfunction. First thing you can try that is cheap to fix is to try clean the hose that connects to the outer tub. A lot of times there is algae develops after years of washing.
    May 07, 2011 | Fisher and Paykel Fisher Paykel Intuitive...
    Nec nw-891 washing machine will not complete the programmed cycle
    Apparent malfunction in the timer circuits. Specific Component replacement not available.
    Jun 30, 2009 | Washing Machines
    Washing Machines Logo
    Top Washing Machines Experts
