Why wont manual switch work
Just pressing on off manual switch
  • 3,382 Answers
Assuming it is always on the contects would be welded closed if it doesn't come on the switch may be bad or the element is bad.
Posted on Nov 27, 2014
Maytag bravos electric dryer powers on but will not run no codes on it, just wont run
Check that door is fully closed. Or turn on dryer and manually press the door switch to see if that works. If not than it is that switch. A thermoswitch will also do that
Mar 30, 2014 | Dryers
Wont shift out of park, brake lights dont work
your brake switch is broken, its on the top of brake peddle. It wont shift from park because you need to press brake to shift from park and with the switch not working it doesn't know your pressing the brake. check connection on switch if its fine you need to replace.
Mar 24, 2013 | 1998 Land Rover Discovery
My microwave wont turn on. the power works, clock, timer and all electrical is working, it just wont turn on.
Most likely you have an interlock microswitch problem or a latch problem. as you just open or just close the door VERY slowly listen for 3 distinct clicks one for each of the 3 interlocks. Two you will hear as you press the door open button and the last one you will hear as the door just opens or closes. If you do NOT have 3 clicks you have a bad micro-switch.
The micro-switches you can purchase on line here:
http://www.repairclinic.com/Sharp-Microwave-Switch-Parts
Owners manual: (Provided only for telphone contacts in first 2 pages.)
http://files.sharpusa.com/Downloads/ForHome/HomeAppliances/MicrowaveOvens/Manuals/mic_man_R530ES.pdf
I think you just have a simple micro-switch problem. However... if the latch assembly that holds the switch is cracked or broken it will have to be replaced. I have seen the plastic latch assembly fail causing the switch not to work properly.
Thanks for choosing FixYa,
Kelly
Jun 28, 2011 | Sharp Carousel R530EST Microwave Oven
Rear brake lights wont work fuse good new bulbs?
There's a brake light switch mounted near the shaft that your brake pedal is mounted to. It's a plunger switch, and it should be easy to find. Press it in manually and your brake lights should come on (if not, the switch needs to be replaced). If the lights come on when you press the switch, press it a few times and/or lube it with a shot of WD40 or a similar product, and chances are that it will start working again. If not, the switch is inexpensive and easy to replace, and you can find the right one for your vehicle at just about any parts store.
Dec 14, 2010 | 2006 Kia Sorento
Car wont start after getting a new key and replacing batteries -
hi well this is a bit long so if you can bare with me i will try explain how to , clear system to decode, and recode as this is what it sounds like that the coding has gone from the ignition key....ok here goe's
to sync key with car depress lock or unlock button manually lock the drivers door within 30 seconds of the above system should now work....if not do next bit
switch ignition on ( using non chip key ) manually lock drivers door using key ( another one, hopefully you will have more than one) press unlock button 5 times, in one second intervals indicators flash 5x for every time signal is received switch ignition off and remove key
that's the de-programming done...
to de-program the system if above fails..........
switch ignition on ( use key without remote ) manually lock drivers door using key to be synced with car complete the following within 30 seconds of doing above within 5 seconds press the unlock button on key indicators should flash once wait 5 seconds press unlock button once to confirm programming vehicle should unlock this also will confirm deactivation of programming mode switch ignition off remove key..that should be it, then try new programed key in ignition.
to re-program system and sync with key switch ignition on manually lock drivers door using key ( another one, hopefully you will have more than one) press unlock button 5 times, in one second intervals indicators flash 5x for every time signal is received switch ignition off and remove key
that should be it, if no joy then will have to main dealer i am afraid...hope this helps
Jun 07, 2010 | 2001 Audi TT
Brake lights wont work when pressed. changed the
By the brake pedal is a brake light switch. replace that item
Mar 17, 2010 | 1990 Toyota Camry
Wont open when I press door opener. makes a clicking sound and reset light is blinking
I, PRESS THE REMOTE THEN UNIT START TO BLINK THE LIGHT. ALSO IT WORK WHEN HOLD THE MANUAL SWITCH TO CLOSE AND OPEN THE GARRAGE DOOR.
Oct 27, 2009 | Chamberlain Powerdrive PD422D 1/2 HP...
My rear spoiler wont lift automatically or manually,even when i press the rocker switch
my spolier for my 996 4s wont go down, does anyone know where the manual buton?
Jul 06, 2009 | 2004 Porsche Boxster
LG REMOTE WONT SWITCH FROM AM/FM TO DVD
HI THERE, I FIXED THE PROBLEM MYSELF BY KEEPING THE FUNCTION BUTTON ON THE DVD PLAYER PRESSED UNTIL IT FLASHED ""MODE"". THEN I PRESSED IT IN SEQUENCE TILL IT CAME UP WITH DVD/TV THEN IT AUTOMATICALLY SWITCHED OVER TO THE DVD FUNCTION MODE. ALL DONE. BUT THE TV/DVD BUTTON ON REMOTE STILL ISNT FUNCTIONING OR CROSSING OVER CHANNELL. HAVE TO DO IT MANUALLY VIA DVD PLAYER. EVERYTHING ELSE WORKING EXCELLENT. THANKS ANYWAY. HOPE THIS INFORMATION WILL BE OF USE TO YOU IN THE FUTURE. I CUD CHARGE YOU FOR THIS INFORMATION BUT I WONT THIS TIME.... LOL. MERRY CHRISTMAS AND GUDBYE...
Dec 13, 2008 | LG Televison & Video
Tv wont switch to Sky when remote control is pressed
Hi.
On the sky box do the following.
Check scart to tv is in the correct socket marked TV.
Try pressing services
then system setup
then picture settings.
Then try switching scart control to on or off.
If this sorts it great. If it doesnt check scart lead has all pins wired & not only A few.
http://dysonmanuals.llc.nu
Chris..
Jan 19, 2008 | Televison & Video
Heating & Cooling Logo
37 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
