Question about Kenmore 1/3 hp Food Waste Disposer
Slow drain on garbage disposals side of sink - Kenmore 1/3 hp Food Waste Disposer
  • Kenmore Master
  • 3,368 Answers
Try running ice cubes through it, it will make a lot of noise but that should clean it out. Please slowly run the cold water with the ice.
I do not like chemicals if they can be avoided. d
Posted on Nov 27, 2014
Why does kitchen sink drain water from drain side to garbage disposal side
The two drains are connected, but below the disposal. Likely if it's not draining down, you still have a clog, and the person the "cleared" the drain didn't.
Sep 03, 2014 | Garbage Disposals
Tip
Cleaning and preserving a garbage disposal
Once a week or so turn the tap on at the sink and turn the disposer on. Then drop a cup of ice in the disposer. The ice will remove any grime and build up and the water will wash it all down the drain.
on Feb 20, 2015 | Garbage Disposals
How to fix a stuffed garbage disposal?
It should have come with a Allen wrench. Be sure it is off. Insert it in the bottom into the center hole. Move it back and forth several times until it frees up. Remove wrench and try, you may have to do this several times. Also be sure the unit is reset before turning on. If it does nothing nor makes nay noise it is probably tripped.
Aug 08, 2014 | In-Sink-Erator Evolution Pro Cover Control...
Our new kenmore garbage disposal shoots the water up rather than sucking it down
Check the drain is not clogged.
Does sink opening have splash guard?
Check that plumbing is vented as required by code:
http://waterheatertimer.org/How-to-repair-and-install-Garbage-disposal.html#slow
Gene h
Mar 23, 2014 | Kenmore 3/4 hp Food Waste Disposer
Garbage disposal is clogged
Does the other side of the sink drain? Are you sure it's the disposal thats plugged? If the disposal is plugged you can turn it on and plunge it a few times and see if that makes a difference.
Jul 07, 2013 | Garbage Disposals
Voltage
Motor will run with 80% rated voltage that shows on nameplate.
Typical household water heater nameplate will show on side of disposal
http://waterheatertimer.org/How-to-repair-and-install-Garbage-disposal.html#voltage
http://waterheatertimer.org/See-inside-main-breaker-box.html
Add a comment and describe voltage that shows on side of device.
May 06, 2013 | In-Sink-Erator InSinkErator Evolution...
Garbage disposal runs but will not take garbage down
can you turn it on for me? I would like to see and hear whats going on to better help diagnose, more than likely the "blade" that spins has detached from the disposal motor assembly or the "blade" my be caught/stuck in place, to resolve this issue.
Unplug the disposal(should be plugged in under the sink)Grab a bucket to place under sink to catch waterremove the sink pipe assembly+disposal (remove the disposal)the water should drain into the bucket from the sink.remove and clean the disposal trap, looking for obstructions while you do so.after cleaning and searching for obstruction, reassemble the unit as it was making sure to reinstall all washers, guards and bolts, after you reassemble the unit plug it back in and test it, if you get the same results then there may be a strong possibility the unit suffers from a defect or damage in which case you may need to replace the whole unit or just part it all depends... good luck... more question just ask
Mar 29, 2013 | Garbage Disposals
Kenmore 1/3 hp Food Waste Disposer Logo
342 people viewed this question
Top Kenmore Garbage Disposals Experts
Gene Haynes
Gil Shultz
ray gallant
Are you a Kenmore Garbage Disposal Expert? Answer questions, earn points and help others
