What do it mean if on the upper right corner of my thermostat(in the plastic white frame, not the screen) a red snow flake light light up
  • 38 Answers
First I need to know brand and model of ur thermostat.
Posted on Nov 27, 2014
  • Manon Martel
    Manon Martel Nov 27, 2014
    Visionpro serie TH8000 it's a thermostat for my heat pump
  • Manon Martel
    Honeywell visionPro serie TH8000, never saw this light come on before, book doesn't mention anything about it, heat pump had stop working during the night, cleaned te filter this morning, but can't make it work now, when i put thermostat on, after a few min this light come on
No heat or a.c..rev batts it says su and pic of snowflake?
The snow-flake means the thermostat thinks it is working...
9 hours ago your unit said "SU"
(most likely "Sunday"....
No: Not INTUITIVE... (I had to go look also).
((now twice re-re-tired... but 2 careers in ALL things ELECTRIC)).
My GUESS is right now MINE says "MO" (Monday... ignore that).
You will need to check your circuit breaker for the compressor...
Sometimes my fan will run... and make all the appropriate noises
but the fuse box right next to the unit... one of my FUSES (USA = 220 volts) will be blown...
>> ((Better if you have breakers))
>> Breakers turn ALL-THE-WAY - OFF... the back - ON.
If you buy yourself one of those "no touch" circuit testers...
you can waive it like a magic wand... Green means no power!
Red means DANGER... CAUTION. (Klein NCVT... mine!)...
NCVT = NON-CONTACT Voltage Tester
Shut off the house main... if you must.
I'm pretty sure it will take less time to rest all those clocks than one trip to the ER (emergency room: I'm just saying)... or WORSE!!
Just be careful...
Fuse boxes are for EXPERIENCED folks (I have ALL the scars from the EXPERIENCES... enlightening though they may be)... I'd rather you remember hiring a professional ought to be more pleasant than ELECTROCUTION...
Comment me back... I check at least daily: I'll be here!
Amazon com ac no touch tester Tools Home Improvement
Apr 25, 2016 | WHITE-RODGERS DIV White Rodgers 1f82-261...
On the white frame upper right corner, a red snow flake came up, can't find in the book what this relate to.
I am only guessing but I belieive that indicates you are operating on the aux heat, could be electric or gas. Mine is gas. This will be consistent at its set temperature which should be about 30F depending on what part of the country you live in. Put a note pad and each time you go by note the outside temp and the indicator as on or off. You will eventually find the problem. You may also have an option to drop the fuel pump and just run on aux heating, but there may also be an indicator for that.
Nov 27, 2014 | Heating & Cooling
I have the 1F79 thermostat, how do I change the reading to Celcius?
Display screen has "Malf" in top right hand corner of screen. what does this mean?
Nov 23, 2010 | White Rodgers White-Rodgers 1F85RF-275...
Alight i have a 1999 mercury cougar and a light popped on the other day and i have no clue what it means. the light is on the headliner bundle of lights. please help. thrashbash_sk8r@yahoo.com
If the light on your cougar has a wrench on it then this is your "Interval Maintenance light", it comes on when your car is due for a scheduled maintenance as prescribed in your owners manual (oil changes, transmission fluid, etc). Another light located on the upper cluster is the "Outside Temp Freeze Warning Light", this light looks like a yellow or red snow flake, if this light is yellow it means it's nearly freezing outside (so watch for slippery roads), and if this light turns red it means that it's 32 degrees or lower
Dec 14, 2009 | 1999 Mercury Cougar
What does the flashing red hand in the upper right
The flashing red light is warning you that the shutter speed will be too long for handholding the camera. Put the camera on a tripod or other stable surface, and/or use the flash.
Nov 08, 2009 | Nikon COOLPIX S9 Digital Camera
I got a 2002 mercury cougar and there is a light that turns on an off once in a while it's the second 1 next to the wrench it looks like a snow flake what dos it mean
The yellow/orange snowflake means its between 42 and 33 degrees and the red snowflake means it's 32 degrees or below (fahrenheit).
Jan 28, 2009 | 2002 Mercury Cougar
Heating & Cooling Logo
114 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
