On the white frame upper right corner, a red snow flake came up, can't find in the book what this relate to.
This is a thermostat for heat pump
  • 3,368 Answers
I am only guessing but I belieive that indicates you are operating on the aux heat, could be electric or gas. Mine is gas. This will be consistent at its set temperature which should be about 30F depending on what part of the country you live in. Put a note pad and each time you go by note the outside temp and the indicator as on or off. You will eventually find the problem. You may also have an option to drop the fuel pump and just run on aux heating, but there may also be an indicator for that.
Posted on Nov 27, 2014
I installed a Honeywell RTH230B model thermostat. The heat works fine, but the AC is blowing warm air. Wires from old system are as follows: Y=yellow; G=green; R=red; O=brown; C=blue; E=white (it looked...
the colors of old system are for heat pump.if you have a heat pump you need heat pump thurmostat and colrs will make more sense.if not,then you need to go into furnace to see what colors go where.yellow is cool, goes to compressor contactor,usually another wire going from furnace to outside unit.green is fan relay rh is heat call rc is cool call
Jan 01, 2011 | Honeywell Programmable Thermostat Heater
I installed a Honeywell TH5220d 1029 thermostat on a American Standard AC/Heat pump and the install and setup went fine. It cooles for about and hour and quit. I found the 5 amp fuse at the furnace...
Red wire to R on thermostat red on furnace and red on heat pump Same with white except w1 on thermostat. Blue to common on thermostat common of furnace (probably brown but will be marked) and blue to common on heat pump. yellow to Y on thermostat and straight to heat pump. Orange to O on thermostat and straight to heat pump. If wired correctly with no shorts fuse problem should be solved. commonly people leave enough wire exposed inside the t-stat for wires to short together. This will blow the fuse. Hope this helps. I understand the frustration.
Jun 27, 2010 | Heating & Cooling
Its saying MO in the upper left hand corner and AC won't turn on
Diagnostic: Set SYSTEM Switch to COOL and lower the setpoint below room temperature. Within a few seconds the thermostat should make a soft click sound. This sound usually indicates the thermostat is operating properly. Ifthe thermostat does not click, try the reset operation .If the thermostat does not click after being reset contact your heating and cooling service person or place of purchase for a replacement. If the thermostat clicks,contact the AC manufacturer or a HVAC service
person to verify the cooling is operating correct.
MO stand for MONDAY.
Jun 06, 2010 | White Rodgers White-Rodgers 1F85RF-275...
Mitsubishi PAR-F27MEA AC controller icon meanings
hi.welcome to the mitsubishi worl of airconditioning.thay are great units to have.ok let me explane this for you.
the sun is for heat mode
the snow flake is for cooling mode
rain droplet is for dehumifiy the air if its a humid day.i hope this helps you.you have to choose the modes on the remote for the unit.then the unit will do the mode you choose on the day.
Jun 09, 2009 | Heating & Cooling
Hunter 44100A programmable thermostat
Yes you will need the orange (o) wire for the reversing valve in your heat pump. T-stat color code is red (r) for 24v power from transformer. Blue (x or c) is the common or the other 24v power from transformer and this will power your programmable t-stat. Orange is for the reversing valve that will switch your heat pump from cooling and heating. Green (g) controls your inside blower. Yellow (y) brings on your outside unit. White is your backup heat.
Sep 28, 2008 | Heating & Cooling
Changing thermostat matching wires trouble
Brown my friend is for the 4 way valve solenoid, that is if you have a heat pump, ( it uses freon for heating instead of natural gas) perhaps you got the wrong thermostat, if you have a brown you need a thermostat for a heat pump, a regular thermostat is not going to have a brown connection.
May 08, 2008 | Heating & Cooling
How to wire hunter 44155
Go to the hunter web site. They will have the proper wiring diagrams on the site. If you cannot do that pick up a basic wiring book at your local electric parts supplier. the place you got the thermostat would be a good start. I do know that menards has some books in the electric area that would be a great help to you. You also will need to be sure that the thermostat is able to handle both air and heat. many only do heat. If this does not help let me know and I will try and get more information to you
Feb 07, 2008 | Hunter Fan Company 5/1/1 Programmable...
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
