Question about Surco 2003 Chrysler Town and Country - With a roof rack or rain gutters - Safari Roof Rack
I had a solenoid pack put in and lost the speedo a wire is bad near by can u help where to look
No codes are showing
  • mike
    mike Nov 29, 2014
    found it the pcm sucked trans fluid up the harness and shorted memory cleaned it out all good
    Master:
  • 706 Answers
Local Chrysler dealer, parts department
Posted on Dec 04, 2014
Had my 99 dodge carvan put on the machine its reading a code p1776
Solenoid pack needs replaced. I twill only get worse.. More codes.
May 24, 2016 | 1999 Dodge Caravan
Hello, have a 2003 Dodge Intrepid SE - 2.7L with 42LE Transmission - just replaced the solenoid pack and OD-UD, LR accumulators-new filter gasket and fluid - now it's giving me OBDII codes P0700 (
It sounds like you have a handle on this but I will ask the dumb question, are you coating the orings with petrolium jelly or trans assembly jelly? As far as the codes go, you might have a bad ECM. That mmany codes all at once seems suspect.
May 31, 2012 | 2003 Dodge Intrepid
Check engine code 31 for a 94 laberon
The 31 code is about the evap system purge solenoid circuit having an electrical problem (open or shorted). I doubt that explains the problem. dash. If you can get it to an Autozone parts store they will often do the readout for free.
Possible Causes Bad connection or wiring - Check the wiring and connections between the logic module and the solenoid. Clean and regrease any corroded connectors with dielectric grease and repair any shorts.
Bad solenoid - The solenoid is located in the right, front fender next to one to three other solenoids. See the Understanding Solenoids page for information about how to test and repair solenoids.
Diagnostic Method Trigger Parameters - Near 0V or near 12V not detected when the solenoid is turned on or off, respectively
Results If Component Fails Fault code 31 is stored.
Aug 11, 2010 | 1994 Chrysler LeBaron
Code 449? what is this,anyone. tks
Code po449 is for bad  solenoid vent valve.After replacing the valve  check for the   12 volts at the "pink" wire.
This error relates too
The PCM has determined that a malfunction exists in the electrical circuit for the vent valve/solenoid in the evaporative emission control system.
Definition:
EVAP (Evaporative Emission System) purge/vent solenoid circuit condition
Explanation:
The solenoids and system wiring are monitored for opens or shorts
Probable Causes
1- Purge or vent solenoids defective.
2- Check connector and wiring.
3- Fuel saturated vapor canister.
4- Failed EVAP vent solenoid.
The cost of the vent solenoid valve is near to 30 bucks. And the valve is located near the gas tank.
Thanks. you can rate this solution and show your appreciation.
May 20, 2010 | 2005 Chevrolet Silverado
Speed od. wont work and the park and drivedash lights all light up and wont shift
THERE ARE TROUBLE SPOTS IN WIRING IN A NUMBER SPOTS FOR TRANS ISSUES ON THESE VANS..
UNDER BATTERY TRAY..WIRES CHAFING ON TRAY
NEAR TRANS SOLENOID PACK..HARNESS CHAFE THRU
NEAR TRANS CONTROLLER UNDER LF FENDER
TRANS CONTROLLER HOUSING ITSELF..RUSTED OUT..
HARNESS IN FRONT OF TRANSMISSION..BROKEN WIRES
YOU NEED TO GET SCANNED AND SEE IF ANY FAULTS PRESENT OR EVEN IF YOU CAN COMMUNICATE WITH TRANS CONTROLLER..A CODE READER WILL NOT TRANSMISSION CODES..IT NEEDS TO BE SCANNED AND DIAGNOSTICS PERFORMED..SOUNDS LIKE A WIRING OR CONTROLLER ISSUE..I HOPE THIS HELPS
Feb 16, 2010 | 2001 Chrysler Town & Country
Chrysler Neon auto gearbox problems
P0733 IS GEAR RATIO ERROR IN 3RD AND P0734 IS GEAR RATIO ERROR IN 4TH..THESE CODES USUALLY MEAN AN INTERNAL PROBLEM IN TRANSMISSION,BUT CHECK WIRES AT SPEED SENSOR CONNECTORS FOR BROKEN WIRES BY PULLING ON WIRES AND WIRING NEAR SOLENOID PACK FOR CHAFING..I HOPE THIS HELPS..YOU MIGHT WANT TO DROP THE TRANS PAN AND LOOK FOR A PLUGGED FILTER OR DEBRIS IN PAN..MAKE SURE THE TRANS COOLER IN RAD HAS NOT FAILED ALSO
Aug 14, 2009 | Chrysler Neon Cars & Trucks
4l60e 2000 gmc tRANSMISSION PROBLEM
Replace the solenoid pack, or the wiring to the trans has problems. Usaully the solenoid pack in our Chrysler trans, but every once in a while, it is bad wiring.
Jun 02, 2009 | 2000 GMC Sierra
93 grand cherokee 5.2 all time 4wd wont stay runing when put in gear
It sounds like the torque converter is locked up. Possible a bad torque converter or converter solenoid. First thing you should try is unplugging the solenoid plug on the transmission. Drivers side, near the shifter. Not the three pin connector near the pan on the same side. The connector you want is higher than the reverse light plug.
May 30, 2009 | 1993 Jeep Grand Cherokee
Looking for manufacture code for trans mf code P1787
P1787 = 2-1 Downshift error. Possible causes; a bad solenoid pack, possible tcm, solenoid pack wires or connection, internal issue. Take is to the dealer, they can diagnosis the problem and reflash the tcm if needed.
May 04, 2009 | 1998 Dodge Caravan
Surco 2003 Chrysler Town and Country - With a roof rack or rain gutters - Safari Roof Rack Logo
62 people viewed this question
Top Surco Cycling Experts
Michial Gueffroy
John Egan
John Egan
Are you a Surco Cycling Expert? Answer questions, earn points and help others
