Question about Frigidaire Dryers
Frigidaire dryer #FEQ1442CESO Heats sporadically
Could it be a loose element or connection
  • Frigidaire Master
  • 3,382 Answers
Yes but it could also be a faulty control or sensor. Check the heat sensor.
Posted on Nov 27, 2014
Illeagle
  • 525 Answers
SOURCE: Dryer tripped out during cycle
An electric dryer must be on a circuit by itself. If you lost power to downstairs sockets, you will need an electrician to separate the 120volt side from the 240volt side. You may not have a problem at all with the dryer. If another appliance was operating at the same time as your dryer, that appliance would have overloaded your circuit and tripped the breaker. Please have this looked into by an electrician to avert a possible fire!
Your tech should have recognized this situation or maybe I have misunderstood the issue, but I gave my opinion based on the question above,
If my assistance helped resolve this issue, please show your appreciation by rating how effective my advice was in resolving this issue.
Thank you,
Dave E. (Illeagle)
"Your satisfaction is my personal reward"
Posted on Jul 07, 2008
  • 23 Answers
SOURCE: Heating element heats up, but dryer will not spin.
Since you stated that the heating element is heating up I believe it rules out the thermal switches.
When you push the start button does it make the motor make any noise? Maybe hear the motor humming? Two things to check for are Broken Belt or Bad Motor:
This requires common sense and since you are going to be bypassing the safety features you need be CAREFUL.
First, with door open, manually press in door switch to by-pass door safety, then press "start", try to manually start the dryer by spinning the drum by hand, If you hear the motor humming but it does not start spinning on it's own; most likely it is a broken belt which can be changed without much difficulty for less than $15 bucks. NOW if it then continues to spin on it's own GET YOUR HAND OUT OF THERE and close the door; you have a bad motor and even though it started it needs to be replaced. A motor for that is available for just under $100 bucks and is not to bad to replace, I would recommend replacing the belt at the same time since you will be in there. Good Luck!
Posted on Apr 29, 2009
lsteward68
  • 331 Answers
SOURCE: heating element bad on frigidaire dryer. how do i install
do you have the element on hand?
Posted on Jun 14, 2009
BarrettDenCo
  • 1772 Answers
SOURCE: How do you connect the wires to the heating
Sorry to read about your problem, I hope this helps you out.
you have to remove the back of the unit....
I tried to help you. Please help me and Rate/Vote on my response, thanks and good luck
Posted on Dec 25, 2010
canwoodjc
  • 3301 Answers
SOURCE: I have a frigidaire model
the door isn't locking properly , open the door and close it again
Posted on Jul 20, 2011
Tappan tef351ewc
Loose connection somewhere?Replace both elements,make sure connections are tight!
Jan 10, 2014 | Kitchen Ranges
Wires to heating element keep burning off
One of the creramic insulators that hold the heater elements may have broken allowing the element to ground out to the metal casing creating a short.
Also a loose wire or crimped connection where the heater element connects will create overheating and eventually a shortout.
If a ceramic insulator is broken, its probably best to purchace a replacement element wich may be available thru appliance parts online.
a loose factory connection can be replaced with a screw type wire connector be sure it will withstand the heat and amperage.
Aug 27, 2011 | Maytag Dryers
The grill (Upper Oven Grill Element) in the oven is not working, I realized the 4 wires at the back that connect to it are all loose. Can i fix it by connecting them myself? is it something dangerous or...
With 4 terminals, it sounds like a double grill element. But it could also be a single grill element with a second oven element. If the spade connecters are loose they need to be tightened first. Get a pair of pliers and gently squeeze the terminals until the gap reduces so when it slides on it will be tight. Do you know what wires go where? If so reconnect them. If you don't do the following;
As you look at the element terminals they should run horizontally. Look at the element inside the grill compartment. From left to right, the no. 1 and no. 4 terminals should be the same element and the no. 2 and no. 3 terminals should be the other element. If this is correct put the 2 neutral wires, in any order, on terminals 1 and 2 and the active terminals on 3 and 4. This should work. You just have to check the correct element comes on when you operate the grill/oven controls.
Feb 18, 2011 | Smeg Ovens
All heating elements stopped working. Power is on and all other lights and clock work.
hello,
hello,
what this means is an indication of disconnection of wire from the element position .
the element it is silver in colour it is connected to the main wire that supply power over to the range
what you need to do to fix up this problem is to unscrew (open)the range with the bass tools then trace the wire down to the element connected to the screen to see if the loose wire that have loose it position fix back to the element connected to the screen ,but if there is no wire that have loose it position from the connection then it mean that the element is weak you will have to replace it with another better one which you can get from the store please make sure that you are getting same size of the old/ weak one.
please make sure that all power supply on the range are disconnected from it before working on it .
thank you and thanks for using fixay.
Jun 16, 2010 | Frigidaire GLEF378 Electric Kitchen Range
I am replacing the lower oven baking element. After pulling the defective one out, I find no female receiver for the male connection tabs on the element. Are they loose wired? I am used to just plugging...
They probably are loose wired unless you see a porcelain receiver for them... it is CHEAPER so they do it! Maintainability? None !!!
With power disconnected, you MIGHT be able to "fish" the leads back out and attach before mounting the element.
Oct 17, 2009 | Viking VEDO205 Electric Double Oven
Element 26 model ELCHS 261. The tv powers up ok but
has problem on the board.the solder is loose or loose solder
Jul 18, 2009 | Element Electronics FLX2211B 22 in. LCD TV
Element is loose
It would be helpful to know about your manufacturer and model number of dishwasher.
There are a couple ways that a heating element can be loose. If it is broken inside the dish washing space, then replacing it will fix that problem.
If the element is loose where one of the ends connects to the bottom of the dishwasher, there is a fair chance that your dishwasher is leaking water under it. That needs to be checked out quickly.
Look closely and see what the situation is. Post here if you need more assistance.
Good Luck!
Apr 10, 2009 | Dishwashers
Wiring a heater element on a hobart am14
That connection was probably a little loose and caused that.
Jan 24, 2009 | Hobart 29 in. AM15-1 Free-Standing...
Stove tops don't heat up, and when they do, it turns of again.
It sounds to me like you have loose electrical connections on your cooktop. Pull each element, and reset. The spash guards under the elements have groves in them to support the elements. These elements need to be supported so that the elements are not moving. Any movement can cause the elements to lose their connection and thus not be able to heat up.
Please rate this solution
Jul 31, 2008 | Whirlpool Kitchen Ranges
Dryers Logo
64 people viewed this question
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
