Question about Exercise & Fitness
I have a Tectrix climbmax 1000 purchased 18 years ago that was still working excellently until last year. Following a move the controller and power supply seem to be working fine but the two steps ar
I tried to open up motor housing but it seems that hasn't been opened since it left the factory. I can't find anywhere externally that looks like it would lock the motor or steppers in place.
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 60 Answers
There are typically cables that lock the clutches in place, if one of the steps has fallen down. Putting them back in place usually does the trick.
Posted on Dec 10, 2014
  • 14 Answers
SOURCE: lights on at the power supply but display doesn't light up and no stair resistance.
Remove the cover on the side where the power cable goes in. There is a connector on the inside there. Inspect the wires going from the inside cover to the alternator. Sometimes the wire pulls out of the connectors. Other than that you will need to troubleshoot all the wires with a meter and see where your power is getting lost.
A good tech support line is National Gym Sypply if you know how to use a meter, know the names of the parts, these guys can help.
Posted on Apr 29, 2009
SamThePirate
  • 77 Answers
SOURCE: need to find part numbers for bearings on a
Those are always marked on the bearing shield itself. Look for a number that looks like this: RS 6802 RS or 6104 R.... it will be a letter/3 or 4 digit number/ letter combination.
Posted on Jan 10, 2010
walesarumi
  • 6993 Answers
SOURCE: Hi...I have a Diamondback 1000es
if it does not power up, then it means its having a power problem. it might have worked fine in the past, but that's electronics for you. Power surge, irregular power supply, excess power supply, etc can affect the unit thereby not making it to power on.
This unit must have a power supply board in it where power enters from the mains. A capacitor, fuse, diode, etc may have been defective on the power board and maybe that's why its not making the unit turn on. There might also be some disconnection or something, inside the unit which is not making it to power on.
To actually find out what's wrong, you need to disassemble the unit with a screw driver and check what's wrong. You will be needing a meter in order to test the components on the power board, once you detect any bad component, you can make necessary replacement at any electronics accessories store withing our vicinity. This is the only way by which you can detect the problem.
Of course, testing the power board with a meter will require someone that has the ability. So it you can't, then you might be needing the help of a repairman or you can call a friend that has the ability to help you out.
I wish you the best of luck.
Posted on Dec 22, 2010
  • 5370 Answers
SOURCE: I need a transformer for
Its AC voltage.The transformer can be bought through online sites.------ To order transformer, click this link below:--- http://www.fitnessrepairparts.com/cart/ViewItem/6000550 ---------- If you require any other parts, except transformer then click this link:--- http://www.fitnessrepairparts.com/equipment/Select/2643/Proform/PF300111-3001-STX ------------ this should help.Thanks.Helpmech.
Posted on Jul 02, 2011
emissionwiz
  • 79851 Answers
SOURCE: My DiamondBack HRT 1000 ES Stair Climber isn't powering up. The power supply tests OK. The display was replaced 3 years ago. Any ideas on how and where to test ?
No we have little to zero info on this type of product, sorry. I suggest you give the customer service dept for the product a call, you should be able to track down their phone # on the Internet.
Posted on Jan 20, 2012
Que es error 5 tectrix personal climber
Replacement Parts for Fitness Exercise Equipment at SPORTSMITH
Error 5, No Slack, Cybex/Tectrix Climbmax 2000/3000, 700S and 800S Steppers Probable Cause An error 5 on the Tectrix Climbmax models 2000 and 3000 as well as Cybex stepper models 700S and 800S indicates the following:
a) Test switch is in test mode.
b) Possible cut in display cable.
Corrective Action a) Adjust slack switch.
b) Inspect display cable; Replace cable if necessary.
Error 5 No Slack on Cybex and Tectrix Steppers Climbmax 2000 3000 700S 800S
Apr 10, 2014 | RTO Tectrix Personal Stair Climber
"no slack"
Corrective Action Tectrix Climbmax
Error Code Reason Suggested Action 5 No Slack Enter test mode and test switch, adjust switch, inspect display cable for cut or crimp
Tectrix Climbmax Error Codes
Mar 16, 2014 | Tectrix Remanufactured Climbmax 150...
Err 5
Feb 22, 2014 | RTO Tectrix Personal Stair Climber
Screen shows error code 5
Feb 20, 2014 | RTO Tectrix Personal Stair Climber
Screen shows err 5
I have a tectrix Stair climber that is displaying No Brake, what do I need to fix this?
Error Code Reason Suggested Action 5 No Slack Enter test mode and test switch, adjust switch, inspect display cable for cut or crimp 6 No Brake Adjust slack switch or replace motor
Jan 02, 2014 | Tectrix Remanufactured Climbmax 150...
Parts
This cable can be ordered from our Website. Please have your exact model and serial number ready. The following link will take you to our Tectrix stepper page.
Tectrix Cybex Stepper Parts Climbmax Personal Climber 2000 3000 Model 150...
May 07, 2013 | RTO Tectrix Personal Stair Climber
Exercise & Fitness Logo
320 people viewed this question
Top Exercise & Fitness Experts
Howard
Howard
Sportsmith LLC
Sportsmith LLC
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
