Question about Ovens
Oven is flashing fx20 erro - Ovens
    Problem Solver:
  • 6 Answers
Utilize black friday special for new oven. Unplug oven and make sure vents are not blocked, then try it again.
Posted on Nov 27, 2014
Co1 erroe code distinctive wall oven what is problem
According to your model number this code means Shorted or stuck key. Your keypad needs to be replaced. Good Luck
Aug 07, 2014 | Dacor Distinctive DO130 30" Single...
Oven wont unlock, flashing erro f1e5
The latch mechanism has failed. If this happened after using the self clean option then it may be possible that the main control was damaged and could be part of the problem. To get the door open I use a coat hanger with one end hooked to reach in and pull the latch back enough to open the door. Good luck, let me know if you have any questions
Apr 24, 2012 | Whirlpool Ovens
Giving current erro message
Check connection at I/O board that it's not damaged.otherwise replace I/O board Give me some more details so I can give you accurate answer. Give me details what is showing in the screen Thanks Please rate me for this Reply me with questions I will be happy to assist you.
Sep 03, 2011 | TurboChef TORNADO Electric Oven
I have a free standing stove/oven, model #790.94111402, Serial # VF51340715. The display shows "Erros F10". Please help.
Hi
Thanks for using FixYa. F10 error indicates that the control board (ERC) has gone bad and the electronic range control (ERC) should be replaced to resolve the issue. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Sep 16, 2010 | Kenmore Ovens
Please help erro code 00E on sanussi multi oven model is as per book zsm 705 w/k ps i am in australia
This code is an open circuit of the Oven sensor which needs replacing.
To access this remove the top panel and left hand side panel,detach the wiring connector from the sensor.Detach the sensor from the clips on the inside of the oven.Remove the sensor from the rear of the oven.When replacing the sensor, make sure it is securely held in position by both clips.
Hope this helps.
May 21, 2010 | Ovens
Problems with TurboChef TORNADO Electric Oven f8 erro.
F8 means Heat rise low the oven failed to warm up in a predetermined time period. First check for problems with the blower and then check the high limit thermostat to see if its tripped. If these are okay call a repair tech because you will need to check the relays for problems
Jan 21, 2010 | TurboChef TORNADO Electric Oven
Bosch oven function error e124
Can you provide a model number for your oven. Is it a single oven or double ? Wall oven or free standing range ?(conventional with cooking surface)
Unfortunately the error codes for Bosch are different depending on the model of the unit.
Thank you, I`ll look for your reply.
macmarkus :)
Jan 09, 2010 | Bosch Ovens
Stopping the self-clean function after starting in erro
You don't have a cancel clean button on it? If not, you may have a reset button in the back of the oven. Otherwise, you may have to let it "run the cycle". Hopefully, you don't have wooden/plastic handles on your frying pans.
Dec 29, 2008 | Whirlpool RBS245PDS Electric Single Oven
Erroe code 5ab
According to the manual, this mode is SAB and not 5AB. SAB stands for sabath mode and lasts for 72 hours. The mode may be canceled by holding in the clock button for 3 seconds. This mode was activated by holding in the clock button for 3 seconds. My wife did the same thing when resetting the clock for daylight savings time this year. Resetting the power does not reset SAB mode.
Nov 21, 2007 | Amana AOCS3040 Electric Single Oven
Ovens Logo
50 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
