Question about Car Audio & Video
What causes the windows of my a4 Audi 2002model, 1.8turbo not to function correctly
Changing the battery of mobiliser
  • 3,368 Answers
Are you sure they are not functioning correctly? Why do you think that?
Posted on Nov 27, 2014
Where is the module and switches on car placed situated audi a4 2002model
Your best option if you plan to DIY, is to obtain a copy of the Chilton's manual for your vehicle.
Nov 29, 2014 | 2002 Audi A4
What is the problem with my mobiliser, it doesn't function at all, I tried to change the battery , but no results
If a new battery did not solve the fault you have to take it back to Audi for repairs.
Nov 27, 2014 | 2002 Audi A4
What causes the windows of an Audi A4 2002 model to freeze
WIRING HARNESS PROBLEM SWITCH PROBLEM OR COMFORT ECU PROBLEM..FOR MORE LET ME KNOW
Windows of an Audi A4 2002 model have freezed what is the problem.
All Windows or 1? If all check fuses. layout is in owners manual as well as locations. If one window either the window switch or window motor. If you a little mechanical you can change out switch. If not find a good mechanic with references on your car. Motor is more labor intensive. Hope just the switch. If it is the fuse and you replace it and it blows again, short in the wiring. Good luck
Water pump impeller query
Hi my name is Tom and I am here to help.
All impeller blades are made of plastic. This way they will keep a tight fit on the inside of the water pump. Metal would not be able to do this.
TomE
Jul 04, 2010 | 2002 Audi A4
Electric windows and central locking wont work first thing until car has been drove for a while A4 tdi audi 2001
First check the battery voltage when the windows and door locks will not work (before driving) Will they function if you connect a battery charger? (Low battery voltage) This condition may be related to the security system (if installed) or poor electrical connection to the battery bus that is overcome when the alternator is charging.Be sure to check for 12V connection to the ECM and security Module (if installed)
You will probally need a schematic to check the wireing, Start with the 12v to the windows switches and discover where the power is missing. It will probally be common to the lock problem at some point.
Good Luck
Sep 28, 2009 | 2001 Audi A4
200 AUDI A4 WILL NOT START AFTER BATTERY CHANGE
make sure you have the correct battery for you car.
May 18, 2009 | 2005 Audi A4
I just replaced the battery in my 2003 audi a4 quattro. Now when I turn on the car the light for the ESP system wont turn off. In the owners manual it tells me that I have to reset the engine management...
Try taking the car to an Audi dealer to reprogram the key.In some cases,depending on the country it was imported from ,it may take several attempts at programming to get it right.Your Audi dealer should do this at no charge.As for removing the battery,always clamp an alternate 12v source to the car cables so the vehicle does not lose a 12v source when changing batteries.These are complicated cars.You need to recode some systems after total loss of 12v.Once again the dealers will help.
Cheers
Aug 03, 2008 | 1996 Audi A4
Car Audio & Video Logo
35 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
