Question about Audi Vehicle Parts & Accessories
Audi a4 2002model 1.8turbo, windows stop working, what might be a problem?
I bought a new mobilizer battery, no results
  • Audi Master
  • 3,368 Answers
Check the fuse.
Posted on Nov 27, 2014
What causes the windows of an Audi A4 2002 model to freeze
WIRING HARNESS PROBLEM SWITCH PROBLEM OR COMFORT ECU PROBLEM..FOR MORE LET ME KNOW
Nov 27, 2014 | 2002 Audi A4
Windows of an Audi A4 2002 model have freezed what is the problem.
All Windows or 1? If all check fuses. layout is in owners manual as well as locations. If one window either the window switch or window motor. If you a little mechanical you can change out switch. If not find a good mechanic with references on your car. Motor is more labor intensive. Hope just the switch. If it is the fuse and you replace it and it blows again, short in the wiring. Good luck
Fuel pump relay location
Hi all happy new year 2016 i have exactly same problem with Audi a3 8p 2.0l fsi 2005 fuel pump running all the Time ( with and without ignition)non stop . For stop it i need to remove fuel pump fuse.
I think this part is defective
I want to have helps before buy it
Thanks in advance.
Feb 27, 2014 | 2005 Audi A3
My 86 Audi 5000 CS Turbo has quit running while driving but at stop signs or stop lights with no indication of anything wrong. When I try to start it again the battery is dead. I've bought batteries...
IF ALTERNATOR AND BATTERY BEEN REPLACED.REPLACE THE BATTERY CABLES AND CHECK ALTERNATOR FUSE AND CHECK ALTERNATOR POWER BATTERY FEED WIRE AND VOLTAGE REGULATOR WIRES FOR DAMAGE.
Sep 04, 2011 | 1986 Audi 5000 CS
Audi battery replaced whit new battery electic windows not working tryed fueses still no joy
im not sure what year or make this audi is but some will loose the programing and need to be reprogramed, the dealer does this, but if the windows had a problem before the battery replacement then there good be a problem with the driverdoor window switches, if that switch goes bad then no window will operate, pop switch up and test for power to switches, also make sure all wires are connected back on to the battery and that nothing was pulled apart. good day.
Jul 30, 2011 | Audi A4 Cars & Trucks
Need to find Active-sync program for Dell Axim 51V
I believe Active Sync has been replaced by Windows Mobile Device Center for Vista. I'm not using my Axim any longer but was able to sync it using Windows Mobile Device Center. You should be able to download at :
http://www.microsoft.com/windowsmobile/en-us/help/synchronize/device-center-download.mspx
Hope this helps.
Mar 15, 2009 | Dell Axim X50v Pocket PC
Audi 2005.5 fobs have stopped working--put in new battery---
this is very common for this car, the transmitters will just stop working. youll need a new key fob and you will need to have it programmed at a dealership.
Dec 11, 2008 | 2001 Audi A4
My passenger electric window in my car doesnt work anymore if it goes all the way down its almost impossible to get it up again! how much would it cost to get a new motor? my car is 1999 audi a3 but...
The window regulator clips are a very common failure. I bought some on ebay which were an improved version compared to the original supplied with the car. I think they are regularly available on ebay!
Jul 08, 2008 | 2005 Audi A3
Vehicle Parts & Accessories Logo
Top Audi Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Randy Ohler
Phil Fisher
Level 1 Expert
Are you an Audi Vehicle Part and Accessory Expert? Answer questions, earn points and help others
