Question about Bosch Kitchen Ranges
Oven not working on gas bosch stove, has never worked since purchased, oven doesn;t come on at all, lights just blink
Burners all work fine, gas works, electrical component must be working as the lights come on but just blink/flash, is a part missing maybe from the circuit board?
  • Bosch Master
  • 3,382 Answers
I would go back to where you purchased it and see if they can repair it under warranty. If you have had it to long then oops you may have to pay for it. I doubt there is anything missing form the circuit board.
Posted on Nov 27, 2014
  • 183 Answers
SOURCE: Tappan Gas Range Oven Will Not Light
probable displaced burner assembly, faulty flame failure device or blocked burner or jet. Regards Engineer
Posted on Jul 28, 2007
aborcass
  • 2651 Answers
SOURCE: KENMORE GAS STOVE OVEN LOWER BURNER WON'T WORK
bad oven ignitor is the most common cause of bake failure, located onthe side of hte burner bar itself, if youd like with a multi-meter, you can check the wires leading to the ignitor for 110v. if you have power and nothing was glowing from ignitor theres your problem
Posted on Nov 23, 2008
heatman101
  • 43501 Answers
SOURCE: Maytag oven doesn't fire, but stovetop burners work fine
This will sound crazy but I had to work through it on my own stove a few years ago. The ignitor (glow tube) was getting hot but the oven would not owrk. When investigating the problem I found that the gas valve will only open when the ignitor pulls a specific amperage or draw of current. As the ignitor ages it pu;;s a reduced draw of current. This causes you to be fooled by the glow nut no gas. Replace your ignitor and your oven will begin to work again!
You can get ignitors easily online by doing a search for "appliance parts" and then entering the model number of your stove. Look for ignitor and you will be good to go. Also check out a few different sites as the prices of the parts can vary quite a bit.
Posted on Nov 20, 2009
Testimonial: "Thank you very much for your help. I was looking for a thermocouple but that must be old school. I couldn't figure out what told gas to flow."
SOURCE: Viking stove top gas burners
I have a VGR36 6 burner. All the spark ignitors stopped clicking after a major boilover spill. Liquid got into the spark module compartment and caused a short. The paper wiring diagram under the spark module protective cover was burned from the short. I had a Harper 6542 non-reignition spark module but the replacement part is now a Tytronics PA020041 Spark Module. I bought kit #000511-000 from allvikingparts.com which includes the module, a black jumper wire, a green ground wire and an instruction sheet.
It's not difficult to replace the spark module but the 2 screws holding down the module toward the back of the stove are not visable and accessible. I used a thumbwheel rachet with a long philips screw driver bit (for cordless drills) to remove and replace the screws. The wiring was simple. The 2 power wires need to be wired to the correct polarity on the module, but the remaining 4 ignition wires can be wired to any of the 4 terminals on the new module. All the wires have plug in connectors and no cutting and splicing is necessary, but I had to cut and splice because one wire shorted and the insulation was burned from the major spill on my stove.
Posted on Mar 19, 2010
SOURCE: Frigidaire electric stove, burners work oven does not. No clock
one of the stoves does not work. What could be the problem and how to fix it?
Thanks
Posted on Sep 13, 2010
My oven is not working. At the bottom of the stove the ignitor light comes on, but gas doesn't come on. I would like to fix the problem, can you instruct me on how to fix my oven. I want to bake...
The ignitor is probably weak. You have a good circuit because the oven control is trying to light burner. The gas valve is alo fine because it is allowing current to flow. The ignitor with age does not draw enough current to light off the stove.
Aug 23, 2011 | Tappan Ovens
Poorly functioning Shipmate stove
Hi
Normally pressing red buttons on stoves is for lighting the oven. You press the button, light the pilot light, leave it depressed for a minute and then that heats up the thermocouple, which opens a valve and allows gas to the main burner.
Shipmate Stoves are still in business, so you could contact them. The link also suggests places for Shipmate propane gas stove spares.
Shipmate stoves Google Search
Mar 27, 2017 | Brown Stove Works 23 in. TL03-3 Gas...
Kenmore Range/oven Burners won't lite
Ours did the same, I unplugged the stove for 1 minute and afterwards the burners worked fine.
May 19, 2009 | Kenmore 75844 / 75849 Gas Kitchen Range
Most likely a hot-surface ignitor has failed. If it doesn't consume enough current, the gas valve won't open. It's usually a fairly easy fix, once you gain access to the ignitor and have a new one to replace it with. Make sure you unplug the range...
Apr 25, 2009 | Ovens
Jul 20, 2007 | Tappan TGF320 Gas Kitchen Range
Demo Mode
press and hold the mode button for more than five seconds. Then use the knob to scroll to "Default". This sets the stove to normal operation.
Dec 09, 2006 | Bosch HGS435UC Gas Kitchen Range
Kitchen Ranges Logo
108 people viewed this question
Top Bosch Kitchen Ranges Experts
Oloyede Monsuru
Jim Thurston
Are you a Bosch Kitchen Range Expert? Answer questions, earn points and help others
